Can't submit my map.
Moderators: Rose, Sunset
Postby Jumpset » 2010.03.30 (19:05)
Yo. :P
So yeah, as the title says, I can't submit my map for some reason. When I try to submit it, I get the error "No objectid for object". I submitted a map just earlier, so why doesn't it work now? o.o Yes, there are objects in the map.
Thanks. :P
Edit: Well yeah, it apparently fixed itself. o.o How come?
NUMA Profile: http://nmaps.net/user/el_devo
Postby el_devo. » 2010.03.31 (23:48)
I've had this problem before, the error seems to come from not having the '#' at then end of your map data, or not starting it with a '$' Hope that helps.
Postby Jumpset » 2010.03.31 (23:51)
As said, it already fixed itself. I think it's because I accidentally dropped a character somewhere. xD
Postby PALEMOON » 2010.04.01 (00:25)
You cannot post a map without any objects in it. Even tilesets need to have some object hidden in the tiles for the website to accept it.
Postby Jumpset » 2010.04.01 (00:29)
Well I know. o.o It was a normal map with objects in it that worked in ned too. Maybe it was just a glitch on the website, since it fixed itself. :P
