Hi,
Loving the game, even more so now that I have discovered it does indeed save progress, but only after every few levels have been completed.
Unfortunately one of my pet gaming hates is playing the same level/s over again due to restrictive savepoints. I would be so much more likely to stick with the game if it were possible, somehow, to save progress after every level.
Doubt it's possible, but thought I'd pose the question anyhow.
Thanks
Save progress after every level?
When you're playing through a column, you are not able to save on individual levels in an episode (five maps). But once you beat the episode, you can play each map separately to improve your highscores if you wish. If you're having trouble completing the episodes, I suggest that you play them in practice mode. (You didn't hear this from me, but N comes with a list of cheat codes to let you skip episodes if you need to. However, if you do this you won't achieve transcendence.)
