Post a Run!
Postby ska » 2011.06.16 (06:53)
149768 hs. one of my best runs of the year to date imo. the laser drone timing and route was all my idea; i didn't even watch another demo...
215091 hs <- my map, please rate/comment too if you can :D
Postby daricque » 2011.06.22 (01:48)
205142 hs
Postby Raif » 2011.06.23 (20:11)
daricque wrote:205142 hs
Taken both hs and sr
NUMA Profile: http://nmaps.net/user/Tacit
Postby Serg » 2011.06.30 (12:54)
111-3 speedrun
(also, my first 0th run)
Postby TheRealOne » 2011.07.06 (04:39)
So I was playing the featured map and I was able to get up to the one way with out having to go to the right at the start. I just held left and got a abnormally high PJ. Back in the day I know Meta found something similar on a different map. I was able to get it twice, but I didn't record either time so I made this map: http://www.nmaps.net/215471 I was hoping someone would play it and complete it. I just want to test a few theories about the union of 3&7 tiles and possibly 2&6 tiles because I think there may be an odd glitch based on perfect footing so that you get some kind of RCJ or something to get extra height.
EDIT: obviously this map isn't hard if you run back to the right at the start. That isn't the point. Try completing it while just holding left from the start.
Postby ska » 2011.07.06 (08:09)
the link you posted was the same as the featured. I assume you meant this: http://www.nmaps.net/215471
Postby TheRealOne » 2011.07.06 (21:50)
ska wrote:the link you posted was the same as the featured. I assume you meant this: http://www.nmaps.net/215471
Yup thank you. So if anyone has some luck beating that while only hold left from the start. Let me know or post it on the map. I am quite interested in this trick/glitch
NUMA Profile: http://nmaps.net/user/Arctic_Pony
Postby Pony » 2011.07.07 (04:41)
got it just holding left, TRO
^sig by Izzy
Postby ska » 2011.07.11 (04:29)
215571 hs
Map: Nmaps.net
Postby daricque » 2011.07.13 (07:09)
3265 sp
Postby MiBeM » 2011.07.14 (16:51)
8369 speed. For some reason I'm really proud of that one.
a.k.a. MoleTrooper/Molenator
Speedruns and stuff
Postby 999_Springs » 2011.07.14 (18:11)
MiBeM wrote:8369 speed. For some reason I'm really proud of that one.
Taken by 61 frames. :P
Postby ska » 2011.07.14 (21:19)
you.. got... POWNED
Postby daricque » 2011.07.19 (12:30)
29116 speed
Postby amomentlikethis » 2011.07.20 (16:55)
2254 speed/hs
2255 speed
2259 speed/hs
2261 speed/hs
Pretty sure 2255 is improvable by 1 frame.
Hi.
Postby daricque » 2011.07.21 (02:15)
2254 taken
Postby golf » 2011.07.21 (05:38)
Had an interesting variation on the invincibility glitch when playing 2259. I completed the level, but I got launched up and left by the spring. Was able to run along the top of the normal doors, and the springs then didn't affect me afterwards. I think its because I hit the exit on the same frame as the launchpad. Unfortunately I couldn't get a replay to show.
Postby 999_Springs » 2011.07.21 (16:07)
golf wrote:Had an interesting variation on the invincibility glitch when playing 2259. I completed the level, but I got launched up and left by the spring. Was able to run along the top of the normal doors, and the springs then didn't affect me afterwards. I think its because I hit the exit on the same frame as the launchpad. Unfortunately I couldn't get a replay to show.
You can see it on scosglenn's run (3rd on highscore, 8th on speedrun). If you watch the replay you can control the ninja after it reaches the exit.
NUMA Profile: http://nmaps.net/user/apakenua
Postby Apakenua » 2011.07.22 (02:19)
215801 HS
Beat you, Golf. :)
What's a signature?
Postby golf » 2011.07.22 (13:48)
Beat you again, and TFK and glib to retake the 0th.
Postby amomentlikethis » 2011.07.24 (02:26)
215856 hs/sr :D
Hi.
Postby Raif » 2011.07.26 (14:27)
amomentlikethis wrote:215856 hs/sr :D
Taken. I held jump for too long, could have been 5 frames faster.
Postby 999_Springs » 2011.07.26 (21:03)
71 frames :D
Postby ToeFaceKiller » 2011.07.28 (19:15)
Everyone who doesn't submit a run to ROPP will be ROPPED by ska.
Postby amomentlikethis » 2011.08.02 (15:45)
Nice run, Moh ;-;
216060
:D
Hi.
