"I don't know where I am!"
What should I do?
Inspired wrote:Look under the bed you woke up on for anything that could be beneficial to your journey.
reventrøpe wrote:Take the pillowcase off the pillow and stick it over your head as an improvised air filter. Nerve gas could come flooding into this room at any minute.
T̷s͢uk̕a͡t͜ư wrote:That looks like a pull-handle on that door, meaning the hinges are on your side. Find something to pop them hinges out.
the voice said "good morning", so it's most probably not the afternoon.Universezero wrote:It could be 16:49.
Look around the room for a camera. See if you can cover the lens with anything, or otherwise prevent it from working.
begin quest to see if there's anything else in the room other than the bed.
Is the clock counting backwards?
Open the under-the-sink cabinet things and see if there's anything inside. also, carry around the toothbrush and deodorant thing just in case. Finally, go see if there's anything in, around, behind, or in the water tank of the toilet
