Fairly obvious this one, but on 62-3 it's possible to draw the seeker drone up when dropping down to the middle-right gold using eru's route.
This allows you to CJ up to the gold above the exit switch (which I spectacularly fail to do in the demo).
Got a bit further in this demo, the CJ allows you to save a load of time in the middle. Once again a ridiculous fail afterwards though.
nice job on the 0th.glib_jase wrote:Fairly obvious this one, but on 62-3 it's possible to draw the seeker drone up when dropping down to the middle-right gold using eru's route.
Here, Here. I knew it was only a matter of time before you were able to lay down a clean run with a nice CJ. Well done sir. Quite a fast run. Now who is going to go for the the final RCJ? =P
I think it might be a little faster...
- Not actually an admin
You mean 40-0ska wrote:40-4
oops, yeah haha. I was like: "don't write 40-4. don't write 40-4. don't write 40-4." so of course that's what I do write.Paradox-Dragon wrote:You mean 40-0ska wrote:40-4
Yeah it must be, I managed to get 2nd (sorry!) with a fairly rough run.ska wrote:40-0
MY ANGER IS NOW MORE THAN YOU COULD EVER POSSIBLY KNOW.glib_jase wrote:Yeah it must be, I managed to get 2nd (sorry!) with a fairly rough run.ska wrote:40-0
If you watch with the demo feature on van's run you had 0th up until the very last jump. you jumped too early so you didn't get the push from the 1 tile and van past you. So that route is certainly faster.glib_jase wrote:Yeah it must be, I managed to get 2nd (sorry!) with a fairly rough run.ska wrote:40-0
- RoboBarber
Thx for 40-0.
My ending is .2 faster, at least. (:p van)
And my beginning too, if you don't touch the wall (I got a shitty one). Because you'll start falling earlier, thus you'll have more speed.
PS : Pablo228 got a 162 route. Not completely sure if it's possible, but probably. I'm trying.
Starting with van's route, you try to collect all the gold in one jump less, i.e. starting by collecting 2 by 2 from the top. I can get the first jumps right.
That looks best. Combine these 2 runs for agd and profit:eru_bahagon wrote:Starting with van's route, you try to collect all the gold in one jump less, i.e. starting by collecting 2 by 2 from the top. I can get the first jumps right.
never got agd even on test map
We're making good progress here, guys. Nice work.
just do 2 more cjs at the end and you should be faster
40-4.
This is possibly quicker than having to do the extra WJ on each side of the map?
That reminds me, ska whatever happened to your route change for 40-4? Why have you still not done it? D:
I retired! XDmohamedraif wrote:That reminds me, ska whatever happened to your route change for 40-4? Why have you still not done it? D:
51-1: compare my 139.250 run to xaelar's 0th. Notice the difference after the exit of the bottom right room...
43-4, can anyone do something with it?
If you can get better WJs or a BBCK or something so that you can beat the first drone then it is useful. Otherwise since you are limited by the drones you will just end up tied with Ska.vankusss wrote:43-4, can anyone do something with it?
Map: 69-2
Time Saved: 6 Frames
Difficulty: Super Easy
Current Route: Lim waits to fall to the 1-tile before jumping.
New Route: Just wall jump instead of waiting to slope jump.
This is a super small innovation, and 6 frame probably isn't enough to beat Lim's great run, but it is also about as easy as 6 frames can come.
44-3 on the highscores board (currently 4th place).. If I can find a way to optimise the end, it could be a new 0th route. (you could even improve the 0th by simply using the normal route for the 2nd half...
Edit: Just thought I'd add that the drone can be problematic on the right side on the final ascent. The best way to counter this (assuming you choose to use part 2 of the innov), is to feint out wide to prevent the seeker from charging at you - but it's easier said than done because you can't afford to miss the gold...
- RoboBarber
44-3. But keep misspelling the levels :P
Your route seems easier, I'll give a try. I might even consider giving you credits for it :)
Son of a bitttttttttttttttttttttch. You're right.. I really have to stop posting these innovations in the dead of night.eru_bahagon wrote:44-3. But keep misspelling the levels :P
69-2 sr
My demo is slower than the current 0th but someone might be able to do something with it.
This is why we don't give you credit for your innovations. You don't even know what level you are innovating ;)ska wrote:Son of a bitttttttttttttttttttttch. You're right.. I really have to stop posting these innovations in the dead of night.eru_bahagon wrote:44-3. But keep misspelling the levels :P
Where did I park my car? What year is this? Who Killed Kenny? Does my butt look big in this? Where am I?TheRealOne wrote:This is why we don't give you credit for your innovations. You don't even know what level you are innovating ;)ska wrote:Son of a bitttttttttttttttttttttch. You're right.. I really have to stop posting these innovations in the dead of night.eru_bahagon wrote:44-3. But keep misspelling the levels :P
