This program let you add numa downloaded maps into N with ease. The program has NUMA-like interface. I have writen when i have found numa website.This program also need Microsoft .NET 3.5 framework. If the program did not run go and download
http://www.microsoft.com/downloads/en/d ... laylang=en
By Omar Zanhour
feel free to send suggestions, and ideas, or report bugs.
Download
Version history :
NUMA AddThis 0.2
Added New feature : Paste game into text box automatically when copied from numa website .
Added New feature : The software now can detect whether entered map data is valid or not .
Added New feature : The program does not be " always on top " when you click Run the game .
NUMA AddThis 0.1
Initial Release
Numa AddThis
- Lucky
Neat program! I personally play in debug mode most of the time, but I can very easily see a lot of people using this. My only suggestion would be to craft this into a browser plug in, so rather than having to run a program, you could just click a button on somewhere on a map's page (or wherever you want to put it).
Regardless, fantastic job!
EDIT: When I search for my userlevels file, I can't seem to find it. The search menu that pops up looks for "Userlevel Files", when I believe it should just be looking for "Text Documents" or something similar to that (just going off of memory here). The search has filtered out all files that aren't "Userlevel Files", and I'm not sure that's a valid extension (unless you've got it directing towards something that I'm not aware of).
See this picture if my poorly worded explanation failed.
http://i.imgur.com/uLlit.png
- Lucky
Thanks.I, SlappyMcGee wrote:Neat program! I personally play in debug mode most of the time, but I can very easily see a lot of people using this. My only suggestion would be to craft this into a browser plug in, so rather than having to run a program, you could just click a button on somewhere on a map's page (or wherever you want to put it).
I've thought about this idea, but I did not learn yet how to make a browser plug in.
This guy knows a lot about plug ins, might be worth it to give him a message. He created the very popular "Favorite Authors Plug-in". Also, I edited my first post in this thread, I found a potential error in your program D:diantahoc wrote:Thanks.I, SlappyMcGee wrote:Neat program! I personally play in debug mode most of the time, but I can very easily see a lot of people using this. My only suggestion would be to craft this into a browser plug in, so rather than having to run a program, you could just click a button on somewhere on a map's page (or wherever you want to put it).
- Lucky
I have saw the picture, and i have assumed that you have not enabled showing extension of known file names. For example, if you have enabled it, the readme file should be readme.txt file. The program looks for "userlevels.txt" file. I guess then that your "userlevels.txt" file has a real name wish is "userlevels.txt.txt".I, SlappyMcGee wrote:This guy knows a lot about plug ins, might be worth it to give him a message. He created the very popular "Favorite Authors Plug-in". Also, I edited my first post in this thread, I found a potential error in your program D:diantahoc wrote:Thanks.I, SlappyMcGee wrote:Neat program! I personally play in debug mode most of the time, but I can very easily see a lot of people using this. My only suggestion would be to craft this into a browser plug in, so rather than having to run a program, you could just click a button on somewhere on a map's page (or wherever you want to put it).
Oof. You are correct, changed the title and your program found it. Ignore me, heh.diantahoc wrote:I have saw the picture, and i have assumed that you have not enabled showing extension of known file names. For example, if you have enabled it, the readme file should be readme.txt file. The program looks for "userlevels.txt" file. I guess then that your "userlevels.txt" file has a real name wish is "userlevels.txt.txt".
(I kept messing up the quote tags if you saw any of those posts)
That is amazingly neat! You should totally contact sidke and see if he can work a plugin around it.
- Lucky
Destiny wrote:That is amazingly neat! You should totally contact sidke and see if he can work a plugin around it.
OK thanks.
