Post a Run!
Postby ska » 2013.08.05 (03:18)
_danielr_ wrote:Nreality 81-4 sr (sorry/thanks again, jp)
The first chimney is a tad slow and I catch the thwump on the way back, but otherwise I'm very happy with it :)
siiiiiiiiiiiiiiick. dronie-nom-worthy imo
Postby macrohenry » 2013.08.05 (15:30)
Wow... That's all I can say.
Postby MiBeM » 2013.08.05 (17:23)
You're a god. Freaking insane run :D
a.k.a. MoleTrooper/Molenator
Speedruns and stuff
Gross
Postby jp27ace » 2013.08.05 (18:57)
ska wrote:siiiiiiiiiiiiiiick. dronie-nom-worthy imo
Screw you.
Also taken a8-4
Postby _danielr_ » 2013.08.05 (19:45)
Wow jp, awesome run! Wasn't Eddy boasting about that not long ago? hahaha
Postby macrohenry » 2013.08.07 (08:36)
230168 hs/sr
Gross
Postby jp27ace » 2013.08.08 (20:49)
Squeezed 1 more frame out of 45-0, I was trying to boost myself off the top corners but I couldn't get it to work
Postby MiBeM » 2013.08.10 (09:30)
34-4 sr taken with a route change, probably my best run yet ^^ Still not quite perfect, I might try to squeeze off a few more frames later.
Speedruns and stuff
Postby ska » 2013.08.10 (12:22)
MiBeM wrote:34-4 sr taken with a route change, probably my best run yet ^^ Still not quite perfect, I might try to squeeze off a few more frames later.
wow. nice innov - can be used for highscoring too by the look of it... (I'm talking to you, Eddy or macrohenry or perhaps a more weekender highscorer)
Gross
Postby jp27ace » 2013.08.11 (19:42)
Nice run Mibem, and yeah as ska said unless the drones somehow screw you over it looks like it could be used for high-scoring too.
Taken 60-3, 60-4, 61-2, and 64-1. Also improved my 60-1 (All v2.0)
Postby Raif » 2013.08.11 (20:43)
It would be faster if you added a triple at the end (left side) like I do in my MBD. Also check my MBD for other improvements to the route. You can try the pj + bbbwj on the right side if you think you can do it :D
Also me and TRO came up with the faster version of the route MiBeM uses nearly 3 years ago. You guys should really check my MBDs more often; there are atleast a few more routes that can be pulled off in realtime with a few changes.
Postby MiBeM » 2013.08.12 (13:29)
Raif wrote:It would be faster if you added a triple at the end (left side)
I'll try that out, the right side in your run is far beyond my skill level though :D
Speedruns and stuff
Postby ska » 2013.08.12 (14:53)
ahhh that's right! I knew I'd seen a faster route on that map!
Postby MiBeM » 2013.08.12 (16:44)
Another 1,5 hours later I finally got under 1000 frames with the triple jump at the bottom left, thanks to Raif for suggesting that trick. This is definitely my favorite of all my runs so far.
On a somewhat related note, a couple of days ago I discovered that I can right click and select "show all", which makes the game area fill almost my whole monitor. That made my play a heck of a lot more consistent since I can see the game way better now. I don't know, this might be something everybody has been doing for years but I just found out and thought I'd share :D
Speedruns and stuff
Postby ska » 2013.08.13 (01:43)
MiBeM wrote:Another 1,5 hours later I finally got under 1000 frames with the triple jump at the bottom left, thanks to Raif for suggesting that trick. This is definitely my favorite of all my runs so far.
I think a lot of highscorers/speedrunners are aware of this. (This only works in NReality though). I personally don't find it to affect my ability to play one way or the other, so just keep it the default size. Anyway.. nice run - I really think you could turn this into a highscores run if you have enough persistence...
Postby MiBeM » 2013.08.13 (12:31)
ska wrote:I really think you could turn this into a highscores run if you have enough persistence...
I think I've had enough of that map for now...
Also took 36-3, nothing fancy but it's a 0th which is always a big thing for me so I'll post it.
Speedruns and stuff
Postby ska » 2013.08.13 (15:02)
In the future, please denote which version of N and the mode you're using if applicable. i.e. N 1.4 36-3 sr. Nice run btw, but still 13 frames off the highscore 0th for the same level ;) Your speedrun would only be 4th on the 1.4 hs boards :D
Postby MiBeM » 2013.08.13 (15:42)
ska wrote:In the future, please denote which version of N and the mode you're using if applicable.
Oh, totally forgot, sorry about that. I'll be sure to mention it from now on :)
Speedruns and stuff
Postby EddyMataGallos » 2013.08.16 (14:24)
_danielr_ wrote:Wow jp, awesome run! Wasn't Eddy boasting about that not long ago? hahaha
Lol I wasn't boasting about it, I just pointed out I beat Msyjsm's run because that map is pretty famous among the community and that run had been very controversial back in its time, though you might not have heard about this since you are pretty new.
Retaken anyway, and it can be pulled up to 13700 with some cleaning on the ws's and some other parts.
jp27ace wrote:Squeezed 1 more frame out of 45-0, I was trying to boost myself off the top corners but I couldn't get it to work
Well done on 45-0 jp, I thought I had maxed it. Tied it, I wonder if it has to do with rocket detection. When jumping earlier (trying to touch the corners) the rocket might detect you differently, hence making it possible to run a little more after taking the switch, before jumping, and gaining that frame. Just a shitty theory though.
Gross
Postby jp27ace » 2013.08.16 (19:42)
Better than any theory I have :p
Taken 99-1 with an innovation, also innovated 74-3 but couldn't quite beat votestraw, but I'm pretty sure its quicker
Edit: Took 74-3
Postby EddyMataGallos » 2013.08.16 (20:15)
jp27ace wrote:Nice run Mibem, and yeah as ska said unless the drones somehow screw you over it looks like it could be used for high-scoring too.
Nice runs, taken ;)
jp27ace wrote:Taken 99-1 with an innovation, also innovated 74-3 but couldn't quite beat votestraw, but I'm pretty sure its quicker
Nice runs I see you finally took 74-3. Retook 99-1. Interestingly I also thought on innovating 74-3, but never made a worthy change haha.
Gross
Postby jp27ace » 2013.08.17 (07:44)
Nice to have you back and taking all my 0ths Eddy :p
Retaken 61-2 and tied 60-3, and also taken 83-2, I tried to focus on just getting a clean run and avoided doing any difficult corner jumps, so you could save a lot of time if you can be bothered.
Postby ska » 2013.08.17 (09:28)
don't wanna be a naggin nelly, but for fuck's sake, denote your goddam runs!
Sannnnnnnks
Postby vankusss » 2013.08.17 (11:10)
05-0 on v2.0
Gross
Postby jp27ace » 2013.08.17 (11:30)
vankusss wrote:05-0 on v2.0
Nice run van, I was going to try something like that at some point. Just wondering, is there a reason you don't do it on an earlier thwump?
ska wrote:don't wanna be a naggin nelly, but for fuck's sake, denote your goddam runs!
No. Taken a7-4 and b7-1
Also I'm now over 4.5m frames in v2.0
