Post a Run!
- Lords a-Leaping
- NUMA Profile: http://nmaps.net/user/guardian_of_chaos
there's always a bigger fish...ari22hoops wrote:takencogg23 wrote:212856 hs
Taken by a second/40frames.MiBeM wrote:12869 speed. I'm so happy, I can do that trick now :3
it's more of a saunter to be honest...l'oeuvre wrote:
Post a run, right?
- On the Psychic Highway
AHA! My Nreality is down (On 3 computers... go figure. :| ) Anyhow, I found a few screenshots of the rankings. Check my NUMA profile.TheRealOne wrote:Ah... It may help if you posted the map IDs...ThisIsApakenua wrote:I had an amazing one, I beat Meta And Golfkid. Other good speedrunners too, and I bet them all. IT was a a tileset. Another I beat had Vankuss and Meta.
Anyways. Decent SR here: 212572 Someone out do me.
donedaricque wrote:94999 hs, sr
Slaters gonna slate.ska wrote:it's more of a saunter to be honest...l'oeuvre wrote:
Post a run, right?
TheRealOne wrote:Slaters gonna slate.
edit: 201491 hs/sr
nice runs! took the last 0thdaricque wrote:213000 sr
213003 sr
213005 hs (easy)
Taken, with 144. Probably 2-3 frames left.daricque wrote:213068 sp
or 4... whatever ;)TheRealOne wrote:Taken, with 144. Probably 2-3 frames left.daricque wrote:213068 sp
or 5ska wrote:or 4... whatever ;)TheRealOne wrote:Taken, with 144. Probably 2-3 frames left.daricque wrote:213068 sp
- Member
213041 sp (190 frames)
I'll submit my run when nReality is back.
186 on 213041 :-)
I think that means you took the 0th by a frame; in which case, nice job!ToeFaceKiller wrote:What was the final score on 213068? I just got 138
Edit: NReality is back up so you can submit it :D
took both.. but someone is bound to shave off more frames...daricque wrote:213158 sp
213191 sp
edit: one for the road: 165994 sr
edit 2: 144195 hs "if you nail the cj at the top you could crack 600 frames. :)"
