New glitch; Moving through Vertical Oneways.
- Member
- NUMA Profile: http://nmaps.net/user/el_devo
Watch this demo: http://pastebin.com/SnXwmnTA
Not quite sure what the deal is, but I will update later with more info.
- Maxwell Smart
- NUMA Profile: http://www.nmaps.net/user/ninja_matt
This is just sooo wierd...
Never seen anything like it before. When you said on irc that you had glitched through a sideways facing oneway i thought it was during a chimney (watch 190-4 speed), but when I saw it I was like O_O.
I think van has the best theory for all these one way glitches so far.
#n-highscores wrote:[23:44] <vann> i have an explanation
[23:45] <vann> M&R were drunk when coding oneways
- Gross
Heh, strange. Like that glitch where you pass through a horizontal oneway when you fall a specific distance (I made a map with this glitch here if you want to see it). I presume this works the same way..?
EDIT: Ha, I found it. You have to move a certain amount of pixels at a VERY exact speed, and you'll go through. Or it may just be your speed. And this had to be done while in the air.
~By me
~By UniverseZero
~By Slick265
<CLICK>
<transcendence!>
Nice map. Crazy glitch.
O_o. Do you have the demo?Inspired wrote:About a year ago I passed through the oneway at the top on 00-0. I told golfkid about it (But he didn't believe me). Trying to find logs for it.
QFE, also there is a krusch map that exists that must've had a - snapped one-way so that you fell through it every time you came off the ledge. Admittedly, i can't clearly recall this happening on a vertical one-way... but yeah, it doesn't really surprise me...BluePretzel wrote:Heh, strange. Like that glitch where you pass through a horizontal oneway when you fall a specific distance (I made a map with this glitch here if you want to see it). I presume this works the same way..?
There have been a few different maps which use the horizontal version of this glitch. It is much easier to regulate the speed some is going on when they fall onto a horizontal oneway than the speed they hit a vertical oneway, so it would be impressive if you can use this well in a map.
epigone made one which was pretty cool.lord_day wrote:There have been a few different maps which use the horizontal version of this glitch. It is much easier to regulate the speed some is going on when they fall onto a horizontal oneway than the speed they hit a vertical oneway, so it would be impressive if you can use this well in a map.
- MBTI Type: ESFP
I imagine that is the case, yes. Pretty interesting find.lord_day wrote:There have been a few different maps which use the horizontal version of this glitch. It is much easier to regulate the speed some is going on when they fall onto a horizontal oneway than the speed they hit a vertical oneway, so it would be impressive if you can use this well in a map.
Hi.
I found a map where this can be done pretty consistently, 204379, just watch the demos on NReality.
- Member
- NUMA Profile: http://nmaps.net/user/stonedeagle
On my episode demo for 148. Not the level demo, but the episode demo, on 148-1, I managed to just jump through a horizontal oneway, No wall jump, no gold lag, I just jumped through it. Also in 177904, there is the opposite glitch.
stonedeagle: that looks like gold delay to me. The gold doesn't have to be on the one-way to delay you through it. In fact, I'm pretty sure it can happen from gold placed half a tile away from the one-way.
Cool glitch, anyhow!
