Bounty Hunters: Eddy is the champion!
Postby ari22hoops » 2012.10.22 (01:50)
25 done. 235 points.
EDIT: 21 done also. 300 points.
Postby EddyMataGallos » 2012.10.22 (09:46)
Ah thanks for the clarification ska, so I will improve it later then.
Edit: Improved ;)
Postby ari22hoops » 2012.10.24 (14:48)
22 done. 400 points.
Postby macrohenry » 2012.10.24 (16:00)
21) done.
Postby EddyMataGallos » 2012.10.24 (17:54)
Argh I forgot about the spect map. What about a recount of the points ska?
Also, you miscrossed nº6, its not done ;) And you can, however, cross nº 15.
Btw, bounties 19 and 25 are the same, but with different prizes o.O
Bounty nº29 done with new route, and 18 as well, by a good amount haha.
Postby ska » 2012.10.25 (02:37)
EddyMataGallos wrote:Argh I forgot about the spect map. What about a recount of the points ska?
Thanks, I was in a rush when I did that. I'll go through them all now. Standby for an edit.
Edits:
1) ari22hoops: You only have 200 points, not 400.
2) Fixed 19 and 25
3) Fixed bounty #6
4) 55596 hs has been extended to the 30th of October!
Postby ari22hoops » 2012.10.25 (05:31)
ska wrote: Edits:
2) Fixed 19 and 25
3) Fixed bounty #6
I have 235 now by my reckoning now that you extended the deadline for 55596 and removed 25. Am I missing something?
Postby ska » 2012.10.25 (05:43)
ari22hoops wrote:
ska wrote: Edits:
2) Fixed 19 and 25
3) Fixed bounty #6
222857 sub 130 frames Speedrun 20
219302 213.400 Highscore 30
105974 sub 393 frames Speedrun 25
87920 148.000 Highscore 10
157855 AGD Highscore 20
222933 122.000 Highscore 30
113072 sub 286 Speedrun 65
Equals 200. What am I missing?
Postby ari22hoops » 2012.10.25 (06:08)
ska wrote:
ari22hoops wrote:
ska wrote: Edits:
2) Fixed 19 and 25
3) Fixed bounty #6
I also completed 19 for 35 points. That appears to be the difference.
Postby ska » 2012.10.25 (11:57)
OK, thanks, scores have been amended. Please let me know if anyone else has any discrepancies.
Postby EddyMataGallos » 2012.10.25 (13:39)
A BLUR flag! Awesome, thanks a lot for that ska :D Its really cool, I really like it ;)
Postby Raif » 2012.10.25 (14:48)
Why does my score seem to have decreased? I remember it being like 180. o_O
Postby EddyMataGallos » 2012.10.25 (15:49)
14) Done ;) Btw I think there was a miscalculation with my scores, I should have had 680, plus 100 now.
0)  13661 hs: 50 points
1) 222857 sr: 20 points
2) 219302 hs: 30 points
4) 222856 hs: 45 points
5) 133-3 hs: 75 points
7) 105974 sr: 25 points
8) 56973 hs: 35 points
9) S87920 hs: 10 points
13) 222855 hs: 30 points
14) episode 46 hs: 100 points
15) 159273 hs: 60 points
16) 157855 hs: 20 points
17) 139892 hs: 80 points
18) 222933 hs: 30 points
20) 38815 sr: 25 points
21) 2113072 sr: 65 points
29) 153351: 80 points
Total: 780 points
Postby Raif » 2012.10.25 (17:34)
Did 19, 20 and 21.
My scores now should be:
9) 87920 hs 10 points
12) 222884 hs: 15 points
19) 222923 hs: 35 points
21) 113072 sr: 65 points
Total: 305 points
Also currently leading on 223043 sr.
NUMA Profile: http://nmaps.net/user/Harveyy
Postby Harveyy » 2012.10.25 (22:05)
Feel like I've got to try a bit harder now you've made a flag for me :P Thanks though! I will give some other levels a go.
EDITS:
1 - 20 Points
2 - 30 Points
Found N March 2012.
Postby Raif » 2012.10.27 (06:57)
Did 30. Now 330 points.
Also since it's 27th in NReality time does that mean I get points for 223043 sr as well? If so 380 points.
Postby ska » 2012.10.27 (13:14)
OK, here's the twist. After being 2 weeks in, and Eddy is looming near the 1000 point mark, I will allow people to set their own bounties (by PM) within certain guidelines. The run must be your own run and whatever amount of points you set, you must have at least that amount. The map can be your own map, and you don't have to submit a demo until the deadline for that map is reached. The run you submit must be of less frames if in speedrun, or of higher score if in highscore mode. The run can be already submitted, or you can hold of on submitting; either choice is fine. If you lose the duel, you lose the amount of points you duelled with and Eddy (or whoever is 0th) gets those points. If, however, Eddy cannot get the score mentioned in the bounty quest (a tie counts as a win for Eddy), the dueller will take away the said amount of points from Eddy's stock pile. (So only pick runs you feel are your best) Also, the score limit has been increased from 1000 to 1500. GOOD LUCK and if you don't understand any of this post, please post, and I'll try to answer your query...
Postby Raif » 2012.10.28 (03:43)
I don't understand. Are you allowed to choose runs that have been made before this competition started? Or must the winning run be made after the bounty is submitted?
I will allow people to set their own bounties .... The run must be your own run
you don't have to submit a demo until the deadline ... The run you submit must be
Whaaaaat?
Postby ska » 2012.10.28 (04:56)
Raif wrote:I don't understand. Are you allowed to choose runs that have been made before this competition started? Or must the winning run be made after the bounty is submitted?
Whaaaaat?
Sorry, I was a bit drunk when I wrote this, so I will clarify further.
The levels/runs you choose can be from any time, but must be submitted on NReality, either already, or before the deadline which is 4 days after the duel is initiated. E.g. if you think you have an awesome route, you can hold off submitting it until later, but it must be before the deadline.
Postby Raif » 2012.10.28 (06:51)
Aah, ok.
Postby EddyMataGallos » 2012.10.28 (16:35)
Lol :P Ill try to do my best, specially in this exams week o.O
I have 2 questions, I supose we'll only have a duel at a time right? And also, is there the point limit for a duel?
Btw, 78-1 sr taken, duel won, sorry Raif. Thats 150 more points for me ;) (This amount was crazy dude, I'd suggest a max of 100, if you guys agree).
Postby macrohenry » 2012.10.28 (17:38)
30) done.
Postby ska » 2012.10.29 (00:23)
EddyMataGallos wrote:Lol :P Ill try to do my best, specially in this exams week o.O
Good point. From now on, I'm capping the duel amount at 100.
P.S. raif can still try to take the 0th back if he wishes/can.
Postby EddyMataGallos » 2012.10.29 (00:37)
Oh, I thought this was like a bounty, that once you get the score you win. So, I guess the 0th place after the deadline will earn the points right?
Then, we must trust on the honor code (do not submit a few minutes before the deadline!)
Postby Raif » 2012.10.29 (03:52)
Nice run Eddy; knew I shouldn't have suggested that much of points.
