N2High v3.0 - New version
Moderator: EddyMataGallos
Postby EddyMataGallos » 2013.07.30 (23:01)
N2High v3.0 - EddyMataGallos 2013
Newest version [10/Sept/2013] (Reuploaded 15/Feb/2020)
N2High v3.0.rar
Reuploaded!
(2.33 MiB) Downloaded 1139 times
Downloads pre-reupload: 552
Downloads from older versions: 251
Update info for v3.0: Since I had already implemented most functions you could probably come up with in the previous version, I really focused on enhancing the program this time. I have included several features and changes to improve the comprehensibility and readability of everything it generates. I also worked on the security of the program.
Of course I haven't forgotton about the rest, as you will see, there are several new functions I've implemented. Plus I have modified a bunch of old ones with new features that show more detailed information, or interesting stuff to know.
I highly recommend to update, as I have also fixed some errors from the last version, including 2 particular ones.
== Changelog ==
+ are big additions
* are changes/improvements/small additions
- are deletions/bug fixes
== v3.0 ==
:: Major update ::
+ Added score files encryption, and some other security measures. (Security feature).
+ Added a default name option, and a config menu.
+ Added Demo Analysis function with 2 different methods (for both online scores and local-stored demos).
+ Added Level Top-10 navigation function.
+ Added padding to all functions to improve readability.
+ Added Largest X-Y spreads function.
+ Added Smallest X-Y spreads function.
+ Added Player's Worst Enemies function (1st scores to).
+ Added ability to resume download if connection is lost.
* Improved score filename system (you can now save/load files with spaces).
* Improved downloading function once again (should be more resource saver and faster now).
* Improved outputted files style.
* Improved decimal notation.
* Improved Player's 0th Changes function (shows ex-tied 0ths, and improved tied 0ths).
* Improved Community TLS function (shows secs, and hours).
* Improved New 0th Report function (shows gained frames & secs, average, and how many players).
* Added date to all output files.
* Added [Possibly maxed] note to 7 functions.
* Added download percentage to window title.
* Added an exit option.
* Changed some output filenames.
- Fixed the redownloading issue (the names doubling), now the buffer is cleared.
- Program won't crash if downloading went wrong anymore (enhanced the error part).
- Fixed the Window title.
== v2.0 ==
:: Major update ::
+ Included a changelog.
+ Kickass interface!
+ Player's 0th Changes function.
+ Player's Top-10 Changes function.
+ Player's full stats function.
+ Player's all reports function.
+ 2 Players Comparison function.
+ 0th Rankings without ties function.
+ Tied 0th Rankings function.
+ X-Y spreads between 2 ranks function.
+ Community all main function at once function.
* Include ties on episode ownages.
* Plus5 and Plus1000 diffs on Player's Worst Scores.
* Mention already maxed levels in Player's Non Top-10 Scores list (to crush dreams ofc).
* Mention average tied 0th scores per level on 0th rankings.
* Put hyphens for tied players on all rankings.
* Only include players with over 25 scores on average rank rankings.
* Improved downloading function.
* Added a download bar.
* Loads of minor changes which I can't even list.
- Fixed the episode ownage function.
- The date doesn't end with a carriage return anymore.
- More minor fixes which probably came unnoticed by you.
== v1.0 ==
:: Initial release with a load of functions already ::
+ New 0ths Report function.
+ 0th Rankings function.
+ Top-10 Rankings function.
+ X-Rankings function.
+ Point Rankings function.
+ Average Rank Rankings function.
+ Maxed levels function.
+ Semi-maxed levels function.
+ Show a level's top-10 board function.
+ Community Total Level Score function.
+ Episode ownages function (without ties).
+ List all 0ths function.
+ List all scores function.
+ Largest 0th-1st spreads function.
+ Largest 0th-9th spreads function.
+ Smallest 0th-1st spreads function.
+ Smallest 0th-9th spreads function.
+ Player's 0th Scores function.
+ Player's Top-10 Scores function.
+ Player's Non Top-10 Scores function.
+ Player's X-Scores function.
+ Player's rank distribution function.
+ Player's worst scores function.
+ Ability to export scores.
+ Ability to load previosuly saved scores.
== What is N2High ==
- N2High is a software which aim is to download the current scores for N v2.0 and provide all kinds of statistics, rankings and reports, both individual and for the overall community.
- N2High is based on the popular NHigh, software developed by jg9000 for the same purpose as this, directed at N v1.4.
- N2High is currently in development. Of course, if you have ANY suggestion regarding the software, e.g. new functions, improvements, bugs, mistakes, etc., don't hesitate on telling me on the forums."
== Installation notes ==
- If you decide to use the compiled executable version, just run N2High.exe.
- Source code is included. If you wish to compile it by yourself, do it.
== Basic usage ==
- First of all, you will have to download the scores, which you will be able to export later, this might take several minutes. You can also load a previously exported file. (3 come included with the app).
- After that you will be taken to a Menu with several functions to choose, for both individual players or overall reports. There are several functions that compare the current scores with a previous file, so its a good idea to export the scores from time to time. Functions are pretty self explanatory, but if you don't understand any, just ask here.
- Most of the reports are exported to a .txt file to avoid too much mess in the command prompt.
== Current TO-DO List ==
Functions:
- Player largest/smallest X-Y spread.
- Player total 0th-1st spread. (community total score minus player).
- Player offline scores (to calculate TLS).
- Option to download all demos at the beggining.
- Overall Top-10 changes.
- Episode semi-ownages.
- Optimize average rank rankings function.
- When doing stats, return rank value taking ties into account.
- Find player's ID and viceversa. Find levels by inserting some conditions.
Program:
- Make a GUI.
- Improve downloading system (I currently depend on WGet, a GNU app).
- Userlevels support.
- Rankings doer (for the forums).
- Score files automatic browser.
- Configurable options: Ignore list, hs file autosave, bonus level nomenclature, number of retries when download fails, etc.
Want anything thats not here? Don't hesitate and tell me on the forums.
== Downloads ==
BEFORE DOWNLOADING: Most of the reports aren't printed on the command line, but exported in a .txt file on your N2High folder, in order to avoid spamming the command prompt.
Attachments not working? MEGA link right here:
[v3.0] https://mega.co.nz/#!8BZn0ZLL!ED_5VVynnu3HsnPcc-YRiwX-30NFMzasw3qNSCSjQOE
Postby ska » 2013.07.30 (23:42)
Awesome! The GUI looks like something out of the MS DOS era from 20 years ago, which made me chuckle. Thanks a lot for doing this. :)
Postby EddyMataGallos » 2013.07.30 (23:52)
Haha yeah, though I'd rather call it a UI, not many graphics there :P And you are welcome :D
I haven't implemented a real GUI yet because it was a tedious process which I thought could wait, after all, the functions are the same :P
I'll do it by all means when I get back from holidays though, I know a lot of people really prefer having a graphic interface and using the mouse.
Postby ska » 2013.07.30 (23:58)
Added a wikia page: http://n.wikia.com/wiki/N2High
EddyMataGallos wrote:Haha yeah, though I'd rather call it a UI, not many graphics there :P
True!
Also, yeah, I actually kind of dig the retro UI. Certainly no need to rush on releasing a proper GUI - getting the functions working properly is the most important thing right now :)
Edit: A few basic things (which I'm assuming you're working on adding) would be a default name, (can't copy and paste right now), and displaying a list of your top 10 scores, not just how many you have...
Postby EddyMataGallos » 2013.07.31 (00:40)
ska wrote:Added a wikia page: http://n.wikia.com/wiki/N2High
True!
Yeah Im definitely thinking on adding the default name, as for the Top-10 list though, thats already implemented!
Most of the functions will not display the content on the command line, because it could be too long (Top-10 Scores being an example). So the output is actually printed on a .txt file in your N2High folder Im sure :D Probably in something called "Ben Schultz Scores.txt" or something like that. Most of the rankings are also printed outside. (0th_Rankings.txt, EddyMataGallos X-Scores.txt, etc etc.).
Also, thanks a lot for the Wiki page!
Postby ska » 2013.07.31 (00:55)
Oh, I get it. Won't those text files get overwritten though with each download? (I assume that wouldn't happen, but I haven't checked.)
Postby EddyMataGallos » 2013.07.31 (00:59)
ska wrote:Oh, I get it. Won't those text files get overwritten though with each download? (I assume that wouldn't happen, but I haven't checked.)
They will if you download the same thing twice, but the names are all different. e.g. If you download your scores again you will overwrite that file, but not if you download mine, or if you do a Points Rankings, or whatever. Everything different is saved in different files. If you think about it, kinda like NHigh.
The reason I did this file thingy is because the command line has a limit of lines to be printed until it starts erasing on the top, plus it has better readability through a file, plus this way you can copy and modify it, plus a long output can break the command line :P
Postby ska » 2013.07.31 (06:07)
I'm a little bit confused (my fault probably). I'm guessing the text files don't really matter if you have the .hs2 file, since they can be called upon by loading a saved .hs2 file anyway, Right? It's just a way of making the data easier to view and manipulate? (e.g. copy onto the forums) because like you said, it is problematic to show too many lines of data using the program.
Postby EddyMataGallos » 2013.07.31 (15:00)
ska wrote:I'm a little bit confused (my fault probably). I'm guessing the text files don't really matter if you have the .hs2 file, since they can be called upon by loading a saved .hs2 file anyway, Right? It's just a way of making the data easier to view and manipulate? (e.g. copy onto the forums) because like you said, it is problematic to show too many lines of data using the program.
Yeah exactly, those .txt files are just for you, for the user. The .hs2 contains everything and can generate them.
Gross
Postby jp27ace » 2013.08.01 (20:04)
Awesome job with this Eddy, still a lot of features to add but looking great so far.
I've been thinking of learning C++ for a while now, so I might have a look and see if I can help with that
to-do list when I get a bit more free time, what devkit did you use for this?
I'm liking the worst scores function, it gives me something to aim for (damn you a8-4)
Oh and enjoy your holiday :)
Postby EddyMataGallos » 2013.08.15 (21:41)
jp27ace wrote:Awesome job with this Eddy, still a lot of features to add but looking great so far.
Thanks :D Thats cool, you are more than welcome to contribute when you want. Now that Im back, I think Ill start with the GUI, and add the rest of the functions later. *hah
I use Dev-C++. I have migrated to Code::Blocks.
Postby EddyMataGallos » 2013.08.23 (01:09)
MAJOR UPDATE GUYS - v2.0
Newest version [23/Aug/2013]
Download on main post!
Update info: With this major update, I finished including all NHigh functions, plus a lot more completely new. Most of the ones from NHigh are actually enhanced or changed to show as much information as possible with every function.
I have severely changed the interface as well, which is still command-based (because the GUI is a pain in the ass) but I hope you find it way more pleasant, as I do. The source code has indeed doubled in size. All this altogether, is the reason I've decided to go up straight to v2.0, skipping all tenths.
I highly recommend to update, as I also fixed several things.
== Changelog ==
+ are additions
== v2.0 ==
:: Major update ::
== v1.0 ==
Postby ska » 2013.09.04 (09:35)
ha ha ha. "hability"
Seriously though, thanks very much for this. I've almost finished downloading all the scores and will do a major 2.0 update on the rankings thread. Hasta luego, amigo
Edit: I sometimes find it buggy where it won't respond to me pressing numbers...
Postby EddyMataGallos » 2013.09.04 (15:07)
Oh damn I got tricked by the spanish word (habilidad) hah. Fixed :P And you are welcome, Im expecting the next version to be releaseable by next week with some interesting additions/changes. I migrated from DevC++ to Code::Blocks but that won't be noticeable.
Postby EddyMataGallos » 2013.09.10 (21:42)
HUGE UPDATE - v3.0
Newest version is v3.0 [10/Sept/2013]
== Changelog ==
+ are big additions
== v3.0 ==
:: Major update ::
== v2.0 ==
:: Major update ::
Postby ska » 2013.09.11 (02:25)
This is a real game changer. You've got my vote for fan-app of the year.
Edit/Note to Eddy: When exporting a "no ties" 0th rankings, even though your program says "0th rankings (no ties).txt" the file I got was just "0th rankings.txt" which replaced my existing file. A very minor thing, but nevertheless something you might want to fix on your next version. Cheers!
Gross
Postby jp27ace » 2013.09.11 (19:15)
Awesome, I love the new default player name option. Back to 600 top 10s again, this makes it so much easier to find my worst runs.
I don't really see why it was necessary to encrypt the score files, but it still lets me open the old ones so its not a problem.
Postby EddyMataGallos » 2013.09.11 (20:26)
ska wrote:This is a real game changer. You've got my vote for fan-app of the year.
Haha thanks though I don't think that exists anymore :P And whops you are right about that mistake, that will be corrected by next release.
jp27ace wrote:Awesome, I love the new default player name option. Back to 600 top 10s again, this makes it so much easier to find my worst runs.
Thanks :P As for the encryption, I know it might seem somehow useless, but I didn't want the score files to be so easily editable (you can just open the old ones and modify anything with notepad, which is not useful for anyone personally, but I wouldn't like fake score files to be floating around in some years time :P).
Oh and of course I added a mark to the new ones, so that way I can also detect and load old files ;)
Gross
Postby jp27ace » 2013.09.15 (14:38)
EddyMataGallos wrote:As for the encryption, I know it might seem somehow useless, but I didn't want the score files to be so easily editable (you can just open the old ones and modify anything with notepad, which is not useful for anyone personally, but I wouldn't like fake score files to be floating around in some years time :P).
You can still edit an old file, load it, and then save it to encrypt it, but I suppose its better than nothing :p
Postby EddyMataGallos » 2013.09.15 (14:51)
Yep but there was no way to prevent that, at least its not so straightforward now :P probably nobody would have any interest on editing it so it should be enough.
NUMA Profile: http://www.nmaps.net/user/thrasher26
Postby thrasher26 » 2014.03.01 (03:54)
Coool :D
thanks Eddy.
Postby EddyMataGallos » 2014.11.06 (16:41)
The program has been reuploaded! Sorry for not noticing earlier, I forgot the forums had lost its attachments. You can download it again now. If it happens to happen again, just ask here ;)
By the way, last year I started on a GUI version. I might get to work on it again now that hackers have been deleted and the program works fine again. I'll try to keep this updated.
Postby ska » 2014.11.22 (08:56)
Great stuff as always... By the way, any chance of a GUI any time soon? :P
P.S. It doesn't seem to work anymore with any name that has an underscore, including my own, obviously. I'm not sure why, but I thought it might be the issue; so I tried johnny_faneca, and it was the same problem. However, trib4lmaniac (for instance) works fine. Perhaps there is a problem in your coding that is messed up by underscores?
Postby EddyMataGallos » 2014.11.22 (23:43)
ska wrote:Great stuff as always... By the way, any chance of a GUI any time soon? :P
Thanks for the warning man, I'll give it a check. However, I remind you your nick in N v2.0 doesn't have an underscore, if I remember properly. Its "Ben Schultz". And johnny hasn't got any run in 2.0 :P
Postby ska » 2014.11.23 (06:49)
fuck... I'm an idiot... I thought it was for 1.4.
*Goes to corner to cry*
