One Life Challenge: Revival
The rules are simple enough. You pick a NReality column and you start from the top and work your way downwards until you lose a life. When you die, the level that you got to represents your score. And then you start at the top all over again.
Note that this whole thing is going to rely on trust. There's no point lying on this - it's not going to matter in the end - and it's not that serious a challenge anyway. Any liars will, however, be prosecuted (whether or not they've been caught).
And all previous highscores have been killed. Like crappitrash's 45-4 on column 0. And Kablizzy's 56-1 on column 5.
I'll get this thing started.
Column 00
0th - ari22hoops: 09-0
1st - aerodynamic: 08-2
2nd - Kablizzy: 06-1
3rd - mediate: 05-4
4th - 999_Springs: 05-3
- Rose: 05-3
6th - Seneschal: 04-4
7th - ToeFaceKiller: 03-2
8th - mohamedraif: 03-1
9th - cogg23: 02-4
Column 10
0th - aerodynamic: 18-3
1st - 999_Springs: 15-0
2nd - cogg23: 13-3
3rd - Rose: 11-2
4th - mohamedraif: 10-1 (How!?)
Column 20
0th - aerodynamic: 24-2
1st - cogg23: 23-3
2nd - 999_Springs: 23-0
3rd - ari22hoops: 22-3
4th - mohamedraif: 20-3
Column 30
0th - 999_Springs: 35-0 ( >_< )
1st - ska: 34-0
2nd - aerodynamic: 32-4
3rd - mohamedraif: 31-2
Column 40
0th - cogg23: 44-4
1st - aerodynamic: 43-4
Column 50
0th - ari22hoops: 52-2
- aerodynamic: 52-2
2nd - cogg23: 51-3
3rd - mohamedraif: 50-1
Column 60
0th - cogg23: 64-2
1st - 999_Springs: 61-4
2nd - aerodynamic: 60-3
3rd - mohamedraif: 60-1
Column 70
0th - cogg23: 72-4
1st - 999_Springs: 72-3
- mediate: 72-3
3rd - TheRealOne: 71-3
4th - aerodynamic: 71-2
5th - mohamedraif: 70-2
Column 80
0th - aerodynamic: 81-3
1st - 999_Springs: 80-4
2nd - mohamedraif: 80-1
Column 90
0th - ari22hoops: 93-4
1st - 999_Springs: 92-3
2nd - aerodynamic: 92-0
Column 100
0th - ari22hoops: 100-3
- aerodynamic: 100-3
Column 110
0th - aerodynamic: 110-2
Column 120
0th - 999_Springs: 123-3
1st - aerodynamic: 122-4
Column 130
0th - 999_Springs: 137-0
1st - ari22hoops: 136-3
2nd - aerodynamic: 133-4
Column 140
0th - aerodynamic: 143-0 (...)
Column 150
0th - aerodynamic: 151-2
Column 160
0th - aerodynamic: 161-2
1st - mediate: 160-3
Column 170
0th - 999_Springs: 172-2
1st - mediate: 170-3
Column 180
0th - mediate: 180-3
Column 190
0th - sayko: 190-4
- mediate: 190-4
Oh, and good luck. You're going to need it.
Also, I was going to create a bunch of silly polls to rival vankusss's Blur 4 polls but since this forum messes up all the poll options every time I edit a poll I decided against it.
...Mother. F... Fine. I'll do this again.999_Springs wrote:And Kablizzy's 56-2 on column 5.
...Wait, we're doing the Unreality levels too? Bahahahahahaha. Oh, this is sa-weet.
There is a way to have proofs: start each run with new .sol, submit the .sol with zero deaths. Of course, I'm not suggesting to follow it and/or making it a rule (that would be silly), just saying.999_Springs wrote:Note that this whole thing is going to rely on trust.
This is still a great idea, and I'm glad to see it revived; I might participate again.
Unfortunately, since you only know when you've lost when you die, then you'd have to submit a .sol with only one death... But then, people would continue on through runs with only a single death, pushing their luck onwards from there. We've had no problems with the trust system before - This community is good for it.atomizer wrote:There is a way to have proofs: start each run with new .sol, submit the .sol with zero deaths. Of course, I'm not suggesting to follow it and/or making it a rule (that would be silly), just saying.999_Springs wrote:Note that this whole thing is going to rely on trust.
- NUMA Profile: http://nmaps.net/user/sayko
10-1
20-3
31-2
40-0
50-1
60-1
70-2
80-1
90-0
I obviously suck at not dying.
EDIT: Died on 05-3. So .. I guess I get there and ended there?
Go on, give it a try and I accept no responsibility if you end up destroying your laptop (and window pane) in the process.
- NUMA Profile: http://nmaps.net/user/aerodynamic
18-3! (really thought I was gonna go all the way for a second there...)
This is pretty fun, makes the easier levels a lot more nerve-wracking than usual.
Edit:
3-4 8-2
18-3
20-3 (...) 24-2
32-2 32-4
42-1 43-4 (...really?)
52-2
60-3
71-2 (this isn't going so well anymore...)
81-3
90-0 92-0
100-3
110-2 (wow, forget that)
122-4
133-4
143-0 (in response to your "..." 999, only 141-0 was a real nuisance for me, but I don't plan on revisiting this column real soon, nonetheless)
151-2
161-2
171-1 (this column doesn't seem too bad, but this level is tricky to beat on the first try, and 170-3 together with 170-4 can be bothersome)
182-0 (drone levels always get me)
192-1 (spent some time on this, and I don't see myself getting so lucky on 192-0 the next time round, so I'm just done with this for now)
- Lords a-Leaping
- NUMA Profile: http://nmaps.net/user/guardian_of_chaos
13-3
23-3
30-0 (lol?)
44-4
51-3
64-2
72-4
Must we to progress further than first episode on columns? (Like 191)
Edit: I checked out other players' posts and i see it's not a must. Problem solved.
Also:
180-3; 170-3; 190-4; 160-3;
EDIT: No sense in making a new post ... 72-3.
Dude, if you're gonna beat me, do it by more than one level! Gah, guess I got some work to do...ari22hoops wrote:After many attempts, I present my newest records.
8-3
aha, niceari22hoops wrote: I'll work on extending that record for you though.
I'm meant to be the best in the world at Ep33 and I can't one-life it... fail.
