What's on your copy right now
Postby Pikman » 2008.11.02 (19:05)
This guide is for the players' packs in Shift 3. Some levels are painfully difficult and others are long and unclear, so I took images of each level and drew on them in Paint. (Might have to click to view the full-size image.)
The first pack is the GreyGames PP. These levels are mostly either symmetrical or containing a repeated gameplay mechanic, and some can be completed without shifting once. You shouldn't need help completing them, but in case you do (which I doubt), the next six images are from this easy pack.
<font color='9A0000'>Level 1-1</font>
<a href="http://www.postimage.org/image.php?v=Pq2s8wkS" target="_blank"><img src="http://www.postimage.org/Pq2s8wkS.jpg" border="0" /></a>
<font color='9A0000'>Level 1-2</font>
<a href="http://www.postimage.org/image.php?v=Pq2s9jdJ" target="_blank"><img src="http://www.postimage.org/Pq2s9jdJ.jpg" border="0" /></a>
<font color='9A0000'>Level 1-3</font>
First follow red until the second door key, then follow the blue line.
<a href="http://www.postimage.org/image.php?v=Pq2s9DaS" target="_blank"><img src="http://www.postimage.org/Pq2s9DaS.jpg" border="0" /></a>
<font color='9A0000'>Level 1-4</font>
See what I mean by symmetry?
<a href="http://www.postimage.org/image.php?v=gx2a37wS" target="_blank"><img src="http://www.postimage.org/gx2a37wS.jpg" border="0" /></a>
<font color='9A0000'>Level 1-5</font>
I think I cheated; skipped a few gravity shifters.
<a href="http://www.postimage.org/image.php?v=gx2a3muJ" target="_blank"><img src="http://www.postimage.org/gx2a3muJ.jpg" border="0" /></a>
<font color='9A0000'>Level 1-6</font>
Simple gameplay mechanic, but the spikes actually present a hazard this time.
<a href="http://www.postimage.org/image.php?v=Pq2sb0tS" target="_blank"><img src="http://www.postimage.org/Pq2sb0tS.jpg" border="0" /></a>
The second pack, levels by azurieq, kicks up the difficulty. You might have to use the restart button, and you might also have to refer to the pictures below to find out which way to go. It's only the second pack, so if you have trouble now, you won't finish the third one without this help.
<font color='9A0000'>Level 2-1</font>
More like a movie than a level, but some user input is required. Fun to watch.
<a href="http://www.postimage.org/image.php?v=Pq2sfplJ" target="_blank"><img src="http://www.postimage.org/Pq2sfplJ.jpg" border="0" /></a>
<font color='9A0000'>Level 2-2</font>
Follow sky blue, then light green. And no, I do not frequent the Hall of Odin.
<a href="http://www.postimage.org/image.php?v=aV2qXWdi" target="_blank"><img src="http://www.postimage.org/aV2qXWdi.jpg" border="0" /></a>
<font color='9A0000'>Level 2-3</font>
Here, once again, follow sky blue, and then light green. Watch the spikes because there are a lot of deadly jumps and falls.
<a href="http://www.postimage.org/image.php?v=Pq2sfVMA" target="_blank"><img src="http://www.postimage.org/Pq2sfVMA.jpg" border="0" /></a>
<font color='9A0000'>Level 2-4</font>
Sorry for being a little fast on the draw, I had to take it while the man was moving. This one's a quicky. Follow red, then light green.
<a href="http://www.postimage.org/image.php?v=aV2rvsgS" target="_blank"><img src="http://www.postimage.org/aV2rvsgS.jpg" border="0" /></a>
<font color='9A0000'>Level 2-5</font>
This one is the first confusing, long level. Start by following violet, then dark blue, then red, and finally light green.
<a href="http://www.postimage.org/image.php?v=Pq2sh1CA" target="_blank"><img src="http://www.postimage.org/Pq2sh1CA.jpg" border="0" /></a>
<font color='9A0000'>Level 2-6</font>
Blue, then red, then light green. The red line looks like it's hovering in midair, but don't worry; there will be a door there. :)
The assorted pack is a mixed bag. By far the hardest are #3 and #6, but the remainder are just lengthy and not as hard to grasp. However, be prepared for levels taking up to five minutes and retracing pathways - these levels are an arduous ordeal and they'll put up a good fight for even the experienced Shift player.
<font color='9A0000'>Level 3-1</font>
Purple, light green, then red. Pretty easy. Many of the switches weren't used. Maybe the author didn't intend for this solution?
<a href="http://www.postimage.org/image.php?v=Pq2siaXJ" target="_blank"><img src="http://www.postimage.org/Pq2siaXJ.jpg" border="0" /></a>
<font color='9A0000'>Level 3-2</font>
Very confusing level to explain. Follow blue, then yellow, then red, then light green, and finally purple.
<a href="http://www.postimage.org/image.php?v=gx2aaawi" target="_blank"><img src="http://www.postimage.org/gx2aaawi.jpg" border="0" /></a>
<font color='9A0000'>Level 3-3</font>
This level is super complex and has frustrated many people. Start with white, go to black, then red, then follow dark blue, and finally light green. Avoid objects marked with an X. Took this pic because COLTchr was stuck on the level.
<a href="http://www.postimage.org/image.php?v=gx2aaLWr" target="_blank"><img src="http://www.postimage.org/gx2aaLWr.jpg" border="0" /></a>
<font color='9A0000'>Level 3-4</font>
Another level that is fun to watch, but this one's hard. So many colors. Red first, then blue, then light green, then goldenrod, then purple. Phew.
<a href="http://www.postimage.org/image.php?v=aV2rysQJ" target="_blank"><img src="http://www.postimage.org/aV2rysQJ.jpg" border="0" /></a>
<font color='9A0000'>Level 3-5</font>
A long but easy level. By the way, red connects to blue and green connects to purple; those two are hard to pick out.
<a href="http://www.postimage.org/image.php?v=gx2abVgA" target="_blank"><img src="http://www.postimage.org/gx2abVgA.jpg" border="0" /></a>
<font color='9A0000'>Level 3-6</font>
This level is the balls, but it's the last one. Lines in midair and changing terrain will have you staring blankly at this image, but it's the best I could do. First it's hot pinkish red, then dark blue, then green, and finally magenta.
<a href="http://www.postimage.org/image.php?v=Pq2skh9i" target="_blank"><img src="http://www.postimage.org/Pq2skh9i.jpg" border="0" /></a>
Well, that's all from me. Enjoy your 15 points, and go crazy.
SHIFT 3 guide made for Kongreguide. Still not put up yet, after a day and a half.
EDIT: I know the HTML doesn't work. But it was part of the copy.
Postby Vyacheslav » 2008.11.02 (19:32)
Postby Eiturlyf » 2008.11.02 (19:57)
Dear sir, I think your pants are missing.
Postby bufar » 2008.11.02 (20:06)
EDIT: Map Tagged.
Postby PALEMOON » 2008.11.02 (20:54)
88:0|35651584|35791394|35791394|35791394|35791394|35791394|546|0|0|0|17895696|4369
Postby deltainferno » 2008.11.02 (20:56)
lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol lol
-previous sigs-
Image-GloomP
Image-NicNac14
Image-Universe_Zero
Image-NicNac14
I LIKE PIE
Postby bufar » 2008.11.02 (20:56)
I'm putting it in map tags before I submit this time.
Postby MattKestrel » 2008.11.02 (21:20)
Postby bufar » 2008.11.02 (21:21)
a giant beaver, which
Postby MattKestrel » 2008.11.02 (21:27)
Its pretty long, so heres a spoiler
Lois Lane and the Scales of Justice
Question 1: Describe what you see in the first picture. Explain what the context of the image is. What has led to this point?
In the first image, we see Lois Lane blindfolded before a Japanese firing squad, with Superman in front of her blocking the bullets. She has been used by the Japanese as a hostage to stop Superman from sabotaging their boats, guns and aeroplanes, and is thus to be executed because Superman continued fighting for the Americans. The image was taken from a war-time Superman cartoon, just after the Pearl Harbour bombings. At this time, the Americans generally had very negative views of the Japanese due to their affiliations with the Axis, and thus depicts them as the “baddies” in this short.
Question 2: Describe what you see in the second picture. What does it represent? Why is the figure blindfolded?
The second picture shows a woman in a blindfold holding a set of scales in her left hand and a sword in the right hand. This picture represents blind justice, where the scales represent weighing up all of the evidence and balancing the arguments, whilst the sword stands for deliberation, immediacy in action, and power. The figure is blindfolded to show that justice does not discriminate people because of how they look, only based on the evidence given.
Question 3: Now explain what the link between the two pictures might be. Why might the cartoon producer want to suggest a link between Lois Lane and the scales of Justice? What does this tell us about how Japan and America were depicted in “The Eleventh Hour”?
Firstly, the two images could be linked as Superman is a symbol of justice and righteousness in America, defending those in unjust circumstances. For example, the Japanese are planning to execute Lois Lane only because of Superman, through no fault of her own. As this is severely unjust, Superman naturally goes and saves her from this fate. However, it can also be said that Lois Lane looks a lot like the representation of justice in the second image. Perhaps the producer has chosen to make her seem like the Scales of Justice to connote justice and righteousness with superman, or with America as a whole? The overall situation also suggests that the Americans thought very lowly of the Japanese, assuming they were dishonourable demons, almost, after the war atrocities of pearl Harbour and various other battles. Whilst Japan is represented as a dirty, dark, evil country, the two main American characters in the short are the epitome of justice and honour.]
Spoiler
Postby NicNac14 » 2008.11.02 (21:28)
*LittleViking*
for my n movie i am making... coming to the forums near you soon...
Postby wumbla » 2008.11.03 (00:29)
o’clock
eganic wrote:I WUMBLA
YOU WUMBLA
HE SHE ME
WUMBLA
Postby unoriginal name » 2008.11.03 (21:31)
You should.
I've no idea.
Postby MattKestrel » 2008.11.03 (21:47)
Postby Universezero » 2008.11.03 (22:09)
Postby bufar » 2008.11.03 (23:47)
I'm getting good at the whole "tag before you post" thing.
Postby Donfuy » 2008.11.03 (23:50)
Postby bufar » 2008.11.04 (04:33)
I in no way endorse and/or condemn this map.
Postby Pikman » 2008.11.04 (20:03)
I need to read PMS
Postby bufar » 2008.11.04 (20:07)
An entry into Paradigm Shift.
Postby MattKestrel » 2008.11.04 (20:42)
quote="atob"
Postby a happy song » 2008.11.04 (23:25)
Postby aids » 2008.11.05 (00:52)
Postby wumbla » 2008.11.05 (02:35)
YOU WUMBLA
HE SHE ME
WUMBLA
Postby bufar » 2008.11.05 (02:51)
(nothing)
Users browsing this forum: No registered users and 45 guests
