Postby Unreality » 2011.07.05 (05:40)
ska wrote:I think Unreality is right... it saves approximately 9 seconds initially. But you also need to factor in the delay for manipulating the laser drones (as well as avoiding the mines and the requirement to make the return journey using the 'top route'). I conservatively estimate a saving of 3-4 seconds after factoring in delays but it might even be more!
the return journey doesn't need to use the top route
first get the top left (trigger > switch, or switch > trigger), then enter the center diagonal passage and get all the diagonal gold, then to the bottom right trigger, then bottom right exit
Postby vankusss » 2011.07.05 (09:37)
Oh yea you guys are right, I thought right bottom triggers traps around left bottom drone...
Looks more interesting now.
EDIT: I did this test level:
Currently, the top drone starts shooting exactly where we want it to. In real run, you'll fall like I do, so it will be like totally random.
Secondly, I can't even be fast enough in this test map to make it up fast.
EDIT2: maybe something like this
EDIT3: possible when doing this:
Postby vankusss » 2011.07.05 (10:13)
My tweaked route for 85-3 is faster (check submitted run).
Also do this near the end:
EDIT: note - you can take 0th even with old route but with that ending trick
Postby Unreality » 2011.07.05 (10:40)
vankusss wrote:Oh yea you guys are right, I thought right bottom triggers traps around left bottom drone...
This level won't reflect the real level! This is because of the Drone AI cycle
If there's only one laser drone in the map, it aims at the ninja for every single frame
if there's two laser drone plus some guass in the map, they take turns so the laser drone won't aim at the ninja directly
in real 87-1 you do have enough time to jump from the bottom left to the top right
Postby vankusss » 2011.07.05 (10:44)
Unreality wrote:This level won't reflect the real level! This is because of the Drone AI cycle
Hm I didn't think those few frames have that much impact, my bad.
Though I won't probably go for it.
Postby Unreality » 2011.07.05 (11:10)
see this demo
Postby ska » 2011.07.05 (15:20)
Unreality wrote:see this demo
nicely done, man!
Postby TheRealOne » 2011.07.07 (17:46)
Map: 11-3
Demo:
This innovation is to jump in the tunnel up top and land on the 8 tile further out so that you can make it up to the platform with the gold and exit switch. Anyone think it is faster? It's not too hard especially if you land flat in the tunnel after dodging the rocket up the way up the wall.
Demo 2:
Low jump also works though this would be slower than the the first strategy. Not sure how much slower though because timing can't be compared because I was slower in the start, but I only hit the ground 5 frames later and I was slower in both the start, tunnel entry, and falling past the 8 tile of the platform with the the exit switch.
Postby ska » 2011.07.08 (05:58)
TheRealOne wrote:Map: 11-3
Demo:
Demo 2:
I think demo one is faster than the current strat. (my tunnel landing was rough as you can see in my 0th). I'd say by maybe 4 or 5 frames at a guess? Which is considerable, considering the tightness of scores...
Postby TheRealOne » 2011.07.09 (04:31)
Demo:
Demo 2:
Yeah I might try for it, but the ending always fucks me. I have done it a few times. Your run isn't the cleanest at the start, it was your ending that did it for you. You got a near perfect slide.
Postby Unreality » 2011.07.10 (05:54)
a better 87-1 freed laser drone demo
Postby vankusss » 2011.07.22 (18:41)
59-2, take top gold in 1 go at the beginning, and then at the end, when going to exit, do this:
it's not really easy, that was my first time I got high enough rcj... so if someone has a lot of time, go for it
EDIT: it's around 3 seconds faster
EDIT: my estimate was quite close...
Postby ToeFaceKiller » 2011.08.21 (21:16)
If anyone attempts 49-4 0th, they should do this ending. Because it would be bad ass.
Postby vankusss » 2011.08.22 (10:53)
ToeFaceKiller wrote:If anyone attempts 49-4 0th, they should do this ending. Because it would be bad ass.
Bro, there are bbs in the way?!
Postby ToeFaceKiller » 2011.08.22 (18:33)
Haha naw man it's quite possible, I did it a few times when testing it out. I'll make a demo later.
Edit: Ok here
Postby ska » 2011.08.25 (15:15)
ToeFaceKiller wrote:Haha naw man it's quite possible, I did it a few times when testing it out. I'll make a demo later.
Edit: Ok here
I think it's a clever idea and appears to save a nice little nugget of time. It also seems like even if you miss the corner jump, you could still salvage the run...
Postby TheRealOne » 2011.10.07 (02:34)
So here is my entire folder of innovations. Most I have already shared, some I haven't. Some are crap. Some are genius. I have lost track at this point so I present it to you in hope of stirring up some competition. Look at 69-3 especially. So have it... Also some are fbf only I think they are marked.
http://www.mediafire.com/?xcznrqw445dfj
Postby Unreality » 2011.10.07 (03:50)
thx for the sharing TRO
there's a growing voice in my heart asking me to add that extraordinary function which every highscorers have longed for thousands of years into NReality
Postby ska » 2011.10.07 (04:29)
11-4 looks cool, but wouldn't it be faster to get the gold in the top left fast? Maybe by jumping off the right wall bit if you know what i mean :P
Postby TheRealOne » 2011.10.07 (13:03)
Unreality wrote:thx for the sharing TRO
Go on..?
*cough* savestates and rerecording for fbf mode *cough*
Postby EddyMataGallos » 2011.10.07 (13:53)
Oh my god whats that function youre talking about!?
Thanks a lot for the effort on compiling those innovs TRO :D
Postby Unreality » 2011.10.08 (07:20)
TheRealOne wrote:*cough* savestates and rerecording for fbf mode *cough*
um the function that you said doesn't benefit general highscorers
savestates is highly forbidden as it could create bugs for highscorers to cheat (retrying in the middle of the game)
Postby ToeFaceKiller » 2011.10.08 (08:31)
Chat? What function are you talkin about Unreality?
Postby TheRealOne » 2011.10.08 (16:34)
This may be true is people could hack it in other parts of the game. I was thinking that it would be an extra step on the end of the underclock slider. Like the slider would snap at -500 and then you could pull a little further to get "FBF" in and this state and only in this game state you could use rerecording and savestates. This would turn MDBing in to TASing so people other than Raif could make amazing runs and test innovations.
Postby Unreality » 2011.10.08 (17:13)
the new function is 70% done
highscorers will probably like it
edit:
done
NReality6g is up at n.infunity.com
it adds a shadow function for demo runs and your previous run
to make the demo shadow works you have to patiently finish watching a demo first (either loaded from scoreboard or your personal best)
this shadow function should hopefully help to create more 0ths
the map pack function inside main menu->highscores isn't finished yet
Users browsing this forum: No registered users and 43 guests
