Post a Run!
- Walking on Broken Glass
- NUMA Profile: http://nmaps.net/user/Kool-aid
201 0ths now with 57-1
That was fast =OKool wrote:reached 200 sr 0ths :) almost half way to my goal
http://n.infunity.com/latest_0_score_speedrun.php
Keep it going!
EDIT: 169-3 My jaw hit the floor. Holy shit that was a clean run.
Both Tiles and Super High Perpendicular Jump
Bottom 1 Tile Removed and Normal Perpendicular Jump
oh and..........00-0 TAKEN hs. I am the keeper of 00-0
Holy shit... You stomped on naem. That run is fantastic. 72-0 is super clean, probably near perfect height going in to the BBCK. Could 169-0 be improved with a corner shove at the exit switch?Kool wrote:72-0, 121-4, & 169-0 sr taken
- NUMA Profile: http://nmaps.net/user/OutrightOJ
Thanks to furry for this awesome sig. He likes birds, he does.
very nice 72-0 man, knew there was another frame in there.OutrightOJ wrote:Retook 169-0 and took 72-0, both by a frame.
Edit: 127-1 sr taken. maxed my ass ;)
Edit: 135-3 sr back from Eddy
Edit2: 110-2 sr back from OOJ
Edit3: 135-3 sr taken back from OOJ
Edit4: Can't beat OOJ's new 135-3 but taken 144-4 sr taken by 100+ frames with innov. Is no one else going to post here?
holy shit Raif. 144-4 o.O tht was fuckin amazingmohamedraif wrote:170-3 sr taken, probably one or two frames still left
That jump... That was fucking brilliant. Well done sir. I did not see that coming at all.jasdanu wrote:holy shit Raif. 144-4 o.O tht was fuckin amazingmohamedraif wrote:170-3 sr taken, probably one or two frames still left
Good discovery. Taken by a further 100+ frames.TheRealOne wrote:That jump... That was fucking brilliant. Well done sir. I did not see that coming at all.jasdanu wrote:holy shit Raif. 144-4 o.O tht was fuckin amazingmohamedraif wrote:170-3 sr taken, probably one or two frames still left
Nice run, ska.ska wrote: Good discovery. Taken by a further 100+ frames.
I was expecting someone would take it by like 50 frames, never thought 100+ more frames were possible. But then again I ran around the map like an idiot instead of turning back. I'll try to take it back (or atleast reduce the gap) when I have time.
Thanks, I chipped off another 12 frames - there's still room though :)mohamedraif wrote:Nice run, ska.ska wrote: Good discovery. Taken by a further 100+ frames.
Taken back. Sub- 600'dska wrote:Thanks, I chipped off another 12 frames - there's still room though :)mohamedraif wrote:Nice run, ska.ska wrote: Good discovery. Taken by a further 100+ frames.
seems possible
Now you are thinking with your noodle. That is looking like a solid route. I think think there may be a way to do a faster ending.mohamedraif wrote:Taken back. Sub- 600'dmohamedraif wrote:Nice run, ska.ska wrote: Good discovery. Taken by a further 100+ frames.
I agree. I tried this a while back and did the same thing you did there. But I think with a little more speed it could be done.vankusss wrote: 145-2:
seems possible
6-1 is a solid run, very clean. 31-2 there can't be many more frame left in that at all. Everything seemed as it should be. I can't see any obvious improvements to be made.Kool wrote:6-1 taken back & 31-2 sr taken
If you watch kool's run against mine in ghost mode, it looks like I am a frame up until the wall jump on the far left.TheRealOne wrote:6-1 is a solid run, very clean. 31-2 there can't be many more frame left in that at all. Everything seemed as it should be. I can't see any obvious improvements to be made.Kool wrote:6-1 taken back & 31-2 sr taken
yea i did tht ska about 10 times. I think the same thing. You seemed ahead until that walljump on the left.ska wrote:If you watch kool's run against mine in ghost mode, it looks like I am a frame up until the wall jump on the far left.TheRealOne wrote:6-1 is a solid run, very clean. 31-2 there can't be many more frame left in that at all. Everything seemed as it should be. I can't see any obvious improvements to be made.Kool wrote:6-1 taken back & 31-2 sr taken
There are deffinitely more than 5-7 frames left if you PJ at the end like Lim does. I think you should have enough speed to make that happen. But your route is fucking awesome. That should be in the next iNsane or BoN2. That was awesome. I did not expected that at all. You use the level like it is a half pipe. That is certainly a "nifty" route.vankusss wrote:Took 42-3 sr with a nifty new route. I don't think my ending is optimal, there are probably like 5-7 frames left.
