From what I remember, it's to do with the velocity of the ninja. When the ninja hits the one-way platform at a certain velocity, the stopping nature of the one-way platform is negated and allows the ninja to pass through.EddyMataGallos wrote:Im not posting this because its a great run, but because it contains a rare oneway glitch most people know, but nobody know why.
Yes, im talking about that one, in the run that glitch happened to me from a different height of what im used to, so i decided to post it here in case anyone can figure out whats going on with this glitch, its appears at the end obviously.
Post a Run!
It is a very strange glitch. Sometime you land on the oneway for 1 frame then fall through, so you can actually jump to prevent your self from falling through, Other times you fall through with out standing on the one way. It works for many different y coordinates, the x coordinate does not matter. Also the distance is not the key to this because not all y values are equal for some reason. Example: If you are on a oneway with y=200 and fall to one with a y=266 you will fall through, but if you are on a oneway at y=300 and you fall to one with y=366 you will not. Both are 66 pixels apart, but only the first works. Also the top oneway in these examples can just be where the ninja's feet are.EddyMataGallos wrote:So there are different speeds that can cause the ninja to fall through the one-way, interesting
I made this map a long time ago to test some of these examples, here is it is to play around on with a demo of me showing what you can and can't do.
not anymore! ;)MiBeM wrote:44-2 speed, it's a 0th :)
In the words of Steve Jobs: "Think Different."
Now I'm sad. Good run, though :)ska wrote:not anymore! ;)MiBeM wrote:44-2 speed, it's a 0th :)
Ignore my pathetic run and imminent death, but you get the idea, don't use the LPs like Mibem, and don't get the lowest door because you can fall an get the switch under the door.
- NUMA Profile: http://nmaps.net/user/Fdaniel
Hi Fdan, welcome to the forum... are you SURE you've got bored of the underclock boards now? Really? ;)Fdaniel wrote:160-1 - HS
But I´m still highscoring on the underclock boards, of course (:
and:
2-1, 2-4 and 3-0 - underclock mode; because I like these three runs, especially 3-0 <3
217642 - HS
I don't think there were any records at all, just some people trying the feature out.Fdaniel wrote:No records to beat anymore /:
I really hope you'll just forget that whole mode and start doing the ONLY REAL MODE, THE HIGHSCORE ONE. SCREW YOU SPEEDRUNNERS AHAHAHAHA!
Yes, I started a few days ago ;)
Fact nº 1: Even with 941 0ths, you're still an hour away from xaelar's total level score.
Fact nº 2: Even with 941 0ths, you've only got 8 episode ownages o.O, i was waiting to see an huge list, and only 8 episodes appeared.
1. Yeah, I´m still working on my Total Level score ;)
2. You will see a huge list, soon, my son (I hope ;), I didn´t really cared about those Episode Ownages yet, but I will try to go for some in the future.
Edit:
just took 141 - 0
Yeah, the fact is that I find strange that since you own most levels, it seems you left a 0th on each episode or something :DFdaniel wrote:@Eddy
Edit:
just took 141 - 0
Yeah, That´s the way it is, gonna change that, though. ;)EddyMataGallos wrote:Yeah, the fact is that I find strange that since you own most levels, it seems you left a 0th on each episode or something :DFdaniel wrote:@Eddy
Edit:
just took 141 - 0
