Time Saved: 20-30 frames
Difficulty: Easy
Current Route:
New Route:
CJ route [Thanks to Raif] Over a second saved:
Awesome innov, took 0th with it. I suppose it can be cleaned a lot.TheRealOne wrote:Map: 25-1
Time Saved: ??? Decent Amount
Difficulty: Moderate
New Route
I was going to save this route change for my self, but i got fed up with trying. The route isn't that hard at all and it is faster than Lim. I do not know by how much because I didn't make it as a test map, but if you watch my demo with the lim's run on the demo feature you can see i beat him to the top left switch, but then I fuck up. Also I am rather slow here, you can go much faster.
Also this double CJ route should be a little faster than the above, but also harder.
Perpendicular jump, also known as reverse jump.eru_bahagon wrote:What is a pj ? push jump ?
What is it ?
Agreed, that gold is not my friend.TheRealOne wrote:Yeah, Wow van. I didn't think the innovation was that fast. There is definitely room to push it to 141.000, but that will mean getting a fast pj in the middle like I do, and even mine is slow compared to a few others I got. The problem is if you go for it you are very likely to miss a gold.
Having tried Lim's route before, I found easier to "pj" and not "wj". Maybe it is just about the vertical speed...ska wrote:Just a tip, I found it a lot easier when testing to just simply wall jump instead of RJ but that's just me, it might be a frame or two slower but it's a hell of a lot easier to pull off...
You can easily test that yourself by creating a test map. For this time, I did that for you:glib_jase wrote:My current 25-1 HS. Is my change of route on the left hand side any quicker?
The ck in bottom left, which is necessary to take the left bottom gold, might render your left wall climbing impossible to do. But dunno, I didn't try.TheRealOne wrote:Map: 41-2
Time Saved: ~.300
This is basically a total route change. I hit the floor at .875 so that means I probably got the door around .950 Someone better than me could probably push the map up to 145.000 with this, unless for some reason that gold I miss take a lot of time, but I don't see why that would happen because Lim doesn't lose much getting those gold in the exact same fashion. Also of course anywhere you could throw in a CK would speed things up, but those are tough. I am thinking maybe on the bottom right E tile would be a nice place to throw one because of the angle you come off the wall would make it plausible.
userlevels data only please.trance wrote:On 81-4 sr, it is possible to get across with hitting the corner of the second thwump. Is it possible for this route to be used to take the current sr 0th*?
It's not really an innov, because it doesn't speed up anything. You end up in the same route after doing that (unless you're willing to find a whole new route after that - good luck).Paradox-Dragon wrote:96-4
sr
possibly impossible
Yeah, that's a big problem with 96-4, all the different routes, some with fast drone dodges, they all end up at the same pace, unless you can are able to get to the next pacevankusss wrote: It's not really an innov, because it doesn't speed up anything. You end up in the same route after doing that (unless you're willing to find a whole new route after that - good luck).
