Post a Run!
Postby EddyMataGallos » 2013.10.02 (22:38)
Haha thanks, its been a long time without playing lat everybody would need to shake off some cobwebs after so much time ;) Although actually you aren't rusty at all for not having played for so long, its impressive indeed. At this rythm you'll be kickin' some asses on Metanet highscoring soon.
Glad it worked a bit, I did feel the difference when I did it on Win7.
As for that guy, that must be an admirer then :P He mostly plays userlevels but he has 3 Metanet Top-10s I think.
Nice innov indeed btw, used it to improve my run by a couple tenths.
Postby golf » 2013.10.09 (02:14)
Taking dan and my advice and moving this discussion over here: 129-1 is mine again. I think its time you step off of this see-saw we've been riding on and just admit defeat daniel :)
Postby ska » 2013.10.09 (03:59)
golf wrote:Taking dan and my advice and moving this discussion over here: 129-1 is mine again. I think its time you step off of this see-saw we've been riding on and just admit defeat daniel :)
I haven't seen this much highscores competition on an NReality map since "International take a 0th off xaelar week"!
Postby _danielr_ » 2013.10.09 (11:07)
golf wrote:I think its time you step off of this see-saw we've been riding on and just admit defeat daniel :)
Fine.
SIKE! Have another 14 frames. :P I promise I'll stop now.
Postby MiBeM » 2013.10.09 (18:22)
Pretty sick runs on 129-1. I've never been able to pull off the chimneying through locked doors trick and I was wondering, is it all about speed or is there some timing involved?
a.k.a. MoleTrooper/Molenator
Speedruns and stuff
Postby ska » 2013.10.10 (01:05)
Daaaaaaaaaaaaaamn. Golf got owned!
Postby golf » 2013.10.10 (01:48)
ska wrote:Daaaaaaaaaaaaaamn. Golf got owned!
lol sure looks like it. I may try to retake it, but that's a pretty sizable lead at this point. When I got that 110.000 score I knew there was still a lot left in the level. I compared our runs in demo mode, and dan had me by a good 10+ frames right until the chimney up to the door. I was able to go pretty much straight from landing after the last set of gold straight up to the chimneying, while he slowed down to get a better angle up and in. So that was maybe a half a second swing.
To answer MiBeM's question, I think there has to be some timing involved. Go take a look at the last several posts in the Metanet 0th thread (which title looks like a dude shrugging his shoulders right now... thanks van) to see the discussion that's spawned. Really, about the entire last page worth is pretty interesting and I think worth reading. To be a little more specific, you have to have a pretty good amount of speed, but for a chimney of the length in the 129-1 route you just can't get enough pure speed to blaze past the first door, so there has to be some sort of timing needed to make it through. Personally, I've never really known what that is, my usually terrible chimneying tends to put me through every once in a great while, only often enough to me that it seems completely random.
As an aside, I want to see what ska can get on 121027 since you made that comment that started this whole mess on 129-1, and it looks like you've never posted a score there.
Postby ska » 2013.10.10 (10:47)
lol, I'm retired.
(Until I take my next 0th)
Postby _danielr_ » 2013.10.14 (23:27)
It suddenly occurred to me that 129-1 sr was probably easier than hs. So I took it off Kool, heheh
Postby golf » 2013.10.15 (00:03)
Ha good job. I'm still proud of my past ownage of 129 speedrun, although I have none of them left. Thought for sure -3 would be safe forever but apparently not :(
Postby MiBeM » 2013.10.16 (15:49)
Randomly playing numa maps to get used to my new keyboard, got a pretty cool run I think on 200004 sr ^-^
Speedruns and stuff
Postby ska » 2013.10.17 (05:17)
230846 hs
I think you can shave off a few frames here and there...
Postby alsojp27ace » 2013.10.17 (21:13)
ska wrote:230846 hs
Nice run, taken with a pretty simple innov at the start
Postby ska » 2013.10.18 (07:36)
alsojp27ace wrote:
ska wrote:230846 hs
Yep. well done, my comp is lagging right now, so 230871 hs is a run I made the other day.
Postby MiBeM » 2013.10.20 (10:28)
200011 sr. Had a lot of fun with this map.
Edit: also got a pretty neat run on 200013 (still sr)
Edit 2: 200015 sr, can't believe I just did all those cjs o.O
Speedruns and stuff
Postby golf » 2013.10.20 (15:59)
MiBeM wrote:Edit: also got a pretty neat run on 200013 (still sr)
200013 was a pretty neat run, but not neat enough :) And your start on 15 you make it look deceptively easy to get that first corner jump, good job there.
Postby _danielr_ » 2013.10.20 (16:09)
Took 200015. Plenty cleanable though.
This would be the ideal route:
$###9000000000000000000000000000000000000000000000800000000000000000000001111111PP000NN11111111111111111PP000NN11111111111111111PP000NN11111111111111111PP000NN11111111111111111PP000N11111190000000000000000000006000000000000000000000000000000000000000000000000000000000000000000000800000000000000000000071111111PP000NN111111111111111PP000NN111111111111111PP000NN111111111111111PP000NN1111111111111111P000NN111111111111190000000000000000000006000000000000000000000000000000000000000000000000000000000000000000000800000000000000000000071PP000NN11111111111111111PP000NN11111111111111111PP000NN11111111111111111PP000NN11111111111111111PP000NN11111111111000000000000000000000060000000000000000000000000000000000000000000007|12^204,420!12^180,396!12^156,372!12^132,348!12^108,324!12^108,228!12^132,252!12^156,276!12^180,300!12^204,324!12^348,324!12^348,228!12^372,300!12^396,276!12^372,204!12^396,180!12^420,156!12^444,132!12^444,228!12^420,252!12^588,84!12^612,108!12^636,132!12^660,156!12^684,180!12^684,276!12^660,252!12^636,228!12^612,204!12^588,180!2^48,576,0,-1!2^72,576,0,-1!2^720,24,0,1!2^744,24,0,1!5^60,528!11^732,528,732,528!0^276,546!0^288,540!0^294,528!0^288,516!0^276,510!0^264,504!0^258,492!0^264,480!0^276,474!0^276,456!0^264,450!0^258,438!0^288,450!0^294,438!0^264,426!0^288,426!0^276,420!0^516,450!0^504,444!0^498,432!0^504,420!0^516,414!0^528,408!0^534,396!0^528,384!0^516,378!0^516,360!0^504,354!0^498,342!0^504,330!0^516,324!0^528,330!0^534,342!0^528,354!6^228,132,2,1,0,3!6^324,468,2,1,0,1!6^564,132,3,1,0,3!6^468,468,3,1,0,1#170:17895697|17895697|17895697|17895697|40265457|35791394|35791394|8738|35791392|35791394|8738|35791360|35790850|35791394|107405858|107374182|107374182|107374182|107374182|237117990|107374182|107374182|107374182|105145958|1638#
Shame about the drone...
By the way, why not try 200012?
Postby MiBeM » 2013.10.20 (16:44)
_danielr_ wrote:why not try 200012?
I kinda got bored of that map after playing around with it for a while. Maybe I'll try it again later.
Speedruns and stuff
Postby EddyMataGallos » 2013.10.20 (17:00)
_danielr_ wrote:Took 200015. Plenty cleanable though.
Fun levels, took both. I did 12 in hs mode because it also submits to sr, which doesn't happen the other way around, remember that, it's beneficial.
Postby macrohenry » 2013.10.21 (16:02)
128999 sr
Not that hard to do, but it looks cool. :D
Postby MiBeM » 2013.10.22 (16:25)
200020 sr, just barely couldn't get under 1000 frames :P
Speedruns and stuff
Postby _danielr_ » 2013.10.22 (21:54)
macrohenry wrote:[128999 sr] Not that hard to do
Come on then. How long did it take to cut it down to that speed? ;)
MiBeM wrote:200020 sr, just barely couldn't get under 1000 frames :P
Eddy's run - TROLOLOLOL
Postby MiBeM » 2013.10.23 (17:12)
_danielr_ wrote:Eddy's run - TROLOLOLOL
Dammit Eddy. You did that on purpose didn't you? :|
Speedruns and stuff
Postby EddyMataGallos » 2013.10.23 (18:31)
mwahahah
Postby MiBeM » 2013.10.24 (08:09)
200029 sr. I think I'm pretty well used to my new keyboard now, maybe it's time to get back to actual Metanet/Nreality levels :D
Speedruns and stuff
Users browsing this forum: No registered users and 93 guests
