My sigs
Postby NicNac14 » 2008.11.10 (19:10)
true.
Postby Why Me » 2008.11.10 (19:35)
Well I did say that I was still learning. I'll test out some stuff right now.
EDIT: And also I was wondering how to change a certain color invisible. THat way I could just take a normal pic with a white background and the background invisible. Anyone know how to do that?
Postby NicNac14 » 2008.11.10 (19:37)
tats why i gave you the advice... duh.. :P
Postby Why Me » 2008.11.10 (19:53)
How's this? It's my first try right now. I'll try again later.
Postby Izzy » 2008.11.10 (20:07)
GTM wrote:Use Gaussian blur instead of motion blur. it gives a much more balanced effect imo.
Smudge Smudge Smudge.
Postby NicNac14 » 2008.11.10 (20:09)
uhmmm... do want the background colour different cause then u use bucket tool.
if you want a invisible layer with an object then duplicate and then use magic want to highlight the stuff you want deleted and the erase it. delete the background and then add your own. any other question then just pm me and i'll answer...
oh and check out my sigs please?
thanx...
oh and the car looks really cool...
Postby Why Me » 2008.11.10 (21:08)
I don't have any smudge brushes. And when I try the settings that I've found in tutorials, it only vreates lines, and it doesn't smudge anything.
NicNac14 wrote:uhmmm... do want the background colour different cause then u use bucket tool.
For some reason the bucket tool doesn't work on my comp.
NicNac14 wrote:if you want a invisible layer with an object then duplicate and then use magic want to highlight the stuff you want deleted and the erase it. delete the background and then add your own.
Thanks.
NicNac14 wrote:any other question then just pm me and i'll answer...
Thanks.
NicNac14 wrote:oh and check out my sigs please?
No problem.
NicNac14 wrote:oh and the car looks really cool...
I got it in planetrenders.net
Postby NicNac14 » 2008.11.10 (21:51)
well if the bucket tool doesn't work go up in edit and select fill then add a gradient or sometin' its the little black and white circle under layers...
very usefull
the arrows show what..
click here to see...
here..
Postby Why Me » 2008.11.10 (22:42)
Okay, here's another sig I just made. If anyone wants it, go ahead. Tell me what you think.
Postby Why Me » 2008.11.11 (04:18)
I made a random sig for NicNac because I felt like it. I used the smudge brush. What do you think?
Postby Why Me » 2008.11.11 (04:38)
Another one I just made. Anyone can use this.
Postby Why Me » 2008.11.11 (07:09)
Dude....I just spent, like, 2 and a half hours making this sig. It is EPIC:
Postby NicNac14 » 2008.11.11 (10:40)
now that is pretty cool...
Why Me wrote:Dude....I just spent, like, 2 and a half hours making this sig. It is EPIC:
and the sig you made for me reminds me of one of my firsts...
ur getting better..
Why Me wrote:I made a random sig for NicNac because I felt like it. I used the smudge brush. What do you think?
Postby Why Me » 2008.11.11 (16:08)
Hooray! Now I know how to be good at making sigs. Depends what they are, though.
Postby isaacx » 2008.11.11 (16:19)
i like that one, if your takeing requests, may i have one like that?
Postby Why Me » 2008.11.11 (16:25)
Yeah, I'll try. What would you like it of? I just want to know because I can't make a really good one without knowing what it should be a picture of.
Postby Why Me » 2008.11.11 (22:18)
@issacx: How's this? I found a cool render, and made this:
Like it?
Postby Why Me » 2008.11.13 (01:41)
Has anyone seen the sig I made yesterday? I'm still taking requests, BTW.
Postby origami_alligator » 2008.11.13 (20:01)
Assuming you have a PC, to make transparent background you have to separate your layers. Do not place any renders in the same layer as the background, or else transparency becomes extremely difficult. To make a brand new layer click the button that appears next to the trashcan icon in the layer menu.
From here, make your sig as you want to. It helps to create new layers every time you add a new element to your signature, so that if you make a mistake you can simply just erase that layer or delete it instead of having to undo a bunch.
When you are all done, click the "eye" icon next to the layer that you don't want to see anymore (the background layer of white for example). The layer should disappear entirely and you should see gray and white squares in the background.
Now, go to File>Save for web... and once you are in there be sure to find the format you will be saving in and choose PNG-24. Be sure to click the Transparency checkbox. When you are finished saving it then upload it and post it here!
Hope that was explanatory enough.
-southpaw-
Postby isaacx » 2008.11.13 (20:33)
thanks, i like it, i think i might actually use it
Postby Why Me » 2008.11.14 (01:57)
Manus Australis wrote:Assuming you have a PC, to make transparent background you have to separate your layers. Do not place any renders in the same layer as the background, or else transparency becomes extremely difficult. To make a brand new layer click the button that appears next to the trashcan icon in the layer menu.
-southpaw-
Well I know how to make new layers, and I always use multiple layers. I was really asking how to change one single color in a picture to transparent. For example, say I was looking for a picture, but I couldn't find any renders, and I had to use a picture that had a built-in white background. How would I change it so that the already built-in white background would disappear, and I would be left with a render from what originally was a picture?
Postby Why Me » 2008.11.14 (05:16)
Does anybody want to have a sig made by me?
Postby Why Me » 2008.11.14 (05:59)
Here's a sig that I just made. It's for Isaacx. You don't have to use it; I just felt like making it, and yours was the only name that would work that I tried.
Postby origami_alligator » 2008.11.16 (10:29)
Why Me wrote:Well I know how to make new layers, and I always use multiple layers. I was really asking how to change one single color in a picture to transparent. For example, say I was looking for a picture, but I couldn't find any renders, and I had to use a picture that had a built-in white background. How would I change it so that the already built-in white background would disappear, and I would be left with a render from what originally was a picture?
mmm, things get tricky here. You'll want to familiarize yourself with the pen tool. It allows you to make selections of the borders you want instead of by color or shape. If you zoom in to maximum zoom and then select the pen tool you need only select the pixels of the outside border of the image and continue selecting anywhere from 1 to 100 pixels depending on how straight of a line the pixels make when you're selecting.
When you've made your way around the image then you select the first place you clicked and it will make a mask. (Did I forget to mention you have to lower the opacity of the Pen Tool Layer to zero so you can see what you're selecting?) Set the opacity to 100%, click the "eye" icon next to the layer with the render and then use the magic wand tool to select the color of the mask.
Disappear the mask layer, then reappear the render layer. With the marquee tool selected, right-click on the selection and choose Make New Layer Via Cut. Then delete the white background layer.
Some notes:
This method is tedious and long and usually leaves a pixelly white border around the outer edge, which can be cleared up with the eraser tool and a slight blur. Otherwise this is the most effective method that I've personally used. No doubt there are more effective ways to do so. Searching the internet might come up with some good results.
Hope that helps,
-southpaw-
Postby origami_alligator » 2008.11.17 (04:18)
Why Me is now using this thread for his sigs. I suggest you suggest sigs from him from there.
-southpaw-
