Metanet Bitesized :: LEVELS FINISHED! :D Playtesters needed!
Moderator: zoasBE
- Steam: What's Steam
Thanks, Scrivener for the levels... maybe we can continue again. :D But you've gotta check the levels needed to do in the front page, because 55-1 and 55-3 were done. But we'll use yours, (because I made 55-1 & 55-3).
- On the Psychic Highway
Those maps need to be done.Scrivener wrote:the front page is confusing. are the maps shown ones that have been done, or ones that need to be done?
- Commodus
- Commodus
In the future though, Rule, can you put the level codes in the format I asked? I've forgotten names of some of the levels, like 24-2 and 93-2.
Also, I think I've lost a few levels from when my laptop was broken months ago, so the real total isn't 370, it's 366. I'll update.
Let's get this thing finished!
- MBTI Type: ESTP
- Richard Richards
What in the flying fuck?Epic4ever wrote:Noob Question: what are you doing here?
Also, thanks to whoever pinned this =)
- Not actually an admin
So, i've been doing some stuff for this, since it died, well, i've been working on Metanet Bitesized in #Meta on IRC, Getting some advice, from zap & trance for some of the maps, no one else that i asked to help contributed
Here's the topic for #Meta
'384/500 - 76.8% - 116 To Go - Main Project: http://tinyurl.com/Metanet-Bitesized - Maps To Do: http://tinyurl.com/Maps-To-Do - Userlevels: http://metanet.4shared.com/'
I fixed all the spelling errors & capitalized all the map names & types
The userlevels.txt is in a download file because Pastebin only accepts 500kb willard
I've been thinking of things to improve it as a whole. I was thinking of removing all the 'backgrounds' (e.g. 43-0) and just filling them with walls. Some of them are really nice (e.g. 20-1, 33-1) but some of them are pretty blah (e.g. 00-1, 00-2, 02-0).
Some levels will have to be remade since they're not 'mini' enough (3 tiles between the border of the game window, and the edge of the level. 04-1, 04-2, 04-3, 04-4, especially 04-3, aren't nearly small enough, they were all made by me in the very early stages of this project. I'll remake them sooner or later.)
The odd level is very difficult for its placement, and compared to the actual level: 33-0 is one.
Also, this might be kind of fiddly, but a small proportion of levels are off-center. That doesn't matter at all though.
Pa-D, 27-2 was a duplicate, but in this case yours is far smaller, so yours is in.
Also, most of my maps are 3 tiles from the top & bottom, & 3 tiles from the left & right, so, i was unsure if you meant 3 tiles on each side or just 3 tiles in total? (For some of the maps i made, i kept all the things to scale & just moved them all closer together, for others i scaled everything down by 1/2 or 1/3, some of my maps would be better done at 1/2 & not just moved closer together)
81-3 is very difficult & i did ask some of the pros like zap & Eddy to help playtest it, but none of us have been able to beat it, i have been able to get 3/4 of the way, it is also a very addicting map & fun, also, possibly harder than 88-4, also, my 88-4 may still need some editing
About the blank space, yes, i thought of removing it all too, I also noticed in your maps, some have 4 tiles on all the corners, 00-0 is an example of a 4 tile in the bottom left corner, i found this very annoying, just wondering if you also wanted to fix that too, if you give me a list of all the things that need fixing, & a list of the maps that are too big, i will be more than happy to fix them willard
Ridiculous small, that's the whole spirit of this project!Paradox-Dragon wrote:Ahh yes, 27-2, i had made that when i read the list wrong, I have since read the list wrong several times & probably made 6 other duplicates, all deleted, i only kept 27-2 because it was ridiculous small & funny, i thought yours was more serious so i kept both, i only kept mine as a joke
3 tiles from the top, bottom, left and right.Paradox-Dragon wrote:Also, most of my maps are 3 tiles from the top & bottom, & 3 tiles from the left & right, so, i was unsure if you meant 3 tiles on each side or just 3 tiles in total? (For some of the maps i made, i kept all the things to scale & just moved them all closer together, for others i scaled everything down by 1/2 or 1/3, some of my maps would be better done at 1/2 & not just moved closer together)
There are a few difficult ones there, far more difficult that the original levels (33-0, I'm still looking at you). If you could edit 81-3 to make it easier, that would be great.Paradox-Dragon wrote:81-3 is very difficult & i did ask some of the pros like zap & Eddy to help playtest it, but none of us have been able to beat it, i have been able to get 3/4 of the way, it is also a very addicting map & fun, also, possibly harder than 88-4, also, my 88-4 may still need some editing
I'll fix that. You can check the quality control if you want!Paradox-Dragon wrote:About the blank space, yes, i thought of removing it all too, I also noticed in your maps, some have 4 tiles on all the corners, 00-0 is an example of a 4 tile in the bottom left corner, i found this very annoying, just wondering if you also wanted to fix that too, if you give me a list of all the things that need fixing, & a list of the maps that are too big, i will be more than happy to fix them
Wait, are you saying my maps are too big?3 tiles from the top, bottom, left and right.
No No No, i won't! This map is great, if people can't beat it, i'll make them beat it!If you could edit 81-3 to make it easier, that would be great.
Maps like 1-0 & 2-0 both have the ninja 002 coordinates above where the ninja on the actual maps are
2-0 also has a NaN'd gold & a BB (bounce block) missing, Here is it with a BB & fixed gold
Finally, ep 00 & 01, is more of a resemblance to ep 00 & 01 than an actual ep 00 & 01
EDIT
I can easilly do this, how many votes till you decide what happens? 20 (10 people willard)?Center all the levels (this will look neater but really, really fiddly to do.)
About Episode 33: I think you should get permission from numa_ninja. Forgot to mention in in the first post.
Also, how can you easily center maps?!
That program doesn't always have the correct image, & drones are usually offIt's dangerous to go alone... take this.
I have some good mapping skills, i can make/copy/move objects fast, tiles are easy since you can just copy paste in ned, there is also, NED Plus, a fan program from the old forums for multiple objects & another fan program for object moving, i can/will get them for you
EDIT
Here is the Object mover & here is the NED Plus
For the object mover, i'm using windows 7, & this is probably how the program works on all computers. just open 'gnmov', paste your map data into the top text box, click 'Load Objects', then 'Select All' (or all you want), set the X & Y offset, X 24 moves everything 1 grid square to the right, then press 'Translate', & there's your map data willard
EDIT
35-2, It's not on the list, or in the userlevels, Which makes 13 levels to go in the 30s collumn, Which makes 76.6%, Which doesn't make sense willard
- Semimember
- NUMA Profile: http://nmaps.net/user/NachoCheese
Is that 29-3 O.K?
Any maps you want me to do and I'll do them.
EDIT: 97-4
53-3
http://pastebin.com/k3jY8BWq
Dox and I worked on 83-3 which is annoying, but possible. I'll be doing more of the 80s column in the future.
Also this is to complete the 20s column.
http://pastebin.com/CjPQwhMa
NachoCheese has 29-3 completed, so I decided to finish it off.
Sig by Aidiera.
EDIT
NachoCheese can't get the N Level Data, so here...
- Attachments
- N Level Data.zip
- N Level Data
- (254.19 KiB) Downloaded 1201 times
http://pastebin.com/jrP6jjvX
http://pastebin.com/6RheFsHu
Sig by Aidiera.
EDIT
More maps
EDIT
Some more
- Donator
NachoCheese, trance, thanks a lot for finishing the 20s column! That's five columns down, five to go! Also, trance, there's some good work on the 80s column there! :)
NachoCheese, in the future, could you post the level data in the format I provided at the first page? Just makes things a bit easier since I've forgotten the names of the levels!
Paradox-Dragon, thanks for your help on the 30s. Sorry about 35-2... nobody's perfect!
BanjoDave, thanks for removing Episode 95 off the to-do list! :D
