uberFAP
Moderators: Rose, Sunset
Raigan and the Horse-Woman
Postby sidke » 2010.08.09 (19:59)
squibbles wrote:I get that popup with totally unrelated tabs. It just happens.
Huh... Unless you have a single tab open and this still happens, this error is caused by tabs. Try browsing with one tab, and if it still occurs, refer to the bottom of the OP.
squibbles wrote:Also, for some odd reason, I have arctic pony in my list...twice. O_o
I cannot remove one, without the other disappearing, and adding one also adds both.
Resolved, and a new version of the script has been uploaded.
Postby chocollama » 2010.08.09 (21:51)
Slayr wrote:I'm not seeing the sync button anywhere, but this idea is really cool.
check your profile
Postby Slayr » 2010.08.10 (02:02)
check your profile
i did.
Postby sidke » 2010.08.10 (02:43)
please, i know i just put it up there last night or so but if you run across a problem, read the entire op for helpful information such as the "Assuming a problem will eventually arise:" section. and then get on IRC because i don't want to back and forth eight million times via pm :<
Postby Slayr » 2010.08.20 (04:08)
my security system won't allow me to download it, i use Norton Antivirus. it keeps telling me the file was trying to attack my computer.
Postby Kablizzy » 2010.08.20 (04:28)
Slayr wrote:i use Norton Antivirus.
I think I found your problem, ma'am. You had a family of weasels building a space rocket in your turlet.
Postby Slayr » 2010.08.20 (05:07)
i assume you meant to spell turtle
also, i don't understand your metaphor
Postby sidke » 2010.08.20 (06:01)
this plugin has code norton finds similar to a rootkit. then again, everything has code norton finds similar to a rootkit.
then again i also already mentioned this in the OP...
Security Information:
Some antiviruses think this is a rootkit or attack of sorts. I don't know if it's because there are eval() calls or that is sees the incredibly roundabout xss method I coded in, but there is nothing harmful that can happen from this plugin.
maybe i need to table of contents it or make it searchable by a list of keywords because people aren't reading it :C
you can either disable norton and install the plugin, leave norton as is and not install the plugin, or remove norton and since you're paying for antivirus already, get real protection: nod32
Postby Slayr » 2010.08.21 (03:29)
i'm not paying for it though.
Postby unoriginal name » 2010.08.21 (06:38)
Slayr wrote:i'm not paying for it though.
Pretty sure that isn't the point.
Postby otters~1 » 2010.08.21 (18:38)
Haha.
Eh.
Postby Kablizzy » 2010.08.22 (01:35)
Bahahahaha. Ahaha. Ahah. Oh, man. I'm not sure if you're saying that you're not paying for Norton *at all* (as in, it's a hacked copy, or deactivated and no longer protecting your computer), or if you just mean that, like, your parents pay for it instead of you. In either case, Bahahahahaha! Ahahahahaha!
Postby toasters » 2010.08.22 (03:57)
Sidke you sexy thing you, this is fantastic. The first one was neat, but this one is just so much more elegant and functional. I love it.
Postby Slayr » 2010.08.23 (04:02)
i dont see what's wrong with Norton. it works fine, instead of just saying its bad albeit using metaphors tell me why its bad.
PS i don't understand why it would be funny that my parents are paying for it, although i can laugh at the first scenario.
Postby Kablizzy » 2010.08.23 (07:11)
Slayr wrote:instead of just saying its bad albeit using metaphors tell me why its bad.
You *have* seen me post, right? I'm the lovable, over-sardonic codgety, old dickbag who only makes over-the-top posts satirizing the current state of the world and referring specifically back to "Easier Times" when Petrol Oil was less than a dollar a gallon. If I weren't colorful and over-the-top, there'd be no fun to me ever, ever coming here. Metaphor is funny. Funny is good. Therefore, Blizz is awesome. Logic makes money for priests. http://zombo.com
Postby Slayr » 2010.08.23 (16:38)
Touche
Postby ska » 2010.09.28 (11:18)
I just wanted to say I've been using this for a while now and I <3 it.
Is there any way of seeing like a 'most subscribed to author' chart?
that'd be interesting.
Postby sidke » 2010.09.30 (06:35)
ska wrote:I just wanted to say I've been using this for a while now and I <3 it.
sorta, here is a raw printout of some quick python script i wrote to show authors and the number of times they've been favorited. i didn't bother sorting it.
{'': 14, 'nDEAVOUR': 2, 'IWBTNINJA': 2, 'rocket_thumped': 6, 'furry_ant': 6, 'blackson': 4, 'n0_ma11y': 1, 'etdeshon': 1, 'NIGHTMARE619': 1, 'squibbles': 1, 'icathus': 1, 'DW40': 1, 'cahu': 2, 'romaniac': 2, 'Njitsu': 1, 'PALEMOON': 10, 'shokwave': 1, 'ska': 2, 'GreenEggsAndHam': 1, 'Bunniesandsheep': 1, 'DemonzLunchBreak': 1, 'kiaora': 1, 'kendogg102': 1, 'miststalker06': 4, 'Palemoon': 1, 'BionicCryonic': 2, 'cucumber_boy': 2, 'Evil_Bob': 2, 'Chrdrenkmann': 2, 'Jugglekid': 1, 'Leaff': 5, 'ratatat_': 1, 'Losttortuga': 9, 'gloomp': 4, 'loveheat': 1, 'WordBlamCreator': 1, 'Sendy': 1, 'dejablue4': 1, 'Jawbit': 1, 'pheidippides': 1, 'im_bad_at_N': 2, 'formica': 1, 'da_man894': 2, 'Echarin': 1, 'maxson924': 3, 'Replon': 1, 'hoohah2x2sday': 2, 'oof____kabooff': 1, 'LouDog004': 1, 'Riobe': 12, 'seven_two': 1, 'toasters': 3, 'mahi_mahi': 3, 'jeffkillian': 1, 'Nexx': 1, 'Onesevennine': 1, 'Clifty': 1, 'Barabajagal': 7, 'mc_george': 1, 'SkyPanda': 3, 'kingalex': 1, 'j_v': 1, 'whaleshow527': 1, 'Aphex_N': 1, 'TheBlackLion': 1, 'myrrhman': 1, 'orangekraken': 1, 'mintnut': 2, 'RadiumFalcon': 4, 'SkyRay': 6, 'RockLeeGui': 1, 'Cerberus[]': 5, 'stepself': 2, 'wulfgang': 4, 'eternal_moonlight': 1, '-LordOfPeanuts-': 1, 'Viil': 3, 'karmap0lice': 1, 'saberhageN': 1, 'GRN': 2, 'pocketchange24641': 1, 'Geckos': 2, 'origami_alligator': 2, 'Orion_': 2, 'Life247': 1, 'thedupli': 1, 'al__cair__raheakallan': 2, 'Bl3wolf': 1, 'ChaoStar': 1, 'sept': 2, 'epigone': 3, 'Gillespie': 2, 'player_03': 1, 'DDRave': 1, 'mythrhythm': 1, 'fireburnsfree': 1, 'AMomentLikeThis': 1, 'Pheidippides': 5, 'R_U_S_H': 1, 'nevershine': 5, 'script': 1, 'BloodyMoonLike': 1, 'lord_day': 5, '9400': 1, 'ChrisE': 3, 'AsTimeFliesBy': 1, 'Guitar_Hero_Matt': 3, 'neither_nor': 1, 'sidke': 6, 'astheoceansblue': 8, 'yungerkid': 2, 'lsudny': 1, 'arctic_pony': 1, 'in_dub': 1, 'the_happy_taco': 1, 'Nphasis': 2, 'mzapacer': 1, 'blue_tetris': 2, 'remote': 1, 'mrgy05': 1, 'RandomDigits': 1, 'heatwave21': 2, 'brainstone': 3, 'Mechtradevil': 1, 'Cadmus': 1, 'Izzy': 1, 'Kaylab': 3, 'krusch': 3, 'Mericet': 1, 'MattyMc13': 1, 'Invalid': 1, 'MyCheezKilledYours': 1, 'b3njamin': 1, 'martyr': 2, 'AdorableRabbit': 1, '29403': 1, 'Race_Week': 1, 'rozer': 1, 'AlOnE_AnD_bRoKeN': 1, 'Brttrx': 2, 'littleviking001': 2, 'Arctic_Pony': 1, 'T3chno': 2, 'Wizard2': 2, 'I-Am-A-Bilingual-Hippopotamus': 1, 'uNcoNditioNal': 2, 'ganteka': 1, 'warrioronthesky': 1, 'shortshift': 5, 'fingersonthefrets': 3, 'spudzalot': 6, 'Sweep': 1, 'skyline356': 2, 'Ferox ': 3, 'Yahoozy': 8, 'apse': 4, 'BluePretzel': 3, '_destiny^-': 9, 'motocrosser': 1}
also i just updated uberfap to (hopefully) fix jerrod's problem. we'll see if it worked :x
Postby sidke » 2010.11.28 (07:23)
double and necro post, i've spent some time to resolve a few issues with the uberFAP code.
i checked the server for activity, and it's nice to know that people use it!
hopefully with this code update, it's more usable...
so update your plugin by going to http://userscripts.org/scripts/show/83019!
Postby ska » 2010.11.29 (01:18)
Hey, thanks for the update, but is there any way to recover favourite authors from the server? I lost all my favourite authors and would like to have them back. thanks :)
Postby sidke » 2010.11.29 (04:27)
ska wrote:Hey, thanks for the update, but is there any way to recover favourite authors from the server? I lost all my favourite authors and would like to have them back. thanks :)
only if you've synced your favorites to the server before
in 'edit settings' on your profile,
- Restore uberFAP: Clicking and confirming this will request your list from the server, and populate your favorite authors with those on the server.
Postby ska » 2010.12.03 (11:43)
yo, i messed up, i hit sync thinking it would sync with my old favourites not vice versa, is it possible to get a old sync from the server to synchronize with? ta
Postby sidke » 2010.12.12 (11:30)
ska wrote:yo, i messed up, i hit sync thinking it would sync with my old favourites not vice versa, is it possible to get a old sync from the server to synchronize with? ta
very late response :<
short answer: no
long answer: there's only one collection of favorites, i didn't code in to make regular backups... i could try some other way, so i'll get back to you
edit: success, just click restore and you should be good to go. sorry it took so long .-.
also an update to the code, there was a bug that caused new users of the script to not be able to favorite authors... now they can!
NUMA Profile: http://nmaps.net/user/lsudny
Postby lsudny » 2011.01.08 (10:15)
Yeah, sorry for digging up the old thread, but I have a problem with uberFAP. I've downloaded the script, installed it, I've got everything - settings, "no fav. updates" - everything but the heart icons. What should I do?
I'm using Firefox.
soundcloud | facebook
That is why I decline the title of Iron Cook and accept only the lesser title of Zinc Saucier, which I just made up. Also, it comes with double prize money!
Postby sidke » 2011.01.08 (10:56)
recently my host has been cancelled. i'll work shortly on an offline version of the script until i get another site up. this might be why you're having problems, so check later this weekend
