Metanet 0ths Thread
How many votes will this poll get?
1
0
No votes
2
0
No votes
3
0
No votes
4
0
No votes
5
1
13%
6
3
38%
7
1
13%
8
1
13%
9
0
No votes
10
0
No votes
11
0
No votes
12
1
13%
13
0
No votes
14
0
No votes
15
0
No votes
16
0
No votes
17
1
13%
18
0
No votes
19
0
No votes
20
0
No votes
Total votes: 8
Postby Raif » 2012.04.29 (01:36)
TheRealOne wrote:Nice Raif. That ending has always baffled me. How many times did you die there?
The ending was easier than I expected. I think the position of the E-tile above the gap + the speed at which you are falling makes it very easy to hit the corner in some form or other.
Postby ska » 2012.05.01 (18:24)
Took 34-1 back from xaelar..
A lot of history here with this level. Finally, after playing slavishly for a few hours, I managed to take back this level by a solitary, satisfying frame after making the route innovation in the first place - who knows when!? (early 2011 at a guess - How long has LFT been used, xaelar?)... Anyway, I knew there was at least a frame left after getting a .600 agd-1 run. This really is a hellishly difficult level to 0th as there are 3 major obstacles in increasing difficulty one must overcome to get a good score, with the 3rd obstacle, (the drone dodge) being the clincher, since everything prior is really just a warm-up and this obstacle serves to be a bottleneck using the current route. I'd love to see this one MBD'd, looking at you raif (as kryx's ANGERFIST run uses a faster start - although doesn't really serve much purpose in the current route, might be able to be used in a MBD run to beat the drones.)
Phew. That's enough N for a while!
Postby vankusss » 2012.05.01 (18:55)
ska wrote:Took 34-1 back from xaelar..
79-4, 88-4, 96-4 and such have all quite hard increasing difficulty. You just need a lot of tries to pull everything off.
Postby ska » 2012.05.01 (19:03)
vankusss wrote: 79-4, 88-4, 96-4 and such have all quite hard increasing difficulty. You just need a lot of tries to pull everything off.
no doubt!
Postby TheRealOne » 2012.05.01 (20:03)
N is a game that exists in a great harmony of copy-cats and innovators. On any give map someone finds the fastest route and then inevitably people copy that run and out do the originator. Then someone comes up with something more ingenius. These days I think we have exhausted all most all of the "faster and easier" innovations, so if someone wants to take 0th they either need to snipe out frames or add in harder and harder innovations.
We went through the age of the double jump and 1&2-tile triple jump earlier, Then we went through the age of the corner jump and the age of the in between mines wall jump, Then the age of the backwards bounce block wall jump... There is always progression. I think the next big step may be cleaning up maps that could use 4-tile triple jumps. Those are huge time savers, but will destroy a run if failed.
Postby ska » 2012.05.02 (07:34)
Yeah, by a lot of history, I simply meant, a lot of different routes that have been built upon since this level was first introduced.
Relevant quote: "If I have seen further it is by standing on the shoulders of giants" - Isaac Newton
Postby Raif » 2012.05.02 (11:37)
14-0 from Eddy. Still quite a bit from improvable.
Postby TheRealOne » 2012.05.02 (14:25)
Raif wrote:14-0 from Eddy. Still quite a bit from improvable.
Definitely improvable. There is a lot of back and forth between you and Eddy on that map. You are way ahead at the very start. Your slide and first jump were prefect. That save a very large chunk of time, but you hesitation at the third switch put you behind Eddy, then you pulled ahead again at the top, then stayed ahead, but lost a frame or too clipping the corner in the center after the triple. Then finally you wall jumping doing to the exit was slower, but you lead you built in the top right carried you to the end. A seemingly simple map, but very hard to get everything right for the balls to the wall run. Especially the sliding turn-a-rounds.
Postby Raif » 2012.05.02 (14:31)
You have to slow down a bit at the third switch, otherwise this happens:
Trying to improve..
Postby EddyMataGallos » 2012.05.02 (20:04)
Thats exactly the reason I dont do the first triple, I know it saves, but I always die on that drone, so I think its better not to do it and then just go faster (but not much or you'll die on that drone again). Doing it or not doing it doesnt affect the run, since we will then tie in that later part, the drone is a speed-limit.
Btw retook it, 112 possible.
Oh also retook 36-3, i dont know why, but I kept fucking up the ending. Funny how I beat Raif by jumping at the very end tunnel haha, we were tied until then (i think) :P
Postby Raif » 2012.05.03 (00:07)
Nice runs, Eddy. I'll try to take them back when I have time.
And no, you were faster right from the start of the tunnel, before you start jumping.
Postby ska » 2012.05.03 (05:15)
Great runs, Ed.
Postby EddyMataGallos » 2012.05.03 (13:05)
Oh sorry I misinterpreted the demo comparison them :S
Thanks guys :)
Postby Kool » 2012.05.05 (17:27)
90-0 by a frame over kryX, annnndddddd another cheated 0th bites the dust
:D
Postby ska » 2012.05.05 (18:02)
Kool wrote:90-0 by a frame over kryX, annnndddddd another cheated 0th bites the dust
:D
That was so sick that I don't even care it puts you a 0th further from me :D
Postby TheRealOne » 2012.05.05 (18:33)
:D
Perfection at its best. Absolutely sick run.
Postby Kool » 2012.05.05 (19:33)
d'awww shucks :3
Edit: Also will you have time for rankings anytime soon real? loved to see em' man
Postby EddyMataGallos » 2012.05.05 (19:58)
Rofl nice kool :D
Postby eru_bahagon » 2012.05.06 (23:05)
Nice 90-0 Kool. =)
@ Eddy : nice 14-0, and I enjoyed your 174-2 too (well, xaelar innov' I guess, so he did innovate something ?)
Yeah, I discovered that today, browsing random level, and was like : "fuck that level"^^
Postby EddyMataGallos » 2012.05.06 (23:37)
haha thanks, he probably created the full route himself :P I was amazed at the enormous difference between 0th and 1st (40 secs lol)
Postby ska » 2012.05.07 (03:34)
EddyMataGallos wrote:haha thanks, he probably created the full route himself :P I was amazed at the enormous difference between 0th and 1st (40 secs lol)
The 5th sign that the apocalypse is nigh.
Postby EddyMataGallos » 2012.05.07 (22:17)
Took 71-0 so broke last ownage.
Postby TheRealOne » 2012.05.07 (23:45)
EddyMataGallos wrote:Took 71-0 so broke last ownage.
Well done. A very clean run. Now that you have broken every last ownage, why not take one for your self?
Postby EddyMataGallos » 2012.05.12 (00:40)
Thanks I've been thinking on doing it. I may aim at it as my next goal.
REPOST: Took 99-4 from TWA, as well as 21-3 and 21-4, making EP21 my first ownage :D
Postby golf » 2012.05.12 (00:57)
That's the Eddy we've all been missing. Well done and congrats on the ownage!
Users browsing this forum: Google Adsense [Bot] and 34 guests
