Metanet Programmer Directory
Postby otters » 2010.11.06 (02:14)
Geti wrote:
incluye wrote:Why does === exist?
So you can check for identical types as well as values? O_o
Why doesn't == do that? O_o
Postby smartalco » 2010.11.06 (02:58)
Because more often you would want to know something like if the string '0' is equal to the value zero.
Postby Tanner » 2010.11.06 (12:01)
smartalco wrote:Because more often you would want to know something like if the string '0' is equal to the value zero.
Wait. So comparing a string of "0" and an int of "0" would return that they're the same? I'm thoroughly opposed to this idea.
Postby otters » 2010.11.06 (12:31)
Exactly. If you want to figure out of the integer value of "0" is 0, then cast it as a gosh-darned integer or something. This is part of my "babysitting the programmer" idea. Another is:
<?php # prints out nothing
if("0") print "hello";
if(0) print "hello";
if("") print "hello";
if(0.0) print "hello";
Raigan and the Horse-Woman
Postby sidke » 2010.11.06 (17:55)
incluye wrote:
hairscapades wrote: Wait. So comparing a string of "0" and an int of "0" would return that they're the same? I'm thoroughly opposed to this idea.
php doesn't have type definition... so instead of complaining, you should thank php for being flexible like this, learn its quirks, and get over them.
because if you can't, you use a different language. simple.
Postby t̷s͢uk̕a͡t͜ư » 2010.11.06 (20:16)
nevada wrote:php doesn't have type definition... so instead of complaining, you should thank php for being flexible like this, learn its quirks, and get over them.
The point is that this is bad programming practice, and PHP, by encouraging this kind of bullshit, will build bad programming habits.
But I guess this really isn't that serious of a problem if you're planning on never using any other language, collaborating with others, or working on a large project.
As for the distinction between equality and identity, that's actually a valid issue. If that's the difference between the == and the === operator in PHP, I have nothing against that. In Python, that difference is the == operator versus the is operator. In C, it's the difference between comparing values and comparing memory addresses. In Lisp, it's the difference between equal and eq. It's definitely an important distinction.
Postby sidke » 2010.11.06 (23:35)
T̷s͢uk̕a͡t͜ư wrote:The point is that this is bad programming practice, and PHP, by encouraging this kind of bullshit, will build bad programming habits.
because there've never been large-scale web development projects done in php using - holy shit, get this - a repository that lets teams of developers work on the same project aka collaborating. i think you're funny.
it was inevitable that a programming thread would end up a language bashing thread.
Postby Geti » 2010.11.07 (01:16)
I'm just surprised we haven't got back onto editor wars yet.
@Tsukatu are you opposed to dynamically typed variables or just PHP's implementation? I've always found them both a blessing and a curse, but if you're smart about how you're coding something there's no issue with them. Unless I'm missing your point entirely O_o
God knows if i'm back.
Postby otters » 2010.11.07 (02:00)
Geti wrote:I'm just surprised we haven't got back onto editor wars yet.
TEXTMATE \m/
Postby scythe » 2010.11.07 (02:22)
C and Lua. Not C++, though it's a decent language that is simply misunderstood.
Postby smartalco » 2010.11.07 (02:29)
Dynamically typed variables are the shit, as the kids say.
Postby scythe » 2010.11.07 (02:33)
smartalco wrote:Dynamically typed variables are the shit, as the kids say.
And they can be fast, too.
Postby t̷s͢uk̕a͡t͜ư » 2010.11.07 (06:31)
Geti wrote:@Tsukatu are you opposed to dynamically typed variables or just PHP's implementation? I've always found them both a blessing and a curse, but if you're smart about how you're coding something there's no issue with them. Unless I'm missing your point entirely O_o
I'm talking about the entirety of PHP's style.
scythe wrote:Not C++, though it's a decent language that is simply misunderstood.
http://harmful.cat-v.org/software/c++/coders-at-work
Postby Geti » 2010.11.07 (07:10)
Ah, fair enough. To each his xor her own though. Interesting read in the article. Everyone there's thoughts on complexity seem to be mimicking mine, so that's a good sign.
@scythe: wait, justintime compilation has nothing to do with dynamic typing though, it's just cramming everying into bytecode at runtime so you aren't iterating through code, you're iterating through what it means to the machine. Sure, faster, and yes, marvellous idea, but not really to do with dynamic type.
Actually, most interpreted languages (the ones that benefit from all that JIT goodness) nowadays are dynamically typed, so maybe that's what you were getting at?
incluye wrote:TEXTMATE \m/
Pff I think you mean geany for graphical editors (though, if anyone has another suggestion for lightweight *nix IDEs I'm open, geany does its job pretty damn well though). I'm undecided as far as cli editors go.
Postby t̷s͢uk̕a͡t͜ư » 2010.11.07 (09:43)
Anyone else tried out Google's Go?
I am unenthusiastic after my first foray:
Postby scythe » 2010.11.07 (09:51)
T̷s͢uk̕a͡t͜ư wrote:Anyone else tried out Google's Go?
Took a look, wasn't interested. I was hoping it would be like OCaml, only without that horrible abortion of a syntax that OCaml uses (OCaml makes Perl look elegant). Instead it turned out to be compiled Java, only not a total piece of shit, but twice as slow.
Postby t̷s͢uk̕a͡t͜ư » 2010.11.07 (09:56)
scythe wrote:[Go] turned out to be compiled Java, only not a total piece of shit, but twice as slow.
You forgot "and 2,500 times the size" (javac'd Hello World was ~400 bytes).
Qui si castrano ragazzi
Postby GamingWolf » 2010.11.07 (15:59)
Oh hey there was other articles on that site that I probably needed to read. Thank you for that.
Postby t̷s͢uk̕a͡t͜ư » 2010.11.08 (03:35)
Yeah, I've been using the information on that site to look into stuff I should know but have little means of finding out about in the first place.
I'm still slightly skeptical of some of its criticisms, but I'm always interested in gaining perspective, so that list of better practices is something of a "to learn" list for me right now.
Postby taaveti » 2010.11.09 (05:30)
Yeah, a lot of their criticisms seem to be based on a really narrow world view (e.g. advocating against HTTP or dynamic libraries). There are certainly some valid points made there, but there are a good number of invalid ones too. The fact that they suggest that exchanging tarballs and patches could be better than subversion counts pretty heavily against their credibility (if they had stopped at git I could've called it a matter of opinion or filed it under "narrow world view", but having used CVS, svn, and plain archives I have to say that svn is the clear winner of the three).
That said, the general idea of reducing complexity is definitely one that needs to be stressed. I may not state it as a flat "c++ doubleplusungood", but I would caution someone not to get so absorbed in the OO paradigm that they ignore the obvious and simple answer in pure c.
Postby mediate » 2010.11.09 (16:16)
I'm to learn C++ at university. That would be my first programming language. Right now, I'm learning and using Maple, which is crap-on-wheels.
Postby scythe » 2010.11.15 (01:44)
Qt, though, is awesome. I can agree that C++ is all-too-often terrible, but in the form of Qt it's great.
Postby t̷s͢uk̕a͡t͜ư » 2010.11.18 (00:57)
Extremely relevant to previous conversation:
http://www.reddit.com/r/programming/com ... variables/
And if you're particularly interested in this specific problem, some further reading.
Postby smartalco » 2010.11.18 (03:26)
T̷s͢uk̕a͡t͜ư wrote:Extremely relevant to previous conversation:
That is fucking awesome. And by 'fucking awesome' I mean 'fucking awesome if you want to write some really fucked up obfuscated code, or just play around with a language'. Not something I would ever consider using in anything I actually wanted to function.
Postby t̷s͢uk̕a͡t͜ư » 2010.11.18 (04:07)
"Awesome." There's an interesting word to reach for. I was thinking more along the lines of "horrifying".
