NLympics records here
Postby EdoI » 2008.09.27 (19:11)
Hi all! If you made the record from the NLympics map-pack that is here http://forum.therealn.com/viewtopic.php?f=18&t=78, just post the replay data if the map has exit, if it doesn't send a demo and I'll put it on the thread!
Postby Evil_Sire » 2008.09.27 (19:52)
You tried this on the old forum man.
And it failed
lock?
Postby EdoI » 2008.09.28 (19:38)
Evil_Sire wrote:You tried this on the old forum man.
And it failed
lock?
Because there was a 'Post a Run' thread where runs should be posted. Now there isn't (and I hope there won't be), so it shouldn't be locked, right?
Postby ToeFaceKiller » 2008.09.29 (01:26)
As mentioned, all topics will be ported over to this forum. This should include the post a run thread, as it was pinned and quite active.
As this thread is for NLympics map pack only, though, it shouldn't have anything to do with the post a run thread, so I don't see why it has to be an either/or type thing.
Postby Neil_Bryan » 2009.05.12 (03:38)
Records of NLympics:
NOTE: Times are based on Min:Sec:Millisec
Time might be longer than average time.
Archery-unaccomplished
Bounce Blocks Breaking= 00:29:83 = 29.83 sec
Chimney Jumping W x1=3.35 sec
Chimney Jumping W x2=6.69 sec
Chimney Jumping W x3=10.19 sec
Diagonal Wall Climbing=3.98 sec
Freefall-unaccomplished
Gold Collecting-AGD=03:18:34 = 3 min 18.34 sec
Hurdles=9.85 sec
Long Bouncing=amount of gold passed by ninja: 30 pcs
Long Jump=amount of gold passed by ninja: 34 pcs
Mines Avoiding=17.23 sec
Nonathlon-unaccomplished
One Wall Climbing=6.78 sec
One Way Platform Jumping=13.31 sec
Reverse Bounce Blocks Breaking=21.58 sec
Thwump Riding-unaccomplished
Timed Jumping-tight tileset-unaccomplished
Timed Jumping-wide tileset-unaccomplished
Perpendicular Frenzy-unaccomplished
Pole Vault=17.96 sec
Chimney Climbing (w/ Laser)=7.87 sec
Heptathlon-unaccomplished
Running-unaccomplished
Swimming-unaccomplished
Thwump Cannon Blasting=11.47 sec
Thwump Moving=16.61 sec
Tile Hanging=27.46 sec
Uphill Climbing (w/ Laser)=10.28 sec
3-pont Shot-unaccomplished
Survival Conceptual-Delaying the Inevitable=reached the end at 4.89 sec
Names of Towns
Shortest: Y
Postby EdoI » 2009.05.12 (10:49)
I need demos...
Postby Rhekatou » 2009.05.13 (02:55)
ToeFaceKiller wrote:As mentioned, all topics will be ported over to this forum. This should include the post a run thread, as it was pinned and quite active.
wait - - -
no they aren't!
(correct me [kindly] if i am wrong/wrongly reviving this thread)
Postby ToeFaceKiller » 2009.05.13 (07:28)
You're right, but check the date on that reply. I posted that before anyone knew the threads weren't being ported over... The main point of that reply was to say the post a run thread and this thread are completely separate things, and shouldn't conflict with each other. Sorry for cluttering up this page, EdoI.
Users browsing this forum: Google [Bot] and 13 guests
