RETROMORPHOSIS [MODERATOR PLEASE CLOSE]
Postby wumbla » 2010.06.21 (21:40)
can I still join in? if yes, sign me up as a contestant
eganic wrote:I WUMBLA
YOU WUMBLA
HE SHE ME
WUMBLA
Postby ENT474 » 2010.06.22 (05:53)
for the objects, can you use only those things?
Postby ENT474 » 2010.06.22 (06:06)
ENT474 wrote:for the objects, can you use only those things?
The object modifications sound like instructions.
Postby crescor » 2010.06.22 (08:38)
and
Could I get a confirmation that this is according the rules?
NUMA Profile: http://nmaps.net/user/sTalkR
Postby sTalkR » 2010.06.22 (14:18)
@wumbla, you are very welcome to join. i'll add you to the list.
@ENT474, the modifications are not instructions. you MAY use them, you MAY not. for example, crescor did change the placement of the ninja, and he added 10 mines, but he kept the drones.
the first code box labelled "tiles" gives you the tileset of map 6-1. you are to make a playable map out of it that is fun, exciting and good looking. you can use anything you like, but you can NOT modify the tiles (as there are no tile modifications available).
the second code box labelled "objects" gives you the object set of map 6-1. you are to add tiles to create yet ANOTHER fun, exciting and good looking map. on top of that, you can use the modification options i gave you in the first post. got it? got it.
@crescor, your maps are both valid entries. congratulations, you understood the rules =)
Postby Brainwasher » 2010.06.22 (21:37)
I have not joined a contest in a while, so I'm up for this one.
Now back from life.
Postby sTalkR » 2010.06.23 (01:54)
sure, you're in.
Postby ENT474 » 2010.06.23 (02:22)
Wow, I suddenly realized how stupid I was and how simple the instructions were.
Postby bufar » 2010.06.23 (06:26)
Re-Tile = Re-Object
Nmaps.netNmaps.net
Postby Brainwasher » 2010.06.24 (19:18)
Re-tile:
Edit: cool, here's the re-object
Now back from life.
Postby sTalkR » 2010.06.24 (20:22)
it's also in the first post.
Quarks
Postby lj11 » 2010.06.26 (01:41)
My entries will be collabs with j_v
Postby wumbla » 2010.06.26 (06:23)
Re-tile:
Re-object:
YOU WUMBLA
HE SHE ME
WUMBLA
Postby crescor » 2010.06.26 (09:38)
I made a new map, and I'm going to pull my first retile out. Is that allowed?
Edit: I allready changed it, if this is not okay, tell me
Postby sTalkR » 2010.06.26 (12:58)
sure, you can change your entries until the end of the round.
Postby wumbla » 2010.06.26 (15:53)
i noticed you lacked a judge, i would be glad to withdraw myself from the competition to judge, maybe, it depends if you've found one by the 28th
YOU WUMBLA
HE SHE ME
WUMBLA
Postby sTalkR » 2010.06.26 (15:56)
i decided to run the contest with 2 judges. thanks anyway =)
Postby wumbla » 2010.06.26 (16:19)
no problem. Oh and i realised my re-object subission wasn't valid, so I fixed it up and editted my original post
YOU WUMBLA
HE SHE ME
WUMBLA
Postby 大見解 » 2010.06.27 (14:08)
Re-object
Re-tile
edit map tags :P
Postby sTalkR » 2010.06.27 (17:07)
daikenkai, i'm pretty sure that the code of both your maps is messed up. either that, or i'm too dumb to copy it correctly.
Postby 大見解 » 2010.06.27 (17:45)
sTalkR wrote:daikenkai, i'm pretty sure that the code of both your maps is messed up. either that, or i'm too dumb to copy it correctly.
I just tried copying them, and both the maps were perfectly fine >_>
Postby sTalkR » 2010.06.27 (17:58)
yeah, my bad :/ nevermind.
Postby crescor » 2010.06.27 (19:54)
Stalkr, I'm afraid you're too stupid :)
Also, Daikenai, that retile is fantastic. I found the re-object a little too tedious though.
Quarks
Postby lj11 » 2010.06.27 (20:24)
NUMA Profile: http://www.nmaps.net/user/da_guru
Postby da_guru » 2010.06.27 (20:34)
Port de Sur = retile
District 08151a = reobject
I hope I did everything right.
