Whoa... that exists? How do I go about doing that?heatwave wrote:Just make sure you turn on private contest mode in NReality. That is, if you don't want the contestants to be able to see each other's runs. (Which I assume is your intention)hippo wrote:NReality is required and your run must be posted there.
MPT3 - Sign-Up Closed, Seeding Week Has Commenced!
- Semimember
- - - - - - - - - - - - (Formerly IAABH, pajammin) - - - - - - - - - - - -
I never knew of a such thing?hippo wrote:Whoa... that exists? How do I go about doing that?heatwave wrote:Just make sure you turn on private contest mode in NReality. That is, if you don't want the contestants to be able to see each other's runs. (Which I assume is your intention)hippo wrote:NReality is required and your run must be posted there.
- NUMA Profile: http://www.nmaps.net/user/da_guru
- Semimember
I agree, and that's why I'll probably leave it open, but at the same time the closed competition would encourage players to find their own routes. However, it worked fine as an open competition in MTP2 and it made it very exciting.da_guru wrote:But that wouldn't motivate you to do even greater runs. You'd probably stop trying to get a better demo much earlier than you'd do if the demos of the others were visible, imo.
- MBTI Type: ESTP
Append |||protectedcontest at the end of the map (assuming its the only NReality mod in the map) to have the runs private, but the scores public (so I could see that xaelar got 225.375, but I couldn't click and see his run), except the mapmaker can see the runs again
- Semimember
Ah I see. The protected contest is a cool idea, but the problem is that I'm using already rated maps for this and I can't edit the map data.kkstrong wrote:Append |||privatecontest at the end of the map (assuming its the only NReality mod in the map) to have the runs and scores private to everyone but the mapmaker,
I think it should be fine. Unless everyone objects, the tournament should be just as fun as a public scoring competition.
- MBTI Type: ESTP
Also I'm in, if you'll have me.
I presume you mean undone.kkstrong wrote:You would just resubmit and delist, the only problem with protectedcontest is that it can't be done except by Unreality himself, so you would otherwise have to post the demos here. Private contest //can// be undone.
How are the pairings decided, is it completely at random like picking names out of a hat or otherwise; and are they decided for each round at a time or all at once?
- Semimember
For MPT2 I did it with seeding based in # of highscores. I'm looking to make it random this time but if everyone wants seeding then we can do it that way.999_Springs wrote:I presume you mean undone.kkstrong wrote:You would just resubmit and delist, the only problem with protectedcontest is that it can't be done except by Unreality himself, so you would otherwise have to post the demos here. Private contest //can// be undone.
You should join!
I'd actually prefer random pairings so just keep it that way, thanks.
- Semimember
I agree I would like to see some form of seeding as well. It could be done as simple as one seeding map to start, and then 0th plays 19th, 1st plays 18th... etc. If there ends up being more than 20 people this can still work, you will just have to look at the n.infunity.com page for the map to show highscores that aren't in the top-20.Fenneth wrote:This isn't a democracy, but I'd still like to put my vote in for some level of seeding. Van vs Izzy or something round 1 would be a pity.
- NUMA Profile: http://nmaps.net/user/aerodynamic
While originally I was in disagreement with Fenneth, I do like the way TRO has proposed it. A qualifying lap, er, map, is not only a simple and fair seeding method, but it allows everyone a chance to compete more than once. For example, even if you get out in the first round you would still have had the opportunity to compete against everyone else in the competition, which sounds like a fun idea to me.TheRealOne wrote:I agree I would like to see some form of seeding as well. It could be done as simple as one seeding map to start, and then 0th plays 19th, 1st plays 18th... etc. If there ends up being more than 20 people this can still work, you will just have to look at the n.infunity.com page for the map to show highscores that aren't in the top-20.Fenneth wrote:This isn't a democracy, but I'd still like to put my vote in for some level of seeding. Van vs Izzy or something round 1 would be a pity.
- Legacy Elite
- Semimember
This is a cool idea.TheRealOne wrote: I agree I would like to see some form of seeding as well. It could be done as simple as one seeding map to start, and then 0th plays 19th, 1st plays 18th... etc. If there ends up being more than 20 people this can still work, you will just have to look at the n.infunity.com page for the map to show highscores that aren't in the top-20.
- Oops Pow Surprise
- Semimember
This is a great idea. And will happen.TheRealOne wrote:I agree I would like to see some form of seeding as well. It could be done as simple as one seeding map to start, and then 0th plays 19th, 1st plays 18th... etc. If there ends up being more than 20 people this can still work, you will just have to look at the n.infunity.com page for the map to show highscores that aren't in the top-20.Fenneth wrote:This isn't a democracy, but I'd still like to put my vote in for some level of seeding. Van vs Izzy or something round 1 would be a pity.
YOU RUINED THE SURPRISE OF MY GENIUS IDEA! Haha.Daikenkai wrote:you should have a seperate thread for like.... bracket subs. Fill in a bracket of who you think would win. Establish a point system for the bracket, and see who wins the guessing.
Yeah I was planning on doing this and it'll make the tourney that much more exciting.
MORE CONTESTANTS!!!
hippo even if you wait another 2 weeks, at most 2 more people will join, everyone who wants to be in, is. start it already or everyone will lose any enthusiasm he has (my grammar sucks). the community is small nowadays, keep that in mind.hippo wrote:MORE CONTESTANTS!!!
- Semimember
I'll wait a tiny bit longer and then set it up.vankusss wrote:hippo even if you wait another 2 weeks, at most 2 more people will join, everyone who wants to be in, is. start it already or everyone will lose any enthusiasm he has (my grammar sucks). the community is small nowadays, keep that in mind.hippo wrote:MORE CONTESTANTS!!!
It would be nice to just have even a couple more, but if it's really slowing down then we'll just get this party started.
I'll join in.hippo wrote:Keep signing up everyone! Even if you're completely inexperienced, it's worth a shot!
But, can anybody explain me what shall i do when a map is chosen to be played,i mean, do i submit my score to NReality? Do i post the demo here ?
- Semimember
You'll submit your run on NReality. This makes it much easier to judge. :)EddyMataGallos wrote:I'll join in.hippo wrote:Keep signing up everyone! Even if you're completely inexperienced, it's worth a shot!
- Semimember
Haha same with me. I'm in the middle of finals but I enjoy the occasional distraction. :Pheatwave wrote:I want to join this, but alas. Finals are creeping up.
If you change your mind, I'd still love to have 9 more players, so you would be very much appreciated!
Ok, thanks!hippo wrote:You'll submit your run on NReality. This makes it much easier to judge. :)EddyMataGallos wrote:I'll join in.hippo wrote:Keep signing up everyone! Even if you're completely inexperienced, it's worth a shot!
