Metanet Bitesized :: LEVELS FINISHED! :D Playtesters needed!
Moderator: zoasBE
The Future of Metanet Bitesized
1 Remove backgrounds
0
No votes
2 Center all levels
3
20%
3 Remove backgrounds and center all levels
6
40%
4 None of the above
1
7%
5 Capital Letters as Titles
2
13%
6 lower case letters as titles
3
20%
Total votes: 15
Not actually an admin
Postby Paradox » 2012.01.20 (09:50)
Moving onto the 50s collumn
I see trance hasn't given you his next 5 maps from the 80s collumn, so that makes 71 to go on your list, but on the list i'm keeping on IRC, it has 70 maps to go, here is what i have on the list '441/500 - 88.2% - 59 To Go - To Do http://pastebin.com/raw.php?i=LwWVgTWg', from 70 to 59 is these maps & the 5 of trances he hasn't put up here, i checked both lists, excluding these maps, you didn't miss a miss a map on the list from what i checked, anyway, i'm sure you can find it easy, unless you just miss-counted for the total maps done, anyway, this won't die again, it will get finished
EDIT
DW40 told me 56-4 was missing a trigger, fixed it
EDIT
Postby trance » 2012.01.20 (16:05)
29403 wrote:
NachoCheese, trance, thanks a lot for finishing the 20s column! That's five columns down, five to go! Also, trance, there's some good work on the 80s column there! :)
You're very welcome.
I plan on giving what needs to get done in a single paste, but here's one more paste containing the last levels of the 80s column that needed to be done:
http://pastebin.com/d8wM8tpA
Sig by Aidiera.
My Accomplishments
I have 167 speedrun Episode Top-20s and I'm 4th on the boards. :D
Postby 29403 » 2012.01.20 (19:33)
I'm kinda confused, but I've updated the list. I'll update the full pack once you've finished your levels, and good luck with 83-0 and 84-4. Thanks.
Postby Paradox » 2012.01.21 (01:32)
...Anyway
It's very difficult, someone else should probably make a better version, but this is possible
EDIT
EDIT
98-4 is pretty bad, may need a bit of fixing down the bottom, the sides are both possible & easy, they just look difficult
EDIT
If any of these maps are too hard, then i'll fix them
Postby trance » 2012.02.04 (01:20)
http://pastebin.com/Ps38B6xp
I've had these done for a while. The final two levels for the 80s column, 83-3 and 84-0, are done.
Sig by Aidiera.
My Accomplishments
Postby 29403 » 2012.02.04 (19:32)
Thanks.
PD, 36-4 has no exit switch.
Postby Paradox » 2012.02.05 (08:17)
Oh, heh, i usually put that in second, but with changing the tiles every now & then on that map i guess i forgot
Here's the fixed one
EDIT
I just realised, my 35-2 in this post is actually 35-4, i'll fix that, so 35-2 still needs to be made
& here is another
EDIT
I think i edit these posts too much
Postby trance » 2012.02.05 (13:29)
http://pastebin.com/0QSVtVvd
I could of sworn I've posted the rest of the 80s column. Looks like I forgot, but here are the rest of them.
Sig by Aidiera.
My Accomplishments
Postby 29403 » 2012.02.05 (18:04)
Thanks. Personally I thought the 80s column would be finished last, though. :D
Pack updated.
Postby Paradox » 2012.02.06 (00:03)
Postby trance » 2012.02.11 (00:21)
I got the entirety of the 70s column done.
http://pastebin.com/h5P2W66K
http://pastebin.com/BFqVpiGZ
http://pastebin.com/djHMPXbj
As well as the ones that needed quality control (4-1 to 4-4).
http://pastebin.com/hMbBACsH
Sig by Aidiera.
My Accomplishments
Postby Paradox » 2012.02.11 (01:49)
EDIT
NUMA Profile: http://nmaps.net/user/remote
Postby Limer » 2012.02.18 (10:31)
WOAH, this is almost finished?!
29403 good job man. This is astounding.
I feel proud to have been a part of it.
thats right, im remote.
Postby Tunco » 2012.02.18 (22:43)
35-2:
Postby 29403 » 2012.02.18 (22:55)
Limer wrote:WOAH, this is almost finished?!
Whew... it was a tough project, spanning many metanet generations... but we're almost done! Perhaps once it's finished we'll get a bit more life in the community :D
Thanks for the huge bunch of levels, trance, PaD and Tunco. The levelset will be updated once we get to 500, ready for the playtesting stage.
Postby Paradox » 2012.02.19 (12:03)
Postby 29403 » 2012.02.22 (22:45)
Thanks.
Postby Paradox » 2012.02.26 (09:57)
Postby trance » 2012.02.28 (23:31)
And boom! The 50s column is complete!
Dox has 59-2 above me, but here are the other ten.
http://pastebin.com/n58dDihy
http://pastebin.com/76u1k2Wm
http://pastebin.com/0mjabw0u
Sig by Aidiera.
My Accomplishments
Postby Paradox » 2012.02.29 (05:08)
You skipped 39-0
EDIT
Postby trance » 2012.02.29 (05:14)
http://pastebin.com/1yQAe0zg
94-1
Here's my final map for this project. When it is completed, how are we going to playtest the levels?
Sig by Aidiera.
My Accomplishments
Postby Paradox » 2012.02.29 (07:44)
I believe this is finished now
Here are all the levels (or what i believe to be all the levels) with Capital Letters & a few more spelling/punctuation mistakes fixed, there are 2 35-2s because Tunc made it...
userlevels.txt
(698.11 KiB) Downloaded 812 times
Postby Paradox » 2012.03.06 (18:46)
Playtested Comments (Sorry for all the negativity, i don't mean it personally, just noticing the differences between the original & the bitesize)
Ignore the ()
Click Me
30-0 - Could be a bit smaller ()
30-1 - Perfect
30-2 - Really odd ()
30-3 - Could be alot smaller ()
30-4 - A few tile & object adjustments needed to be more like the original
31-0 - Moved a few things around
31-1 - Could probably be smaller, but it is a perfect resize
31-2 - At first look, it looks odd, but it's a good scale from the original, just a few mines not in the right places or an extra mine
31-3 - Background art - Too small for the drones to be the same as the original
31-4 - Background art - I guess it works, although it would probably work better 1 or 2 tiles bigger
32-0 - It's nice?
32-1 - Background art - Too small for the drones to be the same as the original
32-2 - Background art - Okay
32-3 - Background art - I couldn't recognize what map this was, i thought it might be the one it is but i still had to check to make sure
32-4 - Background art - Too small
33-0 - Okay
33-1 - Background art - could probably change the 8 tiles to 1 or 6 tiles
33-2 - Background art - Too small
33-3 - Background art - Too small
33-4 - Background art - Too small
34-0 - Okay, could be smaller
34-1 - A few tile & object adjustments needed to be more like the original
34-2 - Looks odd but it's the same as the original
34-3 - Nice
34-4 - A few tile changes & double all the bounce blocks
35-0 - (I made this)
35-1 - Okay
35-2 - (Unknown)
35-3 - (I made this) You have to get the ending jump really close to the middle for the second exit
35-4 - (I made this)
36-0 - (I made this)
36-1 - Looks odd, could probably use a few tile & object adjustments
36-2 - (I made this) Easier than it looks
36-3 - Great
36-4 - (I made this)
37-0 - It works?
37-1 - Odd tiles to ajust for bitesize but it's great
37-2 - Great
37-3 - (I made this) Incredibly hard to bitesize
37-4 - (I made this)
38-0 - (I made this)
38-1 - (I made this) Annoying to bitesize, easier than it looks, even AGD
38-2 - (I made this) It may be too difficult
38-3 - (I made this)
38-4 - Difficult
39-0 - (I made this)
39-1 - (I made this)
39-2 - (I made this)
39-3 - Okay
39-4 - (I made this)
Postby trance » 2012.03.06 (20:03)
I'll take the 00s and 10s column.
Sig by Aidiera.
My Accomplishments
Postby 29403 » 2012.03.06 (23:26)
I'll go with the 60s, seeing as I made most of those...
