The Weekly Challenge [Contest finished]
- NUMA Profile: http://nmaps.net/user/Chrdrenkmann
- Eleven Squared
- NUMA Profile: http://nmaps.net/user/nevershine
- NUMA Profile: http://www.nmaps.net/user/da_guru
The theme's not prohibiting the use of other enemies, it just sets a minimum of 10 zap/seeker drones, so yes it's ok. However I'd say 10 enemies is quite a lot. Adding some more may easily make gameplay overpowering.nevershine wrote:are additional gauss/rockets OK?
- Eleven Squared
- These Go Up to 11
- NUMA Profile: http://nmaps.net/user/firetamer2
The worst part is that a third of my maps could be submitted to this.
:x
:x
- NUMA Profile: http://nmaps.net/user/TheBlackLion
So try to make a mix of the better ideas you used with this theme ^^firetamer2 wrote:The worst part is that a third of my maps could be submitted to this.
:x
I've a Tumblr were I post pictures, texts, videos and musics.
Who judges this round?
I don't have a signature.
TheBlackLion and me, Sunset makes the ded.Chrdrenkmann wrote:Who judges this round?
So first round is over and we have 10 entries, it's quite good and i hope people will keep an interrest for it.
Now second round begin (check first post) and first round results will be posted in the week!
- Semimember
- NUMA Profile: http://nmaps.net/user/NachoCheese
For this weeks challenge, can I use Nreality? And if I am allowed, if I co-ordinate pathed a mine or something, would I only have to z-snap the start position, or all positions in the path?
- NUMA Profile: http://nmaps.net/user/aerodynamic
Can you we use code edits to "z-snap"? I assume we can, since there's really no way to police it anyway.The Black Lion wrote: Object: golds, mines, exit, and all other objects and enemies wich can z-snaped, have to be z-snaped (type z in NED). You have to use at least 10 z-snaped objects/enemies.
@ Nacho: Yes you can always use nreality. I don't know how work objects pathing, but if each key position of the object is a z-snaped position it's ok for me. But you will not win more points than The others for this particular use of the rules :P
@ Aero: You can use code edit but it's really not necessary. Putting the objects in a quite ramdon way is the concept of the rules, but don't forget the zoom fonction with a right click can make the work easier ;)
Zoom function? When I right click in flash i just get a 'settings' and 'about flash' option.
- Gross
Right-clicking in Nreality gives you the option to zoom in/out.Destiny wrote:Zoom function? When I right click in flash i just get a 'settings' and 'about flash' option.
If that doesn't work, maybe you have an older version of flash...?
I dunno how all that techy stuff works. :ε
~By me
~By UniverseZero
~By Slick265
<CLICK>
<transcendence!>
N v1.4 is Flash 7, NReality is Flash 8.
Rules are a little changed have a look at them.
Otherwise thanks to Destiny for the first entry (who respect the rules perfectly), I hope there will be some more entry at the end of the week...
I still don't get the tileset rule.
I've read the comments for destiny's map and am confused.
VERY confused.
No map before I have a simple and understandable definition of the tileset rule.
VERY confused.
- Gross
~By me
~By UniverseZero
~By Slick265
<CLICK>
<transcendence!>
I'm very sorry for that :/Chrdrenkmann wrote:I still don't get the tileset rule.
VERY confused.
The only rule about tileset is that every tiles have to be in contact with another, forgot what i was saying in destiny map. I made a mistake while writing the rules because i don't speak good english but it doesn't matter. Respect the rule i've wrote and it will be perfect ^^
Again sorry for the confusion.
No problem.The Black Lion wrote:I'm very sorry for that :/Chrdrenkmann wrote:I still don't get the tileset rule.
VERY confused.
My map is finished and will be submitted soon.
- NUMA Profile: http://nmaps.net/user/lukesv
My map got the greatest score difference between the two judges. I call that an accomplishment.
I was stunned, too. o_Olukesv wrote:My map got the greatest score difference between the two judges. I call that an accomplishment.
- NUMA Profile: http://nmaps.net/user/sayko
Yes, you can be proud of you, Da_guru and me have judged something like 40 maps together and never had a such difference :Dda_guru wrote:I was stunned, too. o_Olukesv wrote:My map got the greatest score difference between the two judges. I call that an accomplishment.
First post updated for round 3, read all please!
