Cookies don't work
- Radio Douchebag
Fixes?
- Radio Douchebag
No, I'm on forum.droni.es.incluye wrote:Someone should remove the forums.droni.es alias, no?
Not forums.
The default was changed to Retronet, that's not a problem.
- Mr. Glass
I don't like that.
- Mr. Glass
I'll lock it.
- Mr. Glass
As soon as I log back in and move to another from, it reinstates my desired skin.
- Radio Douchebag
Check. Did that.Chase wrote:It doesn't keep you logged in if you just use quick login at the top. You have to click "Login" next to the boxes and check the box.
Well it's just you, because they do work, it's just your PC doesn't like them.Rhekatou wrote:Check. Did that.Chase wrote:It doesn't keep you logged in if you just use quick login at the top. You have to click "Login" next to the boxes and check the box.
- Radio Douchebag
There's another (albeit minor) annoyance.Chase wrote:Well it's just you, because they do work, it's just your PC doesn't like them.Rhekatou wrote:Check. Did that.Chase wrote:It doesn't keep you logged in if you just use quick login at the top. You have to click "Login" next to the boxes and check the box.
The Quick Login has to have each field erased by a mouse drag.
But that's nothing major.
I'm not sure how I fixed it, but it is veritably annoying when it happens.
- Demon Fisherman
- Mr. Glass
I figured this out a few hours ago.Spawn of Yanni wrote:I hate to sound patronising or something (and it looks like rhekatou already checked this) but just to cover all bases, you guys are sure you didn't just use the quick login, right? You need to go to the main login page and check the "remember me" box.
Dumb dumb dumb.
-_-
- Radio Douchebag
I figured it out on the second try.brighter wrote:I figured this out a few hours ago.Spawn of Yanni wrote:I hate to sound patronising or something (and it looks like rhekatou already checked this) but just to cover all bases, you guys are sure you didn't just use the quick login, right? You need to go to the main login page and check the "remember me" box.
Dumb dumb dumb.
-_-
And it didn't work.
It also logs me out when I click a link (Ie: Yanni just sent me a link to the image worm, but clicking the link logs me out).
Even if you open it in a new window?SlappyMcGee wrote:I had the issue because I clicked a link that was mailed to me for a PM, and those still link to easterviking. Which is an issue that needs to be fixed.
What? The emails that are sent out for PM's link to EasterViking. That is just true. :/flagmyidol wrote:Even if you open it in a new window?SlappyMcGee wrote:I had the issue because I clicked a link that was mailed to me for a PM, and those still link to easterviking. Which is an issue that needs to be fixed.
