Please help Ep 104 Level 0
- Lords a-Leaping
I have tried hitting the spot where the gold is, but half the time I get shocked, and the other half I get pushed through the one-way platforms by backwards-moving thwumps and fall to my death.
Someone has to know, what is the trick here?
To get on topic, the trick here is that its extremely hard. The way that seems to work best, based on my own playing, and a quick look at the highscores, is to jump up towards the ceiling, making sure not to trigger the thwumps too early. The idea is to have the thwumps all be moving upwards, and you to be falling towards them from the left so that you land on the one-way when the last thwump passes it, so that you run right underneath it. There's not much room for error, and I had a lot of times where I'd slide down the thwumps, or otherwise get stopped by them. But I think that's easier than the way that you're talking about. In the future, if you're playing and have internet access, I'd suggest opening a 2nd window of NReality and take a look at the highscores. The NReality levels are generally much less competitive than episodes 00-99, and so the bottom few submitted runs are pretty much completion runs without the intention of going for a highscore.
Also, out of curiosity, is there a reason you haven't submitted your scores? Although those wouldn't be nearly as fun to watch without your running commentary.
- Lords a-Leaping
Anyway, thank you very much for your help, if I make it, I'll make sure to mention you.
EDIT: Are you sure this is the strategy for the FOURTH column? It works fine for the third, but I keep getting pushed through the platform for the fourth.
And just as a fun little tidbit, the 100 and 110 columns were originally released by blue_tetris as Super Hard Column 1 and Super Hard Column 2 respectively.
- Lords a-Leaping
What he's referring to is the highscores on N/Nreality. Just click highscores (right where you would click play game or configure), click 104, then level 0. You'll be able to view other players' runs on that level.YoSniper wrote:Being completely fresh to the forum, I have no idea where these demos are. I looked in the "High Scores" area, but found nothing relating specifically to 104-0. If you can, please provide a link.
Also, welcome to the forums. And good luck with episodes 110-119!
I would strongly encourage you to upload your highscores and by all means, please ask if you have any questions about... well, anything! We're here to help.
One tip: I believe you have to be "logged in" in the Configure menu of N in order to view highscores. I could be wrong, but if you find the tables aren't loading in the highscores menu, that'd be the first thing I'd check. If you haven't done it before, fill out the username/pass/email forms and push the "create new user" button, but make sure you have the username and password you want in there, as this will create your NUMA account as well!
Edit: in case you were unaware (you seem to know a bit about N already though), NUMA is the N User Map Archive, and can be found here: http://www.nmaps.net/
- Lords a-Leaping
The bad news is that after doing levels 0-3 once, I got to level 4 with only 30 seconds left and I simply could not pull it off. So I'm going to have to start all over again >:(
- NUMA Profile: http://nmaps.net/user/heartattack
If I had a nickel for every time that happened to me I'd put it in a jar and call it my "Horribly Depressed Money."YoSniper wrote:Well the good news is that I managed to pull off the move. So thanks everybody for helping me keep my faith.
Thats bittersweet news to hear. And yeah, the problem with the rest of the episode isn't necessarily that they're hard to complete (other than 104-3), but that there's just not that much gold. You really need around a minute or more left when you get to the last level to not feel super-rushed. And don't feel too bad about not being able to finish it with 30 seconds left, there's only been 7 people ever who would have been able to do so.YoSniper wrote:Well the good news is that I managed to pull off the move. So thanks everybody for helping me keep my faith.
Please post the video(s) here when you finish. I'm looking forward to them, even though they'll be out of order. (I've only watched up through episode 101 so far.)
I beat the first 3 columns always, but I cant pass through the fourth, never :/
- Lords a-Leaping
Thanks for the support.
- Lords a-Leaping
- Lords a-Leaping
Same as my name here: YoSniper.EddyMataGallos wrote:And what is your youtube account??
Just to forewarn you, my channel is NOT G-rated whatsoever, so if bad language offends you, then don't come.
I'm sure you can probably handle it, but I wanted to stress that to anyone who reads this message.
Users browsing this forum: Bing [Bot] and 6 guests
