ADMINISTRONG ROUND 2 + RESULTS
Postby SlappyMcGee » 2010.03.13 (18:21)
Techno wrote:SlappyMcGee, may I use this if I remove the items?
'Kay.
Postby Seneschal » 2010.03.13 (18:23)
Link to original tiles in description.
MBTI Type: ESTP
Postby kkstrong » 2010.03.13 (19:17)
Postby T3chno » 2010.03.13 (20:41)
Tileset:
Postby bobaganuesh_2 » 2010.03.13 (21:13)
nearly pissed myself when realized it was due today, and hadn't started yet. this is what I chalked up in 30 minutes, I'll likely tweak it later.
Postby scythe » 2010.03.13 (22:35)
Nmaps.net Nmaps.net
quick quick everyone play it
Postby Pikman » 2010.03.13 (22:54)
Here's a .txt of all submissions thus far, in userlevels form:
userlevels.txt
Let's try this again.
(74.29 KiB) Downloaded 224 times
Postby Nexx » 2010.03.13 (22:55)
tileset:
Postby SlappyMcGee » 2010.03.14 (00:04)
Pikman wrote:Here's a .txt of all submissions thus far, in userlevels form:
userlevels.txt
Oh! :D
Postby scythe » 2010.03.14 (01:47)
The attachment userlevels.txt is no longer available
Lies! Mine and Demonz weren't in there. Also, you forgot the # symbol at the end of kkstrong's map (!!!). See attached (also, added Avarin's).
administrong.txt
(70.08 KiB) Downloaded 236 times
Postby Pikman » 2010.03.14 (02:24)
Yeah, yeah.
It's because I uploaded the file I saved at like 2:30 PM. And if you want to get anal detail-oriented, your data from NUMA was the only map data I had a problem with. (The final # was moved down a line.) New version has all data fixed now, though it's really just the same as yours.
Also, heatwave hasn't replaced his post with an actual submission yet. Did he go somewhere?
MBTI Type: ESTJ
Postby Ad » 2010.03.14 (03:06)
Postby SlappyMcGee » 2010.03.14 (16:48)
Submissions are closed for everybody except for the one dude who has an extension.
Postby Riobe » 2010.03.14 (17:04)
tiles by the furriest ant of them all
Nmaps.net - My map
Nmaps.net - Tiles used
Postby Pikman » 2010.03.15 (00:06)
I felt like organizing a thing so here you go.
userlevels.txt
Complete round organization thing.
(76.04 KiB) Downloaded 239 times
"Nonexistent" means I haven't seen their submission. Other things are explained in the file.
Postby bobaganuesh_2 » 2010.03.15 (01:03)
I've found a fatal gameplay error in the map that I submitted. You won't allow me to resubmit the fixed version, will you?
Postby SlappyMcGee » 2010.03.15 (13:33)
bobaga_fett wrote:I've found a fatal gameplay error in the map that I submitted. You won't allow me to resubmit the fixed version, will you?
Edit it before tomorrow.
MBTI Type: ESTP
Postby kkstrong » 2010.03.15 (18:04)
There is also a fatal error in the tiles of my map, but I built the gameplay around the fatal error, so I guess its not so fatal xD
Oh and Slappy, thanks for the feature. You're the best, dude :]
Postby SlappyMcGee » 2010.03.16 (17:18)
Over now. Judging should be in be Sunday.
