Do you cross your sevens?
Yes
4
19%
No
17
81%
Total votes: 21
Postby 999_Springs » 2010.10.12 (19:03)
A seven is supposed to look like this: 7 not like this: 7. What's up with all these people who habitually, without any thought whatsoever, draw random lines through their sevens which don't make them look like a seven any more!?
Postby 29403 » 2010.10.12 (20:03)
No because it's not a 7 if it's crossed
Postby fawk » 2010.10.12 (20:42)
That's an ex-seven.
[/reference]
Postby 29403 » 2010.10.12 (20:47)
This isn't IRC, no need for / tags Image
Postby fawk » 2010.10.12 (20:47)
fix'd
Postby 29403 » 2010.10.12 (20:48)
Works for me
Postby Vyacheslav » 2010.10.12 (21:21)
Nein.
Postby Spawn of Yanni » 2010.10.12 (21:26)
No, but on a mildly related note, I recently started crossing my Zs.
Postby Pheidippides » 2010.10.12 (23:00)
Occasionally. I also do those angular 3's sometimes, when I'm feeling fancy. p,o
Postby Kablizzy » 2010.10.12 (23:53)
Habitually.
Postby Rose » 2010.10.13 (00:10)
My third grade teacher made us cross our 7's and Z's, but I have not done so since.
Postby Universezero » 2010.10.13 (02:05)
Usually I don't, but if my 7 looks too much like a 1, then I put a cross through it. That's only occasionally though, and I don't do it out of habit.
Postby scythe » 2010.10.13 (02:29)
Yes. I also cross my z's. Never used to do either until I started doing lots of chicken scratch and had to be able to tell a 7 from a 1 and a z from a 2.
Postby t̷s͢uk̕a͡t͜ư » 2010.10.13 (07:12)
Characters should only be crossed to disambiguate them. Nothing else in the English alphabet or Arabic numerals is similar enough to a '7' to warrant this.
I try to be consistent in crossing my zeroes, but I frequently forget to.
Postby Rose » 2010.10.13 (15:33)
T̷s͢uk̕a͡t͜ư wrote:Characters should only be crossed to disambiguate them. Nothing else in the English alphabet or Arabic numerals is similar enough to a '7' to warrant this.
Doesn't a zero with a line through it mean "no solution" in algebra, though?
Postby t̷s͢uk̕a͡t͜ư » 2010.10.13 (19:42)
It doesn't happen often beyond algebra that that symbol sees meaningful use. In upper-division math, you only need to express a "no solution" as part of a proof, in which case it's more appropriate to write out "no solution".
There's always "DNE", to boot.
Postby scythe » 2010.10.13 (20:51)
Actually, it means "empty set". The perpetuation of the idea that it means "no solution" rests on the shoulders of a million misinformed high school algebra teachers.
I've considered dotting my zeroes, which would ease all the confusion.
Postby bobaganuesh_2 » 2010.10.14 (03:14)
Because it's more convenient to the next number. Yes.
Postby t̷s͢uk̕a͡t͜ư » 2010.10.14 (07:18)
scythe wrote:
MAXXXON wrote:Doesn't a zero with a line through it mean "no solution" in algebra, though?
I've always used the Greek phi (i.e. Φ) to represent an empty set. The slash on the phi is vertical, whereas I slash my zeroes diagonally.
Dotting zeroes is not a bad idea, though. I might try switching to that.
