Problem submitting map.
Postby Tryptafeind » 2010.12.05 (15:21)
I've been working on this nifty map deemed "The High Life," but when I submit it to NUMA, it informs me that there are too many characters before the "|," and that's not an easy fix, methinks.... what's the deal?
"A word to the wise is infuriating."
- Hunter S. Thompson
Postby 大見解 » 2010.12.05 (15:54)
most likely, you have an extra character, either a ^, or ; or : or ! or | of some sort. basically, theres an error somewhere in your level data
Postby Scrivener » 2010.12.05 (16:10)
Means you have too much tiledata. Make sure it looks right in the editor and if it does try removing the last symbol before the |
Postby Tryptafeind » 2010.12.07 (13:08)
D:
nothing has helped yet.
I could post the code here...
Postby krusch » 2010.12.07 (23:57)
Try posting it here, either in quote tags or attached as a .txt
I know LV is good at fixing dodgy data, somebody should be able to look at it for you.
Postby 大見解 » 2010.12.08 (00:36)
entwilight wrote:Try posting it here, either in quote tags or attached as a .txt
no not in a quote tag. bad idea.
Postby Kablizzy » 2010.12.08 (02:55)
Either myself or LV can edit it out correctly. We're both pretty equally well-versed in reading code.
Postby krusch » 2010.12.08 (04:47)
My apologies, you're right. Fancy new forums.
Postby Tryptafeind » 2011.01.27 (14:37)
Postby lord_day » 2011.01.27 (15:06)
Try that. I think you were missing some 0's at the end.
Postby Tryptafeind » 2011.01.27 (18:07)
oh my fucking god thank you
thank you thank you thank you
<3
