King Arthur's Gold - Windows build available NOW
Postby Geti » 2011.06.03 (13:57)
chocollama wrote:This is probably the dumbest question ever, but: Can you play offline? Like against computers?
Offline yes (hit start game and you're on your way) against computers no (or at least not until we code some bot AI)
smartalco wrote:You made RPS. Nice.
It's been a crazy week.
Slayr wrote:I still fail to connect to the master server.
Try now, hopefully the new master has fixed the issue, otherwise you'll have to wait until we set up the alternative server fetching system - it'll be less up to date but more reliable under stress.
God knows if i'm back.
Postby Geti » 2011.06.07 (02:48)
New build with a bunch of bugfixes and anti-hacking/griefing code. Also introduces some new bugs that we're working on fixing as we speak.
Changes build 45-49:
- smaller cursors
- new archer cursors
- servers list is read from cache incase master is down
- your player has a name tag at all times
- name tags are drawn above player
- fixed end game crash reason
- added healing heart spawning randomly from killed player [experimental]
- ladders can be built anywhere against backgrounds
- anything can be built directly on a castle background wall
- build block cursor snaps to build position
- disabled map border fadeout
- casting another vote time increased to 10 minutes
- default vote kick ban time increased to 60 minutes
- if player being voted disconnects he is banned automatically
- rcon authorized player cannot be kicked
- added basic speedhack protection
- added hand cursor on block placement
- autoupdater does chmod +x on .sh script files
- players banned by IP and additional unique ID
- local server always disconnects if joining foreign server
- fixed map dimensions being too small
- added thick stone resource block (3x stone)
- fixed infinite ground background ladders
- added autorestarting functionality on new build release
Postby Luminaflare » 2011.06.08 (14:44)
Have a sticky, nice work. I've yet to try it but from what I've glanced at I'd see about focusing on what makes your game different from Minecraft and Terraria. That said really nice entry in to this 'new' genre.
edit: Just started the game up, it doesn't fit in any x by 768 resolution or lower.
edit2: Oh god that's a lot of screen tearing, V-sync option please.
Postby Snuggletummy » 2011.06.08 (22:12)
Anyway, yeah, I've actually been playing this quite a fuckload lately. I've even found some servers that go up to 64 players, and sometimes 128 player, and let's face it, that becomes even more hectic. The only thing I wish for is basically what LF said above me, although I personally want support for my current resolution.
Postby Geti » 2011.06.11 (09:49)
Snuggletummy wrote:Anyway, yeah, I've actually been playing this quite a fuckload lately. I've even found some servers that go up to 64 players, and sometimes 128 player, and let's face it, that becomes even more hectic. The only thing I wish for is basically what LF said above me, although I personally want support for my current resolution.
What res do you use? You can edit the autoconfig.gm script to modify the resolution manually, and vsync should be on by default so I'm concerned about the tearing. non-default resolutions cause funny rendering at times (depending on your openGL implementation -> on your drivers) but whatever. There's a bunch of other handy options in there that we're yet to add to the GUI (like, basically all of them) so have a poke around.
Glad you like it, Snuggletummy. Hope to see you in-game ;)
Postby Geti » 2011.06.16 (03:19)
So yeah for those that haven't seen yet:
http://kagdev.tumblr.com/post/651981780 ... 7-released
Changes 51-57:
- fixed local player globally banned when bot banned
- my player is highlited in players list
- dead player collision radius is smaller
- build block cursor blink red if not enough material
- bomb now gibs people
- new death fall frame
- fixed ping kick not kicking
- bedrock layer lays on the bottom of each map
- modified bedrock look and amount
- bedrock bomb destroying leaves rocks
- bubble emote shows for 2 seconds after pressing key
- added mandatory vote kick typed reason
- vote caster displayed in vote box
- number of votes displayed
- vote dissapears if passes
- added radius of sight into earth
- fixed network errors and previous release lag
- added dirt block [experimental]
- added new config variable m_generator; specifies the map generator config file (default: “Scripts/generator.cfg”)
- knight destruction is 50% slower
- thick rock has its own destruction animation and takes longer to harvest
- thick rock takes 6 hits
- rock digging takes 5 hits
- ground digging takes 3 hits
- door needs 5 wood and 3 stone
- ladder needs 4 wood (10 in tree block)
- destroyed door gives 1 wood and 1 stone less
- trees are higher (more wood)
- sacks cannot go behind team tent
- cannot carry own team’s sack on to the enemy side of the map
- health is synced over network
- fixed sack team changed on client when picked up
- changed chat font
- increased small font size
- fixed mouse cursor stuck in menu
- if hit someone map isn’t hit
Cool stuff like this happens:
Enjoy.
Postby Donfuy » 2011.06.16 (15:07)
I got to play this yesterday, and it's really good. Addictive and fun.
Postby Geti » 2011.06.18 (00:55)
http://kagdev.tumblr.com/post/658234883 ... e-the-flag
More or less self explanatory.
We're leaning more towards a 1-flag mode for this release (and possibly all following free releases, we'll see how that goes) to keep the introductory gameplay simple.
Postby Geti » 2011.06.26 (15:33)
Postby Donfuy » 2011.07.31 (23:50)
I love you, Geti.
~addicted~
Postby Geti » 2011.08.20 (04:52)
http://kagdev.tumblr.com/post/913681219 ... d-released
Straightforward. About a month of work, ready to play and probably riddled with bugs for us to fix, haha. Enjoy.
Postby Snuggletummy » 2011.08.28 (07:16)
Holy hell man! The new HUD update looks fucking fantastic.
Postby Snuggletummy » 2011.09.04 (22:17)
Holy hell man. The home page for the game looks magnificent now.
Postby Geti » 2011.09.05 (13:48)
Hahah thanks ST. Still haven't caught you in-game yet :(
In other news maybe semi-related to "Holy hell":
We got KAG on Desura!
As such, we're having a sale and have been pushing out updates left and right, here's a recent screenshot and some changes for those of you who're a few builds behind:
  • New graphics
  • Netcode optimisation
  • Fall damage
  • Too many bugfixes to count
  • Human catapult
  • Arrow climbing
  • Pretty parallax backgrounds
  • Many French players
It's prettier, and hopefully more fun than ever - there's still work to do everywhere but it's exciting to see things moving along at the moment.
Note that KAG doesn't require Desura to run, you can just buy gold through them now, and it's cheaper that way for the time being I think :)
Pick up a gold account and every coming update ever for the price of lunch in the city!
(whee, buttons!)
Postby Slayr » 2011.09.05 (17:29)
Very impressive looking there Geti. An average rating of 9.5? Well done, that's awesome. I hope you continue to have success with all your other endeavors.
Postby  yahoozy » 2011.09.05 (20:26)
I love any game with an NTSC filter.
Postby Geti » 2011.09.06 (06:43)
@Slayr: Me too, cheers ;)
@Yahoozy: We'll have to start including it with the game then :P I don't think it's public yet.
Postby Snuggletummy » 2011.09.20 (21:01)
So, I had an idea regarding the almost mandatory building tutorial. Also, this sounded fantastic in my head, but maybe not on "paper" so to speak.
Essentially, it's an addition to the mandatory building tutorial. Think of it as an exam; you have a few sections to do before you can play online. Maybe Building, Fighting, and tactics, or maybe even an "apply what you learned" thing. Now, you're scored at the end of the session out of 100% and you're graded on a few factors. Like, how efficient your things were, or how many times you died. And it would do this for all three. And even if you did shitty, you could go back to try to get a better score. After all that, you would have one final test, and you'd basically have to answer a few extremely simple questions, like what it takes to make a ladder or something (Probably too complex, but whatever). In the end, you would have a final grade, and of course a letter grade to accompany the percentage.
In the last little bit of all this, you would, of course, go to find a server. Server hosts could set a required grade to be able to join their server, with the default being maybe a %60 or something..so essentially a D. So, you could have your competitive servers who want the best of the best, or maybe 90% and above, and you'd have your practice servers for those who are still learning the ropes.
So yeah, sorry if that seems too damned complex, but I personally think it'd make the game a little more interesting in terms of people not breaking shit, and hell, you could even make it so that it ISN'T mandatory, but for you to actually join certain servers, you'd have to do the tutorial and get a grade of some sort. And maybe even pointers to help people if they get a lower grade.
These Go Up to 11
Postby BBBB » 2011.11.19 (00:12)
Love the game! Im a bit confused about the full version... Do they get like extra perks during the game?
Postby Geti » 2012.02.02 (13:56)
Snuggletummy wrote:stuff.
sorry for taking so long to respond.
I actually really like that idea. I'll certainly consider it in the future when development has cooled down a little, haha.
@BBBB vaguely yes, in practice no. They can change their heads in-game for some customisation and will get access to the full version features when they're done, which free version players wont get access to, like the zombie mode.
