The NReality Mod Help Thread
||||11,_icon,[half your image width]^[half your image height]^[thwump url];8,_icon,[half your image width]^[half your image height]^[ninja image url]
If you want a more detailed explanation, keep reading.
The four bars denote that this code is for object mods. All object mods start with number that corresponds with a certain object. Here, we use 11 and 8 for thwump and ninja, respectively. After the number is the mod to be used, which is _icon in this case. After that are the options for the specific mod. for _icon, they are image offset x, image offset y, and image url. When nreality loads the image, it won't center it on the object. That is why we make the offsets half of the image's height and width.
- NUMA Profile: http://nmaps.net/user/kyozo_43
I need to know ... if it is possible ... how I would go about making a rotating laser drone (or a normal one even) shoot in one direction (downwards) in increments of about 5 seconds?
- MBTI Type: ESTP
Alright ...SampsonHammerjack wrote:Elaborate.
This is the map I'm working on -
Now, it's an NReality Imagemap.
I want it to have 4 laser drones, shooting downwards, in sections (shoot, stop, shoot, stop, etc.).
They are supposed to be where those green things are on the 'roof' of the 'bank'.
If you could help me that would be great.
- Quarks
Sorry for the lack of details, and there's probably a more elegant way anyway.
Hmm, alright ...tempaccount1 wrote:It is certainly possible, as per Lightnings. I haven't tried it myself (or I tried it but it caused N to crash, probably because I made a mistake), but you can probably create a rotating laser drone with a downward facing laser and zero rotation speed, and a coordinate path and a zero speed. Also, have a regular zap drone hidden in the boundary of the map periodically activating an area trigger that causes the laser drone to stop and start moving in intervals - it should also cause the laser drone to disappear from the map during these intervals.
I'll just wait for kkstrong's approach, but if he doesn't reply, I'll use this :P
- Richard Richards
Is it possible to have 2 object image mods? I want a ninja one and a thwump on in the same map but for the life of me it wont work
Yes you have to take an image from the internet, it won't work if it is saved on your computer. If you made a custom image, you can always use http://www.imageshack.us to upload your image, then manage to get the picture url link. (To retrieve the link, you need to make sure the picture is the only thing on the page, for example: http://img200.imageshack.us/img200/2041/foreground.png. This is known as the "direct" link.)Epic4ever wrote:I have been trying forever to put in a image in one of my maps but i don´t get it to work. Do i take the URL from the Internet or what?
How Nreality code works:impagma wrote:Is it possible to have 2 object image mods? I want a ninja one and a thwump on in the same map but for the life of me it wont work
tiledata|objectdata|bgImage|fgImage|NRealityMapType|objectMod|playerMod|AreaTrigger
In the objectMod location, you place the icon code for the thwump. In the playerMod location, you place the icon code for the ninja. The code looks like:
||||objectType,_icon,x_offset^y_offset^url
Thwumps have an object type #11. So your thwump icon code looks like: 11,_icon,x_offset^y_offset^url. The offset is used to position the icon more perfectly onto the object in question, and use ordinary digits to do so :-3, -2, -1, 1, 2, 3. If you don't use offset you'll use something like this: 11,_icon,^^url. The url is the picture url link, and works the same as how I described placing images above with epic4ever, though obviously the image is much smaller.
The Ninja does not have an object type (the only object that doesn't) so the code should look like: _icon,x_offset^y_offset^url. or _icon,^^url with no offset.
Also note that when two mods that you are using fit into the same category, then they belong in the same category. They have to be separated by semicolons (as opposed to exclamation marks in the objectdata section). So for example two object icons would look like: ||||objectType,_icon,x_offset^y_offset^url;objectType,_icon,x_offset^y_offset^url
- NUMA Profile: http://nmaps.net/user/TheBlackLion
Making text drones is quite simple but I can't figure how to use them with triggers (on and off). It would be really nice if someone could explain me how to.
And is it possible to make them appear/disappear just with time? I mean the text drone appear at x frames/seconds and disappear after y frames/seconds or something like that.
- Richard Richards
- Richard Richards
Mod properties: The ninja hits the door buttons and goes on and the one ways disappear for like 5 sec and then reappear
Question: Do I have to write anything in the box that says Special Off/On?
- Not actually an admin
I'm not quite sure what you're asking, here is an example...Epic4ever wrote:Mod: Regular trigger for 2 one ways
Tell me if it is close to what you're going for...
- Richard Richards
Do I make any sense?
Okay, that is insanely difficult, i can think of a way to do it but it would take awhile to test everything & then it might not even work, maybe someone else can help youEpic4ever wrote:Actually that is exactly what I want, but no actually I want it to be the other way around that when you take the switch the one way appears and stays on until for example i have pressed another switch!
So basically, the One-Way starts off invisible (i can't make this), i can make it so the One-Way disappears as soon as the map starts but you will still be able to see it before starting the map (this will be so boring to make), i can do the same with a locked door, i may be able to do it with a trap so that it starts off invisible anyway (but i've tried to do this with a trap in the past & couldn't get it to work), i'll ask NachoCheese if he can help you if he comes on IRC (& not just coming on for 2 seconds saying "YEAAAAAAAAAAAAAAAAH" then leaving)
- Richard Richards
Okay, yeah I can believe that what I´m asking is kinda impossible but the thing is I´m making a kradda and the guy is going through a path that he already had used and I cant use a locked or a trap door because there is a rocket chasing..! And if I have a trap door then the rocket explodes, if I have a normal door I fuck up the beginning, + the ninja is being pushed by a thwump and so that is the situation...!!Paradox-Dragon wrote:Okay, that is insanely difficult, i can think of a way to do it but it would take awhile to test everything & then it might not even work, maybe someone else can help youEpic4ever wrote:Actually that is exactly what I want, but no actually I want it to be the other way around that when you take the switch the one way appears and stays on until for example i have pressed another switch!
Oh, well if that's the case...Epic4ever wrote:Okay, yeah I can believe that what I´m asking is kinda impossible but the thing is I´m making a kradda and the guy is going through a path that he already had used and I cant use a locked or a trap door because there is a rocket chasing..! And if I have a trap door then the rocket explodes, if I have a normal door I fuck up the beginning, + the ninja is being pushed by a thwump and so that is the situation...!!Paradox-Dragon wrote:Okay, that is insanely difficult, i can think of a way to do it but it would take awhile to test everything & then it might not even work, maybe someone else can help youEpic4ever wrote:Actually that is exactly what I want, but no actually I want it to be the other way around that when you take the switch the one way appears and stays on until for example i have pressed another switch!
Then i can probably make something different, can i see the map? you can PM it to me...
with what you just said, i can think of a few ways to make it work that are easier than what you're asking, i just need to be able to see exactly what i need to out into where, if that's okay with you
Now, it can either be like that or rotation, it can happen randomly (area trigger) or it can happen with a switch (harder than area trigger), it could also be an area trigger that activates a switch at the same time to look like a switch, it could even be a trap switch (easy, please choose this one if you want a trigger), if you want rotation i'll have to do some testing but i should be able to get it in 5-30 minutes
- Richard Richards
- NUMA Profile: http://nmaps.net/user/Ors_II
My NUMA user: http://www.nmaps.net/user/Ors_II
Interested about advanced N-arts? Get a link to N-Artist v1.0 here.
- NUMA Profile: http://nmaps.net/user/Pixelwiz
