do you play your NUMA levels in debug or userlevels
- On the Psychic Highway
- NUMA Profile: http://nmaps.net/user/mahi_mahi
Debug. Never use Nreality, so I have no reason to be in userlevels.
I play packs in userlevels.
debug, unless i'm in nreality for some reason, like if i was going to be playing some nreality maps anyway. i generally don't map in nreality, because i have a tendency to get a blank flash player with "your flash player may have been running with an abnormally speed" displaying where my beautiful map used to be.
I play my NUMA levels in my userlevels, since they are there along with all the countless maps I haven't submitted.
I play NUMA levels on NReality because of the highscore submission system and the fact that you only have to press {spacebar} instead of ~ R tab tab 1 P with caps lock on.
For anything else, though, I use N. userlevels for packs, and obviously debug for mapping :p I never map in NReality. Too many horror stories about Flash crashing, which has never happened to me in N.
- Beyond a Perfect Math Score
NReality userlevels.
Nreality userlevels. Much less hassle, plus it has an inbuilt highscoring system :)
debug is original and nostalgic.
- NUMA Profile: http://nmaps.net/user/rocket_thumped
Debug. Packs of course go into userleves.
- Eleven Squared
- NUMA Profile: http://nmaps.net/user/nevershine
I play in userlevels for convenience. o_ORadium wrote:i play in debug for convenience
- Phei Phei Pho Phum
I agree with heatwave that Userlevels is more convenient, but only in the long run - say, if you're looking to make a fast demo. There's no denying that pressing the Spacebar between plays is way easier than ~ + R + 1 + CapsLk + P + CapsLk, no matter how good you are at the latter.
And yet, I use debug (even when recording demos) because it makes loading the level faster. In my defense, this is because I don't often see myself trying to make a fast demo.
- Steam: What's Steam
I used debug mode.
debug more just because it takes more than a minute (or less) to play my map in userlevels.
- Intel 80486
Always in debug. It's great especially since I suck and I can just respawn after I die without having to start over.
I play my jazz in Ned.
\ ctrl a ctrl v l capslock 1 p
(Debug, for the advantage of being available in both N and NReality.)
I play all my maps in debug; so much easier. Plus, I've got use to Home + \ + r + p.
I play NUMA maps and mappacks in nreality userlevels though.
- Maxwell Smart
Userlevels.
Way easier, and I can return to maps whenever I want. I generally don't want to download maps which are done after single run. Exceptions are really good races. I even test my levels in userllevels, the hassle to retry the level is too big to me. Especially considering the types of maps I like to play.
So you make the whole map before ever playtesting it? o_Okoipen wrote:Userlevels.
I do another playtest for nearly every object or tile I add or subtract.
- Maxwell Smart
I usually build the map, playtest, then edit and repeat this cycle until I'm satisfied. DDAs are exception.MAXXXON wrote: So you make the whole map before ever playtesting it? o_O
Most of my casual mapping is done this way. I still make them in debug, but I almost never have to playtest maps.MAXXXON wrote:So you make the whole map before ever playtesting it? o_O
Same thing with maps on NUMA. I don't actually *play* maps anymore - I just look at them and see how they would play and rate them accordingly.
Play NUMA levels on NReality, since I just have to put the number and voilá
Play mappacks in userlevels, obviously. One n_v14/Nreality folder per mappack (being nreality or n_v14 is random)
