Nreality - replays help
Almost as Bad as One
Postby durfi » 2010.05.10 (11:55)
Hey guys!
Im having trouble with viewing my own replays. In the highscores area, when I click on a replay it loads the level but the ninja stands still. Is it a common issue? And is there any solution for this?
Thanks in advance!
Durfi
Postby Pikman » 2010.05.11 (00:01)
Are you sure that you're clicking the time or the View Replay button rather than the map?
Postby durfi » 2010.05.11 (10:14)
Hello!
I click on the Map number in the "Personal bests" section top left. I've made a screenshot, cause I guess its not the way it should look like:
There are no personal bests at all : S
MBTI Type: ESTP
Postby kkstrong » 2010.05.12 (16:16)
From the screenshot, Most likely your problem is:
1) You need to login (main menu --> configure)
2) You lost your .sol and should check and see if you have it. Link!
It may be another problem (or problems), but those are the two most likely.
