Post a Run!
Postby golf » 2013.01.20 (04:51)
Improved my 00-2 run (fastest without using the middle thwump) by 7 frames since I was close to being knocked off the board.
Postby ska » 2013.01.20 (05:24)
EddyMataGallos wrote:
Taken ;) And to keep the ball rolling (there should be a ball here) 225583 sr.
Yeah, you really got a tight run on my map there :D
As for 225583 sr, looks like you've been challenged! :O
Edit: 90262 hs to keep the ball rolling yet again. PS. Do you think something like this:Image would be possible?
Postby macrohenry » 2013.01.20 (14:41)
Looks like danielr might be back. He also took 17-1 sr and ep02 sr lately.
I think it's tough to get the right angle for the corner kick. It could be possible with a heightless corner jump.
Postby ska » 2013.01.21 (03:00)
macrohenry wrote:...It could be possible with a heightless corner jump.
yeah, that's what I was thinking.. or maybe a shallow jump off, enough to 'bend' around and through the mines.. if that makes sense..
Edit: took 105-1 highscore
Postby zoasBE » 2013.01.22 (14:59)
http://www.nmaps.net/225662 HS
The run in fact it's not really impressive, it's more like just an advertise due the map.
I think some highscorers might like it, ska you might like it. :P
I'm challenging you guys, you can get something above 50.000?
Something even more impressive?
just as friends as enemies
even fewer friends
Postby Harvey » 2013.01.22 (21:41)
I would but it looks like Van's bet us to it. He's over 55 atm...
Postby zoasBE » 2013.01.22 (22:50)
Harvey wrote:I would but it looks like Van's bet us to it. He's over 55 atm...
At least, make your attempt no? ;)
btw, awesome cool run van, and seeing it, I can say that there are still some frames left.
even fewer friends
Postby ska » 2013.01.23 (07:34)
225695 hs
Postby MiBeM » 2013.01.26 (09:18)
Episode 26 sr, not a 0th nor anything special really, but thought I'd post it just to let everyone know that I haven't quit playing N :)
a.k.a. MoleTrooper/Molenator
Speedruns and stuff
Postby macrohenry » 2013.01.27 (19:42)
225826 sr
Postby ska » 2013.01.28 (14:15)
macrohenry wrote:225826 sr
nice!
222515 hs beating Ed by over a second with a route change.
95-1 sr 0th
222569 hs
Edit: 225907 hs
Edit dos: 11925 hs
Edit tres: 49331 hs
cuatro: 225650 hs
Postby Kool » 2013.02.03 (21:52)
53-4 sr, was trying out different route ideas with dan for a while, ultimately if you trigger the top right locked door switch too soon you end up waiting on the drone for a slower frame rate (watch danielr's run) unless you beat the drone when it reaches the bottom (which ended up being insanely difficult without a nearly perfect run) so I settled with slowing my run down so I could slip past the drone at the last second.
Edit: 53-1 taken as well, sorry kryxy ole' pal
Postby ska » 2013.02.04 (08:01)
116048 hs
Postby vankusss » 2013.02.04 (21:18)
wtf check this out
Postby macrohenry » 2013.02.04 (21:26)
What did you do there? :P
Postby Kool » 2013.02.05 (00:42)
So I just wasted 10 minutes of my life trying to figure out what the hell van was trying to show us. I guess the mechanics of jumping from a 3-tile to a wj for 5,000 frames is astounding to him.
50-0 sr as well, took a healthy minute xela's run there is extremely smooth. Trying to rack up some 0ths in the 50's column
Edit: A cool fact, I now have 0th in every column starter in the original 00-99 besides 00-0 (thanks raif :P) 20-0 & 90-0 I'm tied for 0th and I'm 99% positive 20-0 is not improvable.
Postby TheRealOne » 2013.02.05 (01:05)
Kool wrote:So I just wasted 10 minutes of my life trying to figure out what the hell van was trying to show us. I guess the mechanics of jumping from a 3-tile to a wj for 5,000 frames is astounding to him.
Killer runs. 53-1 is sharp. Can someone get the WS on the BB to take it?
Postby vankusss » 2013.02.05 (19:56)
GOAL ACCOMPLISHED HAHAHA
btw that's what I do when I'm on skype with someone...
Postby ska » 2013.02.06 (02:48)
I'm not going to give van the satisfaction that I watched the entire dem--- awww crap.
smashed 210183 hs.
Postby Kool » 2013.02.08 (04:06)
27-2, didn't think I'd get 2 frames out of that. I was trying to figure out an innov involving going right and cj'ing but it ended up always being slower, also I thought xela's route might have been faster, guess not.
Postby TheRealOne » 2013.02.08 (14:18)
Kool wrote:27-2, didn't think I'd get 2 frames out of that. I was trying to figure out an innov involving going right and cj'ing but it ended up always being slower, also I thought xela's route might have been faster, guess not.
Cleanliness can beat out innovation. Super clean run.
If you dare blowing a great run try and hit your head on the corner of the 1 tile with the LP above the door for a few extra frames.
Postby Kool » 2013.02.08 (23:31)
thanks man, and yea I was thinking of the cornerpush but the few times i tried it I always hit the lp, good idea tho.
Also 27-4 taken, did kryX's(ANGERFIST) hs start and his part at the exit switch, was trying to get a wj there but I only got it half of the time. Also I screwed up on the fall I guarantee it's possible to beat the thwump I just didn't risk it. Also 1 frame away on 27-3 hopefully I'll take it and make an edit soon
Edit: Improved 27-4 by 7 frames, screwed up the 2nd part of the top half but made out faster because I didn't spend time on top of the thwump, I guess it's worth it to go slower
Edit2: Improved again by 3 frames, I'm done with the edits and the level til someone takes it, still couldn't beat the thwump :/
Postby ska » 2013.02.09 (13:04)
can you please show me a screenshot diagram sowing exactly which one you mean, (including the approximate ninja trajectory?) thx! :D
Postby EddyMataGallos » 2013.02.09 (22:40)
Hes talking about this one, though I doubt its worth the high risk.
Kool, you might, however, take a shot at 27-2 hs. Raif proved by MBD that LFT's run and mine are improvable by at least one frame.
Postby ska » 2013.02.10 (09:46)
I figured that was it, just wanted confirmation. thanks ed.
