MAPDRAFT (x_x)
- Maxwell Smart
- NUMA Profile: http://nmaps.net/user/sayko
My Cup Runneth Over by kkstrong
Rule
If Applicable, multiply the number of tiles of each type you are assigned by 3. If you
cannot do this because it causes more than 713 tiles in the map, ignore this rule for
that specific tile.
Life247 is the coolest. by Life247
X 'E' tiles
X Gold
'X' is equal to your age.
Scapeshift
Tiles
Use the Tiles of your most recent map posted on NUMA (BEFORE this round started) for
your mapdraft map this round. Any tiles you receive in your booster pack remain the same.
But the third one says "use your last map's tiles". So what should i do? Do i have to ignore other packs' rules about tiles? Or to add my recent map's tiles 23 more E tiles (i've used in that map only one E tile)?
First pack should be considered last, because it's a "general" rule (if I got it right). If so, the second pack gives you 24 E tiles and 24 gold. The third pack gives you one more E tile, 25 total. The first pack brings this to 25 * 3 = 75 E tiles. So, you should use 24 gold pieces and 75 E tiles.sayko wrote:First pack says "every type of tiles will be a multiple of 3" and second one says "24 (my age) E tiles. 24 is a multiple of 3, so no problem with these 2 packs.
You get exactly one exit unless one of your packs specify otherwise (for example, I know at least one pack exists that gives you 5 exits. In that case, you would have to use exactly 5). Same thing applies to ninjas. You can only use the tiles allocated to you in your packs; everything else MUST be blank.koipen wrote:Are exits included in packs automaticly, or are they only there if mentioned? Can I fill any space that is not filled by the tiles in the pack with any tiles I want?
Multiply your tiles from your last map by 3, as well as multiplying whatever other tiles you got.sayko wrote:I've received my packs. 3 of them are paling me about tiles. But i'm confused about especially one of them. CLICK to see thoes packs.First pack says "every type of tiles will be a multiple of 3" and second one says "24 (my age) E tiles. 24 is a multiple of 3, so no problem with these 2 packs.My Cup Runneth Over by kkstrong
Rule
that specific tile.
X 'E' tiles
X Gold
Scapeshift
Tiles
Some of you have received your packs and some haven't. I'm getting them to the rest of you as quickly as I can when I'm not doing homework etc.
- MBTI Type: ISFP
Sig by Aidiera.
- NUMA Profile: http://nmaps.net/user/lsudny
- MBTI Type: ISFP
That is why I decline the title of Iron Cook and accept only the lesser title of Zinc Saucier, which I just made up. Also, it comes with double prize money!
Sig by Aidiera.
Where do I get?
zoasBE@NUMA
VODKALOVER@NUMA
the23@NUMA
insatiable@NUMA
COMMANDOS
//stoneman
9000
:3
CORaN
Astro Chimp
My 100 Vehemence 4 Maps
MOSS
Vehemence 4 as THE23
VODKALOVER Session One
VODKALOVER Session Two
- Phei Phei Pho Phum
Yeah, you'll get them via PM.lsudny wrote:Where do I receive the packs? Here, on the forums?
zoasBE wrote:I have not received my packs.
Where do I get?
I wrote:Some of you have received your packs and some haven't. I'm getting them to the rest of you as quickly as I can when I'm not doing homework etc.
You, Erik, and anyone else will be added starting next round. This is an indefinitely continuing thing, so it's not an issue to join after Round 1. In other words, this isn't a tournament or anything.1211 wrote:Is it too late too join?
Well, since I've been late getting out the packs, I'll give you guys until Mon. March 7. That'll give even the last people to receive the packs a good week and some change.Pheidippides wrote:Just got my packs. When are the maps due?
You're in starting with Round 2.ENT474 wrote:Have I been added?
- NUMA Profile: http://nmaps.net/user/apse
is there a rule regarding starting a map full of tiles or starting a map with no tiles at all (i.e. pressing H or J in the debug menu)?
i have an exceptionally gay pack which requires me to use 20 D tiles which, if starting with a blank map, is rendered useless.
what can i do?
The point of that pack IS that it's useless. Sorry. :p Basically, it's a tile pack that gives you nothing.aapse wrote:hmmm.
what can i do?
OKAY, SO EVERYONE SHOULD HAVE THEIR PACKS BY NOW. It's long overdue, I know. You all have until MONDAY, MARCH 7. Good luck. If for some reason you don't have your packs, just post here or PM me and I'll get them to you.
Also, I know I didn't say this before, but it would help if you posted the packs you had to use for your map either in your map description, in a comment on your map, or in this thread. Not only does this make it easier for me, but the other judges can't see my PMs.
right ._.eevee wrote:The point of that pack IS that it's useless. Sorry. :p Basically, it's a tile pack that gives you nothing.
Heh, I didn't make the pack. You'll have to take it up with PALEMOON if you don't like it :paapse wrote:right ._.eevee wrote:The point of that pack IS that it's useless. Sorry. :p Basically, it's a tile pack that gives you nothing.
- Member
- Oops Pow Surprise
Just not enough people. by erik_player
Items
4 Ninjas.
25 gold.
1 chaingun drone.
1 locked door.
Trembling Heart by Diamondeye
Rule
All enemies besides Mines must be placed so that they only influence the optional
routes in the map (there must be a "safe" way thru the map).
Octane by kkstrong
Tiles
80 'E' tiles
8 '1' tiles
8 '2' tiles
8 '3' tiles
8 '4' tiles
8 '5' tiles
8 '6' tiles
8 '7' tiles
8 '8' tiles
Pick Your Poison
Booster
15 Floorguards and 1 'Seven' Tile
OR
15 Thwumps and 1 'Three' Tile
Questions:
1. I have to use the 4 packs in the same map, right?. And I can not use anything more than what they ordered, right?
2. In Trembling Heart by Diamondeye: The safe route can be solely and exclusively to complete the map. The gold I can include in the non-secure route would be the AGD route with enemies?
zoasBE@NUMA
VODKALOVER@NUMA
the23@NUMA
insatiable@NUMA
COMMANDOS
//stoneman
9000
:3
CORaN
Astro Chimp
MOSS
This will continue on as long as possible. :DAvatar_Fanatic wrote:How many rounds will there be? (This is really fun so far!) :D
D: I'll send them to you as soon as I'm done with this post.大見解 wrote:I do not have a pack.
1. Yes.zoasBE wrote:My Packs are insane !!!
Items
4 Ninjas.
25 gold.
1 chaingun drone.
1 locked door.
Rule
Octane by kkstrong
Tiles
80 'E' tiles
8 '1' tiles
8 '2' tiles
8 '3' tiles
8 '4' tiles
8 '5' tiles
8 '6' tiles
8 '7' tiles
8 '8' tiles
Pick Your Poison
Booster
OR
Questions:
2. Sure, you can do that. As long as there's a non-threatening way through the map, you're all good.
- Oops Pow Surprise
