Bounty Hunters: Eddy is the champion!
EDIT: 21 done also. 300 points.
Edit: Improved ;)
Also, you miscrossed nº6, its not done ;) And you can, however, cross nº 15.
Btw, bounties 19 and 25 are the same, but with different prizes o.O
Bounty nº29 done with new route, and 18 as well, by a good amount haha.
Thanks, I was in a rush when I did that. I'll go through them all now. Standby for an edit.EddyMataGallos wrote:Argh I forgot about the spect map. What about a recount of the points ska?
Edits:
1) ari22hoops: You only have 200 points, not 400.
2) Fixed 19 and 25
3) Fixed bounty #6
4) 55596 hs has been extended to the 30th of October!
222857 sub 130 frames Speedrun 20ari22hoops wrote:I have 235 now by my reckoning now that you extended the deadline for 55596 and removed 25. Am I missing something?ska wrote: Edits:
2) Fixed 19 and 25
3) Fixed bounty #6
219302 213.400 Highscore 30
105974 sub 393 frames Speedrun 25
87920 148.000 Highscore 10
157855 AGD Highscore 20
222933 122.000 Highscore 30
113072 sub 286 Speedrun 65
Equals 200. What am I missing?
I also completed 19 for 35 points. That appears to be the difference.ska wrote:222857 sub 130 frames Speedrun 20ari22hoops wrote:I have 235 now by my reckoning now that you extended the deadline for 55596 and removed 25. Am I missing something?ska wrote: Edits:
2) Fixed 19 and 25
3) Fixed bounty #6
0) 13661 hs: 50 points
1) 222857 sr: 20 points
2) 219302 hs: 30 points
4) 222856 hs: 45 points
5) 133-3 hs: 75 points
7) 105974 sr: 25 points
8) 56973 hs: 35 points
9) S87920 hs: 10 points
13) 222855 hs: 30 points
14) episode 46 hs: 100 points
15) 159273 hs: 60 points
16) 157855 hs: 20 points
17) 139892 hs: 80 points
18) 222933 hs: 30 points
20) 38815 sr: 25 points
21) 2113072 sr: 65 points
29) 153351: 80 points
Total: 780 points
My scores now should be:
9) 87920 hs 10 points
12) 222884 hs: 15 points
19) 222923 hs: 35 points
21) 113072 sr: 65 points
Total: 305 points
- Semimember
- NUMA Profile: http://nmaps.net/user/Harveyy
EDITS:
1 - 20 Points
2 - 30 Points
Also since it's 27th in NReality time does that mean I get points for 223043 sr as well? If so 380 points.
I will allow people to set their own bounties .... The run must be your own run
Whaaaaat?you don't have to submit a demo until the deadline ... The run you submit must be
Sorry, I was a bit drunk when I wrote this, so I will clarify further.Raif wrote:I don't understand. Are you allowed to choose runs that have been made before this competition started? Or must the winning run be made after the bounty is submitted?I will allow people to set their own bounties .... The run must be your own runWhaaaaat?you don't have to submit a demo until the deadline ... The run you submit must be
The levels/runs you choose can be from any time, but must be submitted on NReality, either already, or before the deadline which is 4 days after the duel is initiated. E.g. if you think you have an awesome route, you can hold off submitting it until later, but it must be before the deadline.
I have 2 questions, I supose we'll only have a duel at a time right? And also, is there the point limit for a duel?
Btw, 78-1 sr taken, duel won, sorry Raif. Thats 150 more points for me ;) (This amount was crazy dude, I'd suggest a max of 100, if you guys agree).
Good point. From now on, I'm capping the duel amount at 100.EddyMataGallos wrote:Lol :P Ill try to do my best, specially in this exams week o.O
P.S. raif can still try to take the 0th back if he wishes/can.
Then, we must trust on the honor code (do not submit a few minutes before the deadline!)
