Editor Wars
Choose your editor.
emacs
0
No votes
vi/m
5
28%
nano
0
No votes
ed is the standard text editor
0
No votes
Notepad.exe
5
28%
Notepad++ / ConTeXT / Programmer's Notepad / etc.
4
22%
Microsoft Word
1
6%
other (specify in post)
3
17%
Total votes: 18
Postby t̷s͢uk̕a͡t͜ư » 2010.07.19 (21:26)
It's that time again!
Postby Vyacheslav » 2010.07.19 (22:57)
I voted for nano, but in retrospect I should've specified other and put this:
Postby SlappyMcGee » 2010.07.20 (02:08)
Notepad++ on the Windows Machine, vim on the Ubuntu Laptop.
Postby scythe » 2010.07.20 (02:24)
Vim, definitely.
Postby otters » 2010.07.20 (06:06)
nano Textmate. Didn't realize we could specify our own.
Postby Geti » 2010.07.20 (09:38)
Why can't I vote twice?
nano for cli editing, geany or np++ in a graphical enviro
clarification: nano cause I can't work vi/m properly, I'm a noob, yada yada, but also cause it just seems to work the way it should. Obviously it's not as deliciously verbose as vi but I don't usually need that level of control over my configs.
God knows if i'm back.
Postby 乳头的早餐谷物 » 2010.07.20 (14:45)
metapad—a lightweight Notepad replacement—for regular textual work and note-taking, ConTEXT for programming-related work. And vim on Linux.
Postby smartalco » 2010.07.20 (17:02)
Notepad++ on win
TextMate on OS X (for all 1 of you that may care), I really wish this was on windows
Postby t̷s͢uk̕a͡t͜ư » 2010.07.20 (18:17)
smartalco wrote:TextMate on OS X (for all 1 of you that may care)
Oh, shit, I really should've added that, actually. All of the Macfags I work with swear by it.
Raigan and the Horse-Woman
Postby sidke » 2010.07.21 (08:38)
Tsukatu wrote:Oh, shit, I really should've added that, actually. All of the Macfags I work with swear by it.
it crashes a lot. every time the directory structure changes or a new file finds its way into the depths of the project folder, textmate takes it upon itself to extremely slowly rescan /everything/ and this leads to annoyingly persistent pinwheels of death. every now and then it will also just crash for no damned reason when you give focus back to it from another application. whatever it uses to grep through the project is an extremely slow implementation and it takes forever and then some (pinwheels) to get results. also it costs /fifty-two dollars what the fuck/.
granted there really isn't anything else to use for programming on a mac, so sure it would seem relatively swear-worthy.
Postby t̷s͢uk̕a͡t͜ư » 2010.07.21 (09:38)
maki wrote:granted there really isn't anything else to use for programming on a mac [except TextMate], so sure it would seem relatively swear-worthy.
[x]emacs? vim?
Postby sidke » 2010.07.21 (10:00)
THIS ENTIRE POST IS WRONG
i am going to vi leaving the god forsaken aqua-compliant tardware behind
Postby Geti » 2010.07.21 (10:07)
http://geany.darwinports.com/ ? Granted it's an old release, but still, geany is pretty A+. you could probably just build it from source for mac as is, you do that for linux.
That or just suck it up and use the terminal :P
Postby otters » 2010.07.21 (20:57)
The only part of this that is remotely true for me is the last sentence. Maybe you're using an old version or something.
Postby smartalco » 2010.07.21 (21:48)
I've had the same experience with it is incluye, although the projects I've used it on have maxed out at about 30 files.
On a slight tangent, but if you do web work, this might as well be the god of editors: Code
Postby otters » 2010.07.22 (01:20)
smartalco wrote:I've had the same experience with it is incluye, although the projects I've used it on have maxed out at about 30 files.
I opened / once in TextMate, and it didn't crash--it wasn't usable, exactly, but I could still make new files and delete them.
Postby sidke » 2010.07.22 (09:58)
incluye wrote:Maybe you're using an old version or something.
i run the updates as often as they appear, it's not my fault it's crap. that or the mac it's running on is crap.
no, the 27 inch imac is not very old. i shouldn't complain, though. i can't hardly expect anything would run properly on one anyways. because nothing does. .__.
back on topic, my vote is now solidly secured in vim for mac, although i'm still trying to find something for developing in windows. notepad++ has weird issues in w7 with chrome, and won't bring itself in front of it on focus, and for some reason slows to a halt when you try moving toolbox windows around. i end up just using IDLE for python or notepad for anything else. i've looked into some other editors and found http://bluefish.openoffice.nl/ , but the gimmicky toolbars are pretty off-putting. turning them off works just as well, and otherwise the syntax highlighting and project window are all i really want.
Postby SlappyMcGee » 2010.07.22 (10:39)
I have w7, Chrome and N++ and do not have that issue.
Postby otters » 2010.07.22 (16:55)
Well, we've already established that maki is some sort of freakish magnet for misfortune.
Postby t̷s͢uk̕a͡t͜ư » 2010.07.22 (17:55)
maki wrote:although i'm still trying to find something for developing in windows.
In Linux, I open up vim.
In Windows, I take a second to ponder why I'm doing development work in Windows, start cygwin, and then open up vim.
Postby SlappyMcGee » 2010.07.22 (19:13)
Dude, this is awesome. I'm making you admin again.
Postby Vyacheslav » 2010.07.22 (23:02)
I was hoping more people here still used DOS. Woe is me.
Postby t̷s͢uk̕a͡t͜ư » 2010.07.23 (02:42)
987654321 wrote:I was hoping more people here still used DOS. Woe is me.
Fuck DOS. Nobody uses DOS.
Postby Vyacheslav » 2010.07.23 (04:26)
DOS is the most reliable, stable OS. There, I said it.
Postby Geti » 2010.07.23 (06:23)
I prefer linux. Also, what Tsukatu said.
