Word '07 issue
I am running Windows 7 Home Premium, if that makes any difference.
I need this to be able to view a syllabus for one of my classes. Help please?
Edit: anyways, don't worry about figuring it out asap, gotta go for class now, and won't be back for at least a couple hours.
That works for me, at least for now. Hopefully I can find out about a more permanent solution that lets me open a file from outside of Word.smartalco wrote:Well it was with Word 98, but I used to have a problem where I also couldn't /directly/ open files, but if I launched Word separately and opened the file within Word, it worked fine.
As a sidenote, my Excel and Powerpoint don't have this problem.
I would take a look at this:
http://www.techsupportforum.com/microso ... files.html
you may try if you have the ability to, uninstall and reinstall, could be that the first time you did it, it didnt go through properly. the other thing to check would be if there was an update available in the menu bar.
go to the start circle:
Control Panel-> System Security -> Windows Updates-> Check Available Updates
Look for one that says something about Office or something along those lines.
Hope this helps some, and be sure to look at the site that is attached, the bottom comment could be a good one but theres a few links in it as well
