Anyone could have registered it, but it's probably clux.vankusss wrote:wow clux, is that really you? (i mean, did the registrations from old forums work here or anyone could have registered that nick?)
Metanet 0ths Thread
- Phei Phei Pho Phum
Unless it's LAT again >.>Pheidippides wrote:Anyone could have registered it, but it's probably clux.vankusss wrote:wow clux, is that really you? (i mean, did the registrations from old forums work here or anyone could have registered that nick?)
- RoboBarber
@vankuss : nice innov' at the begining. Unfortunately i don't think i'll have time to get it back. I'm working from monday to saturday...included =)
http://forums.droni.es/viewtopic.php?p= ... e1#p110962eru_bahagon wrote:TRO, why "again" ?
LAT is a sneaky one.
yea thatska wrote:0th for van on 72-4 and for golfkid on Episode 30
- RoboBarber
And ep 56, too. That's 50 0ths, again.
EDIT : and ep 52. Took 1st on 52-4. Anyone to try 0th ?^^
really cool man... played 52 for a bit tonight...eru_bahagon wrote:74-4 IS MINE !
on my latest run, I was 1.525 seconds ahead of your episode run by the start of 52-2, but my hot streak stopped there... Still, I managed a fairly decent episode run and picked up a few highscores along the way... congrats, eru. i might have a go at 56-0 tomorrow...
My first ever metanet 0th.
(If you don't remember, my zeroth ever metanet 0th was 45-4 back in February.)
Hopefully this one is going to last longer than the other one.
[Edit: 4 hours, 10 minutes, 49 seconds. Not even close.
RRRR
GNASH
SNARL
GRRRR
ROWRRRR...]
- RoboBarber
I'm sorry, but I'll have to re-do it to get 35k.
Maybe today if i can't get a agd run on 52-4.
EDIT : ep 15, improved by 4 seconds.
EDIT 2 : 15-2, I love that level, i've played ep 15 to improve my run and it's a 0th now :)
Don't you mean 15-1? ;)eru_bahagon wrote: EDIT 2 : 15-2, I love that level, i've played ep 15 to improve my run and it's a 0th now :)
- RoboBarber
I've tried many times to beat the drones, then you still have to do a fast ending without hitting the door.
52-4 by 1 frame !!! :O It was my 4th try today... It took me about 1 minute of playing xD
I was actually just playing that level to improve my incidental 19th and noticed you trumped LAT by a frame... So I ended up using a variant on Sammage's route. It ended up being a hybrid of eru's and Sammage's and is relatively easy to get a Top-20 using this method. Edit: got a subpar top-20 run on 52-3... so that means I've finally got a highscore for each level in that episode...eru_bahagon wrote:87-3 is amazing =)
btw off-topic, took 87-3 sr, too, like 8 minutes after hs
- RoboBarber
I tried... monday. Yesterday i completely miss that jump -it was my 1st try there-... i didn't skip it on purpose :)nice eru, but you should try doing what lat does, but with that gold lat misses, that would be like 2 sec difference
What's an inverted 8 tile ? I understand what you mean (double jump on the curve), but where can i find the "name" of each "tile" ?btw what's your success rate for that (inverted 8-tile)-double near the end?
To answer this question, i'd say about 2/3. Sometimes i miss it, and sometimes i do it too fast (and you hit blue point on my sketch). For me, it's clearly not an hard part of the run. The jump i completely missed yesterday is one of the hardest part^^ (see purple/pink points)
And most of the time, you just have a bad timing on an easy jump.
Uploaded with ImageShack.us
- RoboBarber
- RoboBarber
1h20 of playing..., a lot more than 4 runs^^ but it's still under 134 :pEru... I think of you as one of the most consistent N players today, and if anyone can pull off a 134+ run it would be you... just set aside an hour or 2 and I reckon you could do it ;)
Well done sir! Care to get the missing golds on 96-4 and 46-4?eru_bahagon wrote:1h20 of playing..., a lot more than 4 runs^^ but it's still under 134 :pEru... I think of you as one of the most consistent N players today, and if anyone can pull off a 134+ run it would be you... just set aside an hour or 2 and I reckon you could do it ;)
Ok.. firstly 46-4 is insanity - on top of a near flawless run which is required just to beat the first drone, you then need to chimney almost perfectly at the end of an already insane run... it's just... ludicrous...TheRealOne wrote:Well done sir! Care to get the missing golds on 96-4 and 46-4?eru_bahagon wrote:1h20 of playing..., a lot more than 4 runs^^ but it's still under 134 :pEru... I think of you as one of the most consistent N players today, and if anyone can pull off a 134+ run it would be you... just set aside an hour or 2 and I reckon you could do it ;)
Also, congrats eru on the great run - 134 was just a target but .875 is still pretty damn good.
- RoboBarber
However, I'm not good enough at chimneying to get a run on 46-4.
