'Kay.Techno wrote:SlappyMcGee, may I use this if I remove the items?
ADMINISTRONG ROUND 2 + RESULTS
- MBTI Type: ESTP
- Beyond a Perfect Math Score
Pikman wrote:Here's a .txt of all submissions thus far, in userlevels form:
Oh! :D
Lies! Mine and Demonz weren't in there. Also, you forgot the # symbol at the end of kkstrong's map (!!!). See attached (also, added Avarin's).Pikman wrote:Here's a .txt of all submissions thus far, in userlevels form:
- Attachments
- administrong.txt
- (70.08 KiB) Downloaded 236 times
It's because I uploaded the file I saved at like 2:30 PM. And if you want to get anal detail-oriented, your data from NUMA was the only map data I had a problem with. (The final # was moved down a line.) New version has all data fixed now, though it's really just the same as yours.
Also, heatwave hasn't replaced his post with an actual submission yet. Did he go somewhere?
- Legacy Elite
- MBTI Type: ESTJ
Edit it before tomorrow.bobaga_fett wrote:I've found a fatal gameplay error in the map that I submitted. You won't allow me to resubmit the fixed version, will you?
- MBTI Type: ESTP
Oh and Slappy, thanks for the feature. You're the best, dude :]
