Why N dies when he falls of a high place
Why do you think N dies when he falls from a high place?
Because of the speed accumilated.
30
86%
Because the game kills him when he falls from a certain height.
5
14%
Total votes: 35
Postby Zephyr » 2008.11.03 (21:52)
I've been wondering about this for a while, does N die when he falls of a high place because of the speed accumilated while falling? Or does the game kill him according to the height he falls from?
I'm a bit confused myself and need some answers =/
Clickme
Postby amomentlikethis » 2008.11.03 (22:50)
You can survive falling to the floor after touching a downward-facing launchpad, so I'm quite sure it's more the height than the speed.
Hi.
NUMA Profile: http://nmaps.net/user/Mr__X
Postby Mr__X » 2008.11.03 (22:58)
I think it's because of the speed. If you run into a wall fast enough (like through a powered-up launchpad or thwump propulsion) then you die. A downward-facing launchpad helps to survive a fall because it doesn't add to your current speed, but lowers it to the speed the launchpad is set to.
Postby blue_tetris » 2008.11.03 (22:58)
You can die from accelerating into walls or ceilings at a high enough rate. I think he dies from the acceleration.
The Real N Sex on the Xerox Space Pimp Online Super Fluffy Pack 1! Super Fluffy Pack 2! Super Crunchy Pack! Mother Thumping Impossible: 2005 MotY! Time is on My Side: 2006 PMotY! Survival map king! Best humor award! Best satire award! Best voice award! Inadvertently intimidating! Assholier than thou! Gdubs is totally back! WIS 14! Cyberzone creator! Clique creator! Most lines on IRC! Ventrilo moderator and regular! Certified Dungeon Master! Most modest person ever! ENTP! Incorrigible alcoholic! CHA 19! AMERICAN! Least pretentious! Elitist extraordinaire! Liberal libertarian! Incapable of experiencing love! Check Safe! Commodore of the Eldritch Seas! Archmagus of the Eleventh Hall! Sheriff of the Uncharted West! Godfather of the IRC Mafia! Pun enthusiast! Quadster! Challenging Dunbar's number! Wikipedian!Approves of 4th Edition! 1,000 Blank White Cards! radio_free_tetris! Migratory! INT 18! Doesn't know when he's being genuine, therefore cannot form lasting relationships with people! Really into black chicks! Even more into Indian chicks and Blasians! Hates moderators! Loves the C word! Tronster! Thinks we should play more Worms! Always wins iSketch! Owns a Wii! Plays as Pikachu in Smash Bros! Wrote literotica! Wrote anime fanfic! Sorta into Asians! Lived and loved the 80's and 90's! Chattiest sig! Cyberzone ][ creator! Operand of the Greater Space Pimp Continuum! Helped lead the forum move!Wizard Date! Participated in the blue_tetris takeover! Pithiest one-liners! Walkin' on, walkin' on broken glass! Seems to have an invisible touch! Economist! Mario hackster! Owner of the most complex D&D campaign setting! Micromanagerial! FREEDOM is all-American! Slowly distancing! Supports the Democrats! Supports the old GOP! CATO Institute fanboy! Penn and Teller fan! Large, in charge, and on a barge! Heralded by community as genius hero! Proud yet humble recipient of the Mare & Raigan Award for 2008! CON 9! Dave of Nazareth! Communist is annoyed with me! Not half bad at images! F.Y.I. I am a medic! It's a spook house, lame ball. Too bad! Space Pimp II: Rags 2 Bitches! F.Y.I. I am a spy! Entire team is babbies! STR 10! Sorta appreciating scythe and atob again, for new reasons! Played CS:S briefly! Welcome to Nebraska! Do you think you can Live! Heist! Portrayer of the mighty 88 Shells! Joyous proprietor of the future estate of Kablizzy and blue_tetris! It's Batmen all the way up! They brought crystals to a sceince fight; that's a good way to lose your cat! Even SlappyMcGee! I'm about to run out of either primates or sexually transmitted diseases! One-upper! Toaster oven clairvoyant Mythomaniac! That's the Magic of Macy's! Half of Half! Spend all my time making love, all my love making time!
Postby Condog » 2008.11.03 (23:15)
I think it's from the acceleration. If you hit any surface fast enough, you get splattered.
Postby isaacx » 2008.11.04 (00:47)
i think it's the height because than hitting corners and such from big heights wouldn't be possible
Postby squibbles » 2008.11.04 (01:19)
speed kills man.
Don't do drugs.
Postby blue_tetris » 2008.11.04 (01:43)
isaacx wrote:i think it's the height because than hitting corners and such from big heights wouldn't be possible
Hitting corners during a fall reduces the acceleration against that surface. You slow down instead of come to an abrupt stop.
Postby twentythree » 2008.11.04 (01:52)
I'm pretty sure in nReality you can make the gravity accelerate more and so it'll die from a lower height.
23!!!!!
Postby Yoshimo » 2008.11.04 (02:03)
It's a simple thing called terminal velocity. If you hit something fast enough, it's going to hurt. It's like getting punched by concrete (or whatever the retard-walls are made out of) in relativity. It breaks bones and jiggles organs. Jigglying enough to make them break.
In game, It's still speed. If you hit a slope, most downward speed is kept, and then burned in friction, slowly causing speed to fade, instead of losing it all in lethal time.
Postby twentythree » 2008.11.04 (02:39)
Terminal velocity is the velocity at which you fall where the air is pushing up on you with the same force as gravity is pulling you down. So on the moon or something with no air, there is no terminal velocity. Impulse is the change in momentum divided by change in time, or force times the time that the force is applied. When you fall onto the flat ground, there is very little time during which the force is applied, so the force is very big. When you fall onto an angled slope with the same velocity, there is less upward force applied by the surface, so you will survive. In real life you probably wouldn't be able to survive a several story fall landing on a 45-degree slope, but that ninja is pretty strong.
23!!!!!
Postby golf » 2008.11.04 (02:48)
in game help - falling 2 wrote:your impact speed is measured perpindicular to the surface -- falling straight down onto a horizontal surface may kill you, while falling the same height to a slope may not.
Look at the help section of the game, people...
Postby Kablizzy » 2008.11.04 (03:16)
It's a physics-based game. Why is this even an issue? Acceleration, anyone?
Postby Nexx » 2008.11.04 (06:07)
Wow, there are a lot of nonsense posts in this thread.
Anyway, acceleration is key, but it also only applies to surfaces (tiles, one-ways, bounceblocks). If you fall the entire height of the map and hit an upward-facing jumppad, even more acceleration was involved than if you just hit the ground, yet you don't die. So acceleration isn't everything as far as the game engine is concerned.
Postby George » 2008.11.04 (07:51)
Newton's Second Law of Motion: Force = Mass × Acceleration.
Mass is constant, thus an increase in acceleration equates to an increase in force. A big enough force will kill the tiny ninja.
Postby Nexx » 2008.11.04 (08:16)
George wrote:A big enough force will kill the tiny ninja.
...except when a jumppad is causing said force...
Postby KlanKaos » 2008.11.04 (09:39)
I think what launchpads do is actually remove all velocity from the ninja at time of impact. Yeah, it isn't possible in real life due to the conservation of energy, but the ninja's speed is absorbed into the launchpad, not translated into downwards force.
Postby Kablizzy » 2008.11.04 (10:34)
KlanKaos wrote:I think what launchpads do is actually remove all velocity from the ninja at time of impact. Yeah, it isn't possible in real life due to the conservation of energy, but the ninja's speed is absorbed into the launchpad, not translated into downwards force.
I believe you may be right, sir.
Postby Zephyr » 2008.11.04 (10:51)
I'm getting VERY confused now.
Clickme
Postby LittleViking » 2008.11.04 (12:11)
z3phyr wrote:I'm getting VERY confused now.
Just look at the poll votes then. They're correct. You're killed by the speed accumulated, basically.
Postby George » 2008.11.04 (12:42)
Yeah, launch pads are weird. The conservation of momentum doesn't seem to apply to one way platforms either. No matter how fast you're travelling (up, left or right), you just don't die when you hit the one way.
Alive
NUMA Profile: http://nmaps.net/user/euphoria
Postby euphoria » 2008.11.04 (14:58)
You can hit vertical and horizontal surfaces going faster than the speed at which N dies from falling though. Likely the downwards momentum causes him to die at a lower speed, while sideways and vertical momentum allows for harder impacts before death.
Something kinda sad about the way that things have come to be. Desensitized to everything, what became of subtlety?
Postby MattKestrel » 2008.11.04 (16:51)
Theres a terminal velocity mod on nreality. Therefore, its the speed, not the game.
Postby Pixon » 2008.11.04 (16:56)
Its because of the speed. Have you ever seen people committing suicide on top of a high building? Its like that.
Postby LittleViking » 2008.11.04 (17:56)
@"terminal velocity": Terminal velocity is an object's maximum falling speed, not the speed at which the ninja dies. Terminal velocity occurs when you're hitting enough air resistance in your fall that your speed can no longer keep going up. A feather would have a very low terminal velocity, while something narrow and heavy like a marble would have much higher terminal velocity.
@not dying on slopes: When you land on a slope, some of your downward speed is converted into sideways motion, so the downward impact is less. Falling on a 45 degree slope makes the impact 30% softer than falling flat.
