It says "retarded highscorer" Retarded? :/mohamedraif wrote:Why does your sig still say retired? :/
Metanet 0ths Thread
I swear it said 'retired highscorer' when I posted. Van, must have changed the sig since then.Izzy wrote:Because he sucks :PTunco wrote:It says "retarded highscorer" Retarded? :/mohamedraif wrote:Why does your sig still say retired? :/
99-1, 81-0 with obvious innov, ep 51 back with crappy runs, and there are maybe few others
also since xaelar is hiding in shadows, i'll mention his 0th's for him: 73-3, 61-1, 24-3 (he took this back from macrohenry, unfortunately it's not on nreality boards, so XAELAR resubmit it). Hmm, and what about visiting irc, xaelar? Maybe there's a surprise waiting for you there? Or maybe not? Find out yourself!
Izzy wrote:When will he stop?
I suppose then, but idk if he will stop then or if that is just the "mission" for the time being. ;) let's hope he goes for at least 273/600, or maybe 250/500 since he doesn't like EP 0thing. lol, but either way go van!!!vankusss wrote:no i'm not :D i need only 97 (little less) xela's 0ths for 0th on hs rankings :) that's the mission!TheRealOne wrote:Well currently xaelar is the all time most prolific highscorer with 272 0th at one time. Are you up for the challenge van? ;)Izzy wrote:van's only going to stop when he beats xela.
It's also second level on the table of largest gaps between 0th and 1st score (first beeing lat's 84-0), so nobody touch it!
xaelar touched it... Absolutely sick innovation though; relatively simple route change for +3 second possibility.vankusss wrote:93-4 with new route AAAAAAAAAARGH, it was really painful i died FOUR TIMES on the last jump with agd.
and seriously, N Contests and High Scores => Metanet highscore 0th's => make it sticky?
- Phei Phei Pho Phum
On it. Should've just PM'd me, I'd have been happy to do it. ;)vankusss wrote:and seriously, N Contests and High Scores => Metanet highscore 0th's => make it sticky?
- Alive
i'm confused by your post, does it mean it's cheated or what? otherwise, you should change your nick and use nreality so TRO can include your legit runs into rankingsL3X wrote:72-2, tied 0th. You guys ignore my runs anyway, and i already had a top 20th on the level, so not like i'm taking a spot from anyone. Anyway, my run is horrid and i mess up a jump, someone could probably squeeze at least another .4 out of the level.
edit: l3x i see you, go to irc
edit2: 59-3 with new route
L3x if you want to start highscoring again that is great, you don't even need to switch your nick. Just start using NReality and submit highscores that way, and then I will subtract 16 from your 0th count because that is the number 0th you had form back in the day. Any new 0ths will still count as long as NReality is used. NReality Download LinkL3X wrote:72-2, tied 0th. You guys ignore my runs anyway, and i already had a top 20th on the level, so not like i'm taking a spot from anyone. Anyway, my run is horrid and i mess up a jump, someone could probably squeeze at least another .4 out of the level.
- Legacy Elite
I added another corner jump to 93-1 to beat lat for my first level 0th in quite a while.
Also, hello to everyone that I haven't seen already on IRC.
