List of substances that cause false positives on drug tests
Postby scythe » 2010.06.04 (02:19)
http://www.askdocweb.com/falsepositives.html
I figured this might be useful, mostly because a false positive at best usually means they'll make you test again and at worst means you won't get whatever job you're applying for. Things like poppyseeds --> heroin aren't surprising, but you might jump at aleve (naproxen) ---> cannabis and amoxicillin ---> cocaine. Some of the refs are very good (anything that says ref 29 for example, it's a handbook from a drug test maker) while others are not so much (e.g the one off the phentermine forum). I'd still avoid these in the lead-up to a test, I guess.
The Vicks stuff is interesting, because it actually contains methamphetamine, but only the entirely inactive isomer laevomethamphetamine. Drug tests, apparently, are achiral.
Postby SlappyMcGee » 2010.06.04 (03:03)
I literally apply vicks to myself every morning and night.
Postby origami_alligator » 2010.06.04 (16:21)
http://www.askdocweb.com/falsepositives.html wrote:Last updated, April 20, 2010.
Postby Rose » 2010.06.13 (02:26)
DemonzLunchBreak wrote:
Hahahahaha.
Is less than two months really enough to be outdated? o_O
Postby 乳头的早餐谷物 » 2010.06.13 (02:27)
http://en.wikipedia.org/wiki/420_%28cannabis_culture%29
Postby Rose » 2010.06.13 (02:30)
白菜 wrote:
MAXXXON wrote: Is less than two months really enough to be outdated? o_O
Ohhhhhhhh. Right.
>____>
Postby otters~1 » 2010.06.13 (02:30)
MAXXXON wrote:Is less than two months really enough to be outdated? o_O
<3
