Episode Ownage Bug?
- Alive
Can any of you guys explain why this happened? If so, can it be reverted?
I don't know if this is your problem though, the question is, were those scores done with an old version?
- Alive
I've had NReality v6g2 since November last year. I obtained all of these runs on this version. Sure, there's a several-month difference between the oldest and newest 0th, but all of them were done on the same version of the game. Also, I have quite a few 0ths from an older version, v6d4. Those were not converted to '.*swipenet', so I really am quite confused. Any ideas?
I'm afraid I don't know why that's happening then o.O I'm sorry. I would send a PM to Unreality to see whats going on, but I haven't seen him here for months.
I was using 6c2 back then in mid-2009, but the same thing happens on 6d4 or in your case 6g2. As the thread explains in detail, all your recovered scores marked as v0 will submit themselves onto the scoreboards when you next hit the submit button. And as the wise man Unreality himself said, "arr .. um... I don't know :p I'm sorry I haven't polished the score recovering function (at all) ;p". If he has no clue, we have no hope of understanding, and since this problem has been around for three years, the chance of it being fixed in the near future with Unreality not around are about equal to the chances of plunge-for-distance making a comeback as an Olympic sport.
I would guess there isn't much you can do, other than to try and improve your own scores before your next submission. It's not just you. Vankusss has about 10 or so metanet 0ths from 2010 that are now listed as dot-star 0th on LegitMode for probably this exact reason. Also, don't use Norton.
- Alive
I did use the score recovery feature...damnit. Does Unreality have direct control over the scores? I don't think I can improve all of these runs :/
Never used Norton and I sure don't plan to :)
Yeah he has direct control over the score database. If you're desperate, your best option is to hope he responds to your PMs and removes the dot. However if you do hit the submit button again, the same glitch would happen; so as a cautionary measure you should overwrite the v0 scores on your side by switching LegitMode on and doing a simple completion of ep103 on 6g2 (the thread I linked explains this). And don't bother with score recovery.
