Inertia field? (DS)
Do you own a copy of Metanet Software's console and handheld title? If so, talk about it here!
Postby Yoshimo » 2008.11.09 (13:12)
That's not ineria. Inertia would make you fly through it at the exact momentum you ent4ered it, not slow you down. What's going on?
Postby rambo5252 » 2008.11.09 (15:03)
wait whaaaaa?
Thanks Toasters for the siggy
Other sigs
ø„¸¨"°º¤ø„¸¸„ø¤º°" ¨¸„ø¤º°"¨
¨"°º¤ø„¸RAMBO ¸„ø¤º°"¨
¸„ø¤º°"¨¸„ø¤º°"¨¨"°º ¤ø„¸¨"°
Lords a-Leaping
Postby Pengitty » 2008.11.15 (11:12)
Inertia field could simply mean it cancels out inertia. What would really be fun though is a gravity inverting switch. That would rock.
If you give a man a match, he'll be warm for a minute, but if you set him on fire he'll be warm for the rest of his life.
Postby alex » 2009.01.04 (05:08)
it would also be cool if there was a kind that could slow down enemies and their weapons, then make someone panic about thinking they're going to die while running past a hidden one :D
Postby Exüberance » 2009.01.10 (03:41)
Where is it called an inertia drone? It's called a Force Field Drone in XBox360 version at least is it not?
Also, how is that incorrect? An object [at rest/in motion] will stay [at rest/in motion] unless acted on by an external force. The drone provides the outside force. I see no problem?
Nmaps.netNmaps.net
Bacardi
Postby Meta Ing » 2009.01.10 (04:25)
Exüberance wrote:Where is it called an inertia drone? It's called a Force Field Drone in XBox360 version at least is it not?
The thing BionicCryonic is talking about isn't a drone, it's a blue, stationary 'field'. (that looks kind of like water.)
Quotes (Click to open):
Kablizzy: Click
TOO BAD!
Postby Exüberance » 2009.01.10 (04:58)
O____O
Did DS get different enemies or something?
Nmaps.netNmaps.net
Bacardi
Postby Meta Ing » 2009.01.10 (05:33)
Yeah. There are no rotating laser drones, force field drones, or electric doors. There are timed mines and inertia fields. No new moving enemies either, unless you count the ability to put floorguards on the ceiling as a new enemy.
Kablizzy: Click
TOO BAD!
Postby alex » 2009.01.11 (19:29)
The drone and field are completely different things. the field is an oblect that only slows you down when you're in it. The drone moves and pushes you away when you get too close
