Post a Run!
Postby Innuendonewb » 2012.01.18 (13:47)
Another top-20 ^^ : 63-3
Postby Kool » 2012.01.18 (18:45)
reached 200 sr 0ths :) almost half way to my goal
201 0ths now with 57-1
Postby TheRealOne » 2012.01.18 (21:03)
Kool wrote:reached 200 sr 0ths :) almost half way to my goal
That was fast =O
http://n.infunity.com/latest_0_score_speedrun.php
Keep it going!
EDIT: 169-3 My jaw hit the floor. Holy shit that was a clean run.
Postby TheRealOne » 2012.01.19 (21:44)
Super Perpendicular Jumps do exist. Here it is confirmed. Look how my feet are in the tile because i landed exactly on the seam this gives me extra height. So here is the same demo data with just removing the lower 1 tile to show that you do need a seam of two tiles to make this glitch happen.
Both Tiles and Super High Perpendicular Jump
Bottom 1 Tile Removed and Normal Perpendicular Jump
Postby Kool » 2012.01.21 (04:55)
72-0, 121-4, & 169-0 sr taken
oh and..........00-0 TAKEN hs. I am the keeper of 00-0
Postby TheRealOne » 2012.01.21 (18:06)
Kool wrote:72-0, 121-4, & 169-0 sr taken
Holy shit... You stomped on naem. That run is fantastic. 72-0 is super clean, probably near perfect height going in to the BBCK. Could 169-0 be improved with a corner shove at the exit switch?
NUMA Profile: http://nmaps.net/user/OutrightOJ
Postby OutrightOJ » 2012.01.22 (20:33)
Retook 169-0 and took 72-0, both by a frame.
Thanks to furry for this awesome sig. He likes birds, he does.
FIRST EVER COMIC STRIP! Using Paint. <3 <CLICK>
Postby Kool » 2012.01.23 (16:09)
OutrightOJ wrote:Retook 169-0 and took 72-0, both by a frame.
very nice 72-0 man, knew there was another frame in there.
Edit: 127-1 sr taken. maxed my ass ;)
Postby Raif » 2012.01.27 (10:39)
170-3 sr taken, probably one or two frames still left
Edit: 135-3 sr back from Eddy
Edit2: 110-2 sr back from OOJ
Edit3: 135-3 sr taken back from OOJ
Edit4: Can't beat OOJ's new 135-3 but taken 144-4 sr taken by 100+ frames with innov. Is no one else going to post here?
Postby jasdanu » 2012.02.02 (02:36)
mohamedraif wrote:170-3 sr taken, probably one or two frames still left
holy shit Raif. 144-4 o.O tht was fuckin amazing
Sig: Izzy
Postby TheRealOne » 2012.02.02 (03:13)
That jump... That was fucking brilliant. Well done sir. I did not see that coming at all.
Postby ska » 2012.02.02 (05:52)
Good discovery. Taken by a further 100+ frames.
Postby Raif » 2012.02.02 (06:29)
ska wrote: Good discovery. Taken by a further 100+ frames.
Nice run, ska.
I was expecting someone would take it by like 50 frames, never thought 100+ more frames were possible. But then again I ran around the map like an idiot instead of turning back. I'll try to take it back (or atleast reduce the gap) when I have time.
Postby ska » 2012.02.02 (09:30)
Nice run, ska.
Thanks, I chipped off another 12 frames - there's still room though :)
Postby Raif » 2012.02.02 (14:15)
ska wrote:
Nice run, ska.
Taken back. Sub- 600'd
Postby vankusss » 2012.02.02 (15:02)
nice innov raif
145-2:
seems possible
Postby ska » 2012.02.02 (15:44)
Took 144-4 highscore by 7.725 seconds.
Postby TheRealOne » 2012.02.02 (16:44)
mohamedraif wrote:
Nice run, ska.
Now you are thinking with your noodle. That is looking like a solid route. I think think there may be a way to do a faster ending.
vankusss wrote: 145-2:
seems possible
I agree. I tried this a while back and did the same thing you did there. But I think with a little more speed it could be done.
Postby Kool » 2012.02.08 (05:11)
6-1 taken back & 31-2 sr taken
Postby TheRealOne » 2012.02.08 (15:05)
Kool wrote:6-1 taken back & 31-2 sr taken
6-1 is a solid run, very clean. 31-2 there can't be many more frame left in that at all. Everything seemed as it should be. I can't see any obvious improvements to be made.
Postby ska » 2012.02.09 (04:22)
If you watch kool's run against mine in ghost mode, it looks like I am a frame up until the wall jump on the far left.
Postby golf » 2012.02.09 (04:45)
Broke 252 on 00-0 tonight. Nothing spectacular, but I feel like that's a huge benchmark to pass. As a sidenote, here's the first run I actually got to 252 with. Note the top right gold - I did not intend to do it that way, but I feel like it was a novel way to collect it. Too bad it seems to be a few frames slower, or I'd actually have an innov on one of the most standardized routes.
Postby jasdanu » 2012.02.09 (17:23)
yea i did tht ska about 10 times. I think the same thing. You seemed ahead until that walljump on the left.
Sig: Izzy
Postby vankusss » 2012.02.12 (00:26)
Took 42-3 sr with a nifty new route. I don't think my ending is optimal, there are probably like 5-7 frames left.
Postby TheRealOne » 2012.02.12 (00:55)
vankusss wrote:Took 42-3 sr with a nifty new route. I don't think my ending is optimal, there are probably like 5-7 frames left.
There are deffinitely more than 5-7 frames left if you PJ at the end like Lim does. I think you should have enough speed to make that happen. But your route is fucking awesome. That should be in the next iNsane or BoN2. That was awesome. I did not expected that at all. You use the level like it is a half pipe. That is certainly a "nifty" route.
